[geos-commits] [SCM] GEOS branch main updated. 75cb982535b845a613e4050eda1f970662510554
git at osgeo.org
git at osgeo.org
Fri Oct 1 09:36:51 PDT 2021
the project "GEOS".
The branch, main has been updated
via 75cb982535b845a613e4050eda1f970662510554 (commit)
from 7f40256c66273f2dfaaf57cc56e6ad1347b17d6e (commit)
revisions in full, below.
commit 75cb982535b845a613e4050eda1f970662510554
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 1 09:36:47 2021 -0700
Fixes from Bas Couwenberg <sebastic at debian.org> pre-release
diff --git a/CMakeLists.txt b/CMakeLists.txt
index b87c32a..d2e9c26 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -271,8 +271,8 @@ if(BUILD_SHARED_LIBS)
target_compile_definitions(geos
PRIVATE $<IF:$<CXX_COMPILER_ID:MSVC>,GEOS_DLL_EXPORT,DLL_EXPORT>)
- set_target_properties(geos PROPERTIES VERSION ${GEOS_VERSION})
- set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION})
+ set_target_properties(geos PROPERTIES VERSION ${CMAKE_PROJECT_VERSION})
+ set_target_properties(geos PROPERTIES SOVERSION ${CMAKE_PROJECT_VERSION})
endif()
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 3393559..97e90a4 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -11,11 +11,12 @@
2. Prepare the build directory.
- $ mkdir _build && cd _build && cmake ..
+ $ mkdir _build && cd _build && cmake -DBUILD_DOCUMENTATION=YES ..
-3. Run the distcheck target, fix any problem with it.
+3. Run the distcheck target and docs targets, fix any problem with them.
$ cmake --build . --target distcheck
+ # cmake --build . --target docs
4. Update the NEWS file (extract most important things from the
repository log). Make sure to update the release date.
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 50a19bb..2f5c519 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -259,7 +259,7 @@ typedef void (*GEOSQueryCallback)(void *item, void *userdata);
* \param item1 first of the pair of items to calculate distance between
* \param item2 second of the pair of items to calculate distance between
-* \param return distance the distance between the items here
+* \param distance the distance between the items here
* \param userdata extra data for the calculation
* \return zero if distance calculation succeeded, non-zero otherwise
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index a74bcac..483b3a3 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -61,7 +61,7 @@ int main(int argc, char** argv) {
options.add_options()
("a", "source for A geometries (WKT, WKB, file, stdin, stdin.wkb)", cxxopts::value<std::string>( cmdArgs.srcA ))
("b", "source for B geometries (WKT, WKB, file, stdin, stdin.wkb)", cxxopts::value<std::string>( cmdArgs.srcB ))
- ("alimit", "Limit nunber of A geometries read", cxxopts::value<int>( cmdArgs.limitA ))
+ ("alimit", "Limit number of A geometries read", cxxopts::value<int>( cmdArgs.limitA ))
("c,collect", "Collect input into single geometry", cxxopts::value<bool>( cmdArgs.isCollect ))
("e,explode", "Explode results into conponent geometris", cxxopts::value<bool>( cmdArgs.isExplode))
("f,format", "Output format (wkt, wkb or txt)", cxxopts::value<std::string>( ))
diff --git a/util/geosop/README.md b/util/geosop/README.md
index 284e368..1d15f8c 100644
--- a/util/geosop/README.md
+++ b/util/geosop/README.md
@@ -30,7 +30,7 @@ It can be used to:
-a arg source for A geometries (WKT, WKB, file, stdin, stdin.wkb)
-b arg source for B geometries (WKT, WKB, file, stdin, stdin.wkb)
- --alimit arg Limit nunber of A geometries read
+ --alimit arg Limit number of A geometries read
-c, --collect Collect input into single geometry
-e, --explode Explode results into conponent geometris
-f, --format arg Output format (wkt, wkb or txt)
Summary of changes:
CMakeLists.txt | 4 ++--
HOWTO_RELEASE | 5 +++--
capi/geos_c.h.in | 2 +-
util/geosop/GeosOp.cpp | 2 +-
util/geosop/README.md | 2 +-
5 files changed, 8 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
