[geos-commits] [SCM] GEOS branch main updated. 69335b86051b8e27c981e18de4762a97764b512a
Fri Oct 1 10:21:43 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  69335b86051b8e27c981e18de4762a97764b512a (commit)
      from  56b5d56d6948f91b5ddb253b04becbd072b2fcbc (commit)
revisions in full, below.
commit 69335b86051b8e27c981e18de4762a97764b512a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Oct 1 10:21:39 2021 -0700
    do not use CMAKE_PROJECT_VERSION for clean version string
diff --git a/CMakeLists.txt b/CMakeLists.txt
index d2e9c26..897e34c 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -131,6 +131,7 @@ if(NOT "${_version_patch_word}" STREQUAL "")
   set(GEOS_VERSION "${GEOS_VERSION}${_version_patch_word}")
   set(GEOS_VERSION_PATCH "${_version_patch}${_version_patch_word}")
 endif()
+set(GEOS_VERSION_NOPATCH "${_version_major}.${_version_minor}.${_version_patch}")
 unset(_version_major)
 unset(_version_minor)
@@ -271,8 +272,8 @@ if(BUILD_SHARED_LIBS)
   target_compile_definitions(geos
     PRIVATE $<IF:$<CXX_COMPILER_ID:MSVC>,GEOS_DLL_EXPORT,DLL_EXPORT>)
-  set_target_properties(geos PROPERTIES VERSION ${CMAKE_PROJECT_VERSION})
-  set_target_properties(geos PROPERTIES SOVERSION ${CMAKE_PROJECT_VERSION})
+  set_target_properties(geos PROPERTIES VERSION ${GEOS_VERSION_NOPATCH})
+  set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION_NOPATCH})
 endif()
Summary of changes:
 CMakeLists.txt | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
