[geos-commits] [SCM] GEOS branch main updated. 4c38944f8b5ef440398ba5f8db14b75489de5d68
Mon Oct 4 09:13:40 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  4c38944f8b5ef440398ba5f8db14b75489de5d68 (commit)
       via  39ab31cba740285700b13357984a31130d18ed85 (commit)
       via  6b46203d77554b7a3a78018091d50cdfd11e4303 (commit)
      from  2696f86ec20ce4100c742b730c87ab401492f1b7 (commit)
revisions in full, below.
commit 4c38944f8b5ef440398ba5f8db14b75489de5d68
Merge: 39ab31c 2696f86
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Oct 4 09:13:33 2021 -0700
    Merge branch 'main' of https://git.osgeo.org/gitea/geos/geos into main
commit 39ab31cba740285700b13357984a31130d18ed85
Date:   Mon Oct 4 09:13:24 2021 -0700
    Content of IsValidTest and IsValidReasonTest were reversed for some reason.
diff --git a/tests/unit/capi/GEOSisValidReasonTest.cpp b/tests/unit/capi/GEOSisValidReasonTest.cpp
index 8166cc5..cf20091 100644
--- a/tests/unit/capi/GEOSisValidReasonTest.cpp
+++ b/tests/unit/capi/GEOSisValidReasonTest.cpp
@@ -9,12 +9,12 @@ namespace tut {
 // Test Group
-struct test_geosisvalid_data : public capitest::utility {};
+struct test_geosisvalidreason_data : public capitest::utility {};
-typedef test_group<test_geosisvalid_data> group;
+typedef test_group<test_geosisvalidreason_data> group;
 typedef group::object object;
-group test_geosisvalid("capi::GEOSisValid");
+group test_geosisvalidreason("capi::GEOSisValidReason");
 template<>
 template<>
@@ -22,9 +22,12 @@ void object::test<1>()
     GEOSGeometry* input = GEOSGeomFromWKT("LINESTRING (1 2, 4 5, 9 -2)");
-    ensure_equals(1, GEOSisValid(input));
+    char* reason = GEOSisValidReason(input);
+    ensure_equals(std::string(reason), "Valid Geometry");
     GEOSGeom_destroy(input);
+    GEOSFree(reason);
 template<>
@@ -33,9 +36,12 @@ void object::test<2>()
     GEOSGeometry* input = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 0 1, 1 1, 0 0))");
-    ensure_equals(0, GEOSisValid(input));
+    ensure_equals(std::string(reason), "Self-intersection[0.5 0.5]");
+    GEOSFree(reason);
diff --git a/tests/unit/capi/GEOSisValidTest.cpp b/tests/unit/capi/GEOSisValidTest.cpp
index cf20091..1580adb 100644
--- a/tests/unit/capi/GEOSisValidTest.cpp
+++ b/tests/unit/capi/GEOSisValidTest.cpp
 // Test Group
-struct test_geosisvalidreason_data : public capitest::utility {};
+struct test_geosisvalid_data : public capitest::utility {};
-typedef test_group<test_geosisvalidreason_data> group;
+typedef test_group<test_geosisvalid_data> group;
-group test_geosisvalidreason("capi::GEOSisValidReason");
+group test_geosisvalid("capi::GEOSisValid");
 template<>
 template<>
@@ -22,12 +22,9 @@ void object::test<1>()
-    char* reason = GEOSisValidReason(input);
-    ensure_equals(std::string(reason), "Valid Geometry");
+    ensure_equals(1, GEOSisValid(input));
-    GEOSFree(reason);
 template<>
@@ -36,14 +33,30 @@ void object::test<2>()
-    ensure_equals(std::string(reason), "Self-intersection[0.5 0.5]");
+    ensure_equals(0, GEOSisValid(input));
-    GEOSFree(reason);
-} // namespace tut
+// Unclosed polygon
+template<>
+template<>
+void object::test<3>()
+    GEOSCoordSequence* shell_seq = GEOSCoordSeq_create(4, 2);
+    double shell_coords[] = {0,0, 0,10, 10,10, 10,0};
+    for (unsigned int i = 0; i < 4; i++) {
+        GEOSCoordSeq_setXY(shell_seq, i, shell_coords[2*i], shell_coords[2*i+1]);
+    GEOSGeometry* shell = GEOSGeom_createLinearRing(shell_seq);
+    ensure(shell != nullptr);
+    GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, nullptr, 0);
+    ensure(polygon != nullptr);
+    char isvalid = GEOSisValid(polygon);
+    ensure_equals(0, isvalid);
+    GEOSGeom_destroy(polygon);
+} // namespace tut
commit 6b46203d77554b7a3a78018091d50cdfd11e4303
Date:   Mon Oct 4 09:12:56 2021 -0700
    Assert a non-null input to IsValidOp
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index df23de5..5f27fbb 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -80,6 +80,7 @@ IsValidOp::logInvalid(int code, const Coordinate* pt)
 bool
 IsValidOp::isValidGeometry(const Geometry* g)
+    assert(g);
     validErr.reset(nullptr);
     // empty geometries are always valid
Summary of changes:
 src/operation/valid/IsValidOp.cpp         |  1 +
 tests/unit/capi/GEOSisValidReasonTest.cpp | 16 ++++++++-----
 tests/unit/capi/GEOSisValidTest.cpp       | 37 +++++++++++++++++++++----------
 3 files changed, 37 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
