[geos-commits] [SCM] GEOS branch main updated. 156f66840b5814c944d2987bc38a25995a2ad00c
git at osgeo.org
git at osgeo.org
Thu Jul 15 10:51:30 PDT 2021
the project "GEOS".
The branch, main has been updated
via 156f66840b5814c944d2987bc38a25995a2ad00c (commit)
from f4d05b230d75bb85624c147c0a51d4987f069218 (commit)
revisions in full, below.
commit 156f66840b5814c944d2987bc38a25995a2ad00c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jul 15 10:38:12 2021 -0700
Clean out unused code from CascadedPolygonUnion
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index b7c5d9f..0bcf394 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -18,16 +18,10 @@
-#ifndef GEOS_OP_UNION_CASCADEDPOLYGONUNION_H
-#define GEOS_OP_UNION_CASCADEDPOLYGONUNION_H
+#pragma once
#include <geos/export.h>
-#include <vector>
-#include <algorithm>
-#include <memory>
-#include <geos/operation/union/GeometryListHolder.h>
#include <geos/operation/union/UnionStrategy.h>
// Forward declarations
@@ -39,11 +33,6 @@ class Polygon;
class MultiPolygon;
class Envelope;
-namespace index {
-namespace strtree {
-class ItemsList;
namespace geos {
@@ -255,4 +244,3 @@ private:
} // namespace geos::operation
} // namespace geos
-#endif
diff --git a/include/geos/operation/union/GeometryListHolder.h b/include/geos/operation/union/GeometryListHolder.h
deleted file mode 100644
index 1498da0..0000000
--- a/include/geos/operation/union/GeometryListHolder.h
+++ /dev/null
@@ -1,74 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#ifndef GEOS_OP_UNION_GEOMETRYLISTHOLDER_H
-#define GEOS_OP_UNION_GEOMETRYLISTHOLDER_H
-// Forward declarations
-namespace geos {
-namespace geom {
-class Geometry;
-namespace geos {
-namespace operation { // geos::operation
-namespace geounion { // geos::operation::geounion
- * \brief Helper class holding Geometries, part of which are held by reference
- * others are held exclusively.
-class GeometryListHolder : public std::vector<geom::Geometry*> {
-private:
- typedef std::vector<geom::Geometry*> base_type;
-public:
- GeometryListHolder() {}
- ~GeometryListHolder()
- std::for_each(ownedItems.begin(), ownedItems.end(),
- &GeometryListHolder::deleteItem);
- // items need to be deleted in the end
- void
- push_back_owned(geom::Geometry* item)
- this->base_type::push_back(item);
- ownedItems.push_back(item);
- geom::Geometry*
- getGeometry(std::size_t index)
- if(index >= this->base_type::size()) {
- return nullptr;
- return (*this)[index];
-private:
- static void deleteItem(geom::Geometry* item);
-private:
- std::vector<geom::Geometry*> ownedItems;
-} // namespace geos::operation::union
-#endif
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 3741dd9..c30c6f7 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -18,99 +18,29 @@
-#include <geos/operation/union/CascadedPolygonUnion.h>
-#include <geos/operation/union/OverlapUnion.h>
-#include <geos/operation/overlay/OverlayOp.h>
-#include <geos/geom/HeuristicOverlay.h>
-#include <geos/geom/Dimension.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/Polygon.h>
+#include <geos/geom/HeuristicOverlay.h>
#include <geos/geom/MultiPolygon.h>
-#include <geos/geom/util/PolygonExtracter.h>
+#include <geos/geom/Polygon.h>
#include <geos/index/strtree/TemplateSTRtree.h>
+#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/operation/union/CascadedPolygonUnion.h>
+#include <geos/operation/valid/IsValidOp.h>
+#include <geos/operation/valid/IsSimpleOp.h>
+#include <geos/util/TopologyException.h>
// std
#include <cassert>
#include <cstddef>
-#include <memory>
-#include <vector>
#include <sstream>
-#include <geos/operation/valid/IsValidOp.h>
-#include <geos/operation/valid/IsSimpleOp.h>
-#include <geos/algorithm/BoundaryNodeRule.h>
-#include <geos/util/TopologyException.h>
#include <string>
-#include <iomanip>
-//#define GEOS_DEBUG_CASCADED_UNION 1
-//#define GEOS_DEBUG_CASCADED_UNION_PRINT_INVALID 1
-namespace {
-#if GEOS_DEBUG
-inline bool
-check_valid(const geos::geom::Geometry& g, const std::string& label, bool doThrow = false, bool validOnly = false)
- using namespace geos;
- if(g.isLineal()) {
- if(! validOnly) {
- operation::valid::IsSimpleOp sop(g, algorithm::BoundaryNodeRule::getBoundaryEndPoint());
- if(! sop.isSimple()) {
- if(doThrow) {
- throw geos::util::TopologyException(
- label + " is not simple");
- return false;
- else {
- operation::valid::IsValidOp ivo(&g);
- if(! ivo.isValid()) {
- using operation::valid::TopologyValidationError;
- TopologyValidationError* err = ivo.getValidationError();
-#ifdef GEOS_DEBUG_CASCADED_UNION
- std::cerr << label << " is INVALID: "
- << err->toString()
- << " (" << std::setprecision(20)
- << err->getCoordinate() << ")"
- << std::endl
-#ifdef GEOS_DEBUG_CASCADED_UNION_PRINT_INVALID
- << "<a>" << std::endl
- << g.toString() << std::endl
- << "</a>" << std::endl
-#endif
-#endif // GEOS_DEBUG_CASCADED_UNION
- if(doThrow) {
- label + " is invalid: " + err->toString(),
- err->getCoordinate());
- return false;
- return true;
-#endif
-} // anonymous namespace
namespace geos {
namespace operation { // geos.operation
namespace geounion { // geos.operation.geounion
-void
-GeometryListHolder::deleteItem(geom::Geometry* item)
- delete item;
std::unique_ptr<geom::Geometry>
@@ -266,15 +196,13 @@ CascadedPolygonUnion::restrictToPolygons(std::unique_ptr<geom::Geometry> g)
-using operation::overlay::OverlayOp;
ClassicUnionStrategy::Union(const geom::Geometry* g0, const geom::Geometry* g1)
// TODO make an rvalue overload for this that can consume its inputs.
// At a minimum, a copy in the buffer fallback can be eliminated.
try {
- return geom::HeuristicOverlay(g0, g1, overlay::OverlayOp::opUNION);
+ return geom::HeuristicOverlay(g0, g1, operation::overlay::OverlayOp::opUNION);
catch (const util::TopologyException &ex) {
::geos::ignore_unused_variable_warning(ex);
Summary of changes:
.../geos/operation/union/CascadedPolygonUnion.h | 14 +---
include/geos/operation/union/GeometryListHolder.h | 74 ------------------
src/operation/union/CascadedPolygonUnion.cpp | 88 ++--------------------
3 files changed, 9 insertions(+), 167 deletions(-)
delete mode 100644 include/geos/operation/union/GeometryListHolder.h
hooks/post-receive
More information about the geos-commits
