[geos-commits] [SCM] GEOS branch 3.9 updated. c5437e903598aaca10fcdacda36bc1b115c50262
git at osgeo.org
git at osgeo.org
Tue Oct 5 13:16:36 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via c5437e903598aaca10fcdacda36bc1b115c50262 (commit)
from 1f727025ec8c19f2d540c902580862ef4c670b11 (commit)
revisions in full, below.
commit c5437e903598aaca10fcdacda36bc1b115c50262
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Oct 5 12:49:36 2021 -0700
Avoid raising double overflow signals in distance calcs
diff --git a/NEWS b/NEWS
index db42c61..b606e21 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ Changes in 3.9.2
- Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
- Fix DiscreteFrechetDistance to use initial points of input lines (#1128, Martin Davis)
- Avoid stack overflow in KdTree::queryNode (Even Roualt)
+ - Avoid raising double overflow signals in distance calcs (Paul Ramsey)
Changes in 3.9.1
diff --git a/include/geos/algorithm/CentralEndpointIntersector.h b/include/geos/algorithm/CentralEndpointIntersector.h
index 4c9145c..e5ca8cd 100644
--- a/include/geos/algorithm/CentralEndpointIntersector.h
+++ b/include/geos/algorithm/CentralEndpointIntersector.h
@@ -140,7 +140,7 @@ private:
findNearestPoint(const geom::Coordinate& p,
const std::vector<geom::Coordinate>& pts) const
- double minDistSq = std::numeric_limits<double>::max();
+ double minDistSq = DoubleInfinity;
geom::Coordinate result = geom::Coordinate::getNull();
for(std::size_t i = 0, n = pts.size(); i < n; ++i) {
double distSq = p.distanceSquared(pts[i]);
diff --git a/src/algorithm/InteriorPointLine.cpp b/src/algorithm/InteriorPointLine.cpp
index 4aa5ac1..3fb5155 100644
--- a/src/algorithm/InteriorPointLine.cpp
+++ b/src/algorithm/InteriorPointLine.cpp
@@ -40,7 +40,7 @@ namespace algorithm { // geos.algorithm
InteriorPointLine::InteriorPointLine(const Geometry* g)
- minDistance = DoubleMax;
+ minDistance = DoubleInfinity;
hasInterior = false;
if (g->getCentroid(centroid)) {
#if GEOS_DEBUG
diff --git a/src/algorithm/InteriorPointPoint.cpp b/src/algorithm/InteriorPointPoint.cpp
index 5d23333..6e52fb5 100644
--- a/src/algorithm/InteriorPointPoint.cpp
+++ b/src/algorithm/InteriorPointPoint.cpp
@@ -33,7 +33,7 @@ namespace algorithm { // geos.algorithm
/*public*/
InteriorPointPoint::InteriorPointPoint(const Geometry* g)
if (! g->getCentroid(centroid)) {
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 2cd1538..0898e56 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -299,7 +299,7 @@ MinimumBoundingCircle::lowestPoint(std::vector<Coordinate>& pts)
Coordinate
MinimumBoundingCircle::pointWitMinAngleWithX(std::vector<Coordinate>& pts, Coordinate& P)
- double minSin = std::numeric_limits<double>::max();
+ double minSin = DoubleInfinity;
Coordinate minAngPt;
minAngPt.setNull();
for(const auto& p : pts) {
@@ -333,7 +333,7 @@ Coordinate
MinimumBoundingCircle::pointWithMinAngleWithSegment(std::vector<Coordinate>& pts, Coordinate& P, Coordinate& Q)
assert(!pts.empty());
- double minAng = std::numeric_limits<double>::max();
+ double minAng = DoubleInfinity;
const Coordinate* minAngPt = &pts[0];
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 9aa73bc..ee2728a 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -285,10 +285,10 @@ MinimumDiameter::getMinimumRectangle()
double dx = minBaseSeg.p1.x - minBaseSeg.p0.x;
double dy = minBaseSeg.p1.y - minBaseSeg.p0.y;
- double minPara = DoubleMax;
- double maxPara = -DoubleMax;
- double minPerp = DoubleMax;
- double maxPerp = -DoubleMax;
+ double minPara = DoubleInfinity;
+ double maxPara = DoubleNegInfinity;
+ double minPerp = DoubleInfinity;
+ double maxPerp = DoubleNegInfinity;
// compute maxima and minima of lines parallel and perpendicular to base segment
std::size_t const n = convexHullPts->getSize();
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 0716766..1b6c19a 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -209,7 +209,7 @@ LineSegment::closestPoints(const LineSegment& line)
std::array<Coordinate, 2> closestPt;
- double minDistance = DoubleMax;
+ double minDistance = DoubleInfinity;
double dist;
Coordinate close00;
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index 82b27d2..bbf7ff0 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -82,20 +82,20 @@ DistanceOp::nearestPoints(const Geometry* g0, const Geometry* g1)
DistanceOp::DistanceOp(const Geometry* g0, const Geometry* g1):
geom{g0, g1},
terminateDistance(0.0),
- minDistance(DoubleMax)
+ minDistance(DoubleInfinity)
DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1):
geom{&g0, &g1},
DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1, double tdist)
geom{&g0, &g1},
terminateDistance(tdist),
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index a71b6f0..11e1b33 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -11,6 +11,7 @@
#include <cstdlib>
#include <memory>
#include <math.h>
+#include <fenv.h>
namespace tut {
@@ -150,5 +151,31 @@ void object::test<3>
GEOSGeom_destroy(g2);
+// distance between boundables should not raise floating point exception
+template<>
+template<>
+void object::test<4>
+ GEOSGeometry* g1 = GEOSGeomFromWKT("LINESTRING (0 0, 1 1)");
+ GEOSGeometry* g2 = GEOSGeomFromWKT("LINESTRING (2 2, 3 3)");
+ // clear all floating point exceptions
+ feclearexcept (FE_ALL_EXCEPT);
+ double d;
+ int status = GEOSDistance(g1, g2, &d);
+ ensure_equals(status, 1);
+ ensure_equals(d, sqrt(2));
+ // check for floating point overflow exceptions
+ int raised = fetestexcept(FE_OVERFLOW);
+ ensure_equals(raised & FE_OVERFLOW, 0);
+ GEOSGeom_destroy(g1);
+ GEOSGeom_destroy(g2);
} // namespace tut
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index c46d39a..852cd35 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -4,6 +4,7 @@
#include <tut/tut.hpp>
// geos
#include <geos_c.h>
+#include <geos/constants.h>
// std
#include <cstdarg>
#include <cstdio>
@@ -129,7 +130,7 @@ void object::test<2>
for(size_t i = 0; i < ngeoms; i++) {
const GEOSGeometry* nearest = GEOSSTRtree_nearest(tree, queryPoints[i]);
const GEOSGeometry* nearestBruteForce = nullptr;
- double nearestBruteForceDistance = std::numeric_limits<double>::max();
+ double nearestBruteForceDistance = geos::DoubleInfinity;
for(size_t j = 0; j < ngeoms; j++) {
double distance;
GEOSDistance(queryPoints[i], geoms[j], &distance);
Summary of changes:
NEWS | 1 +
.../geos/algorithm/CentralEndpointIntersector.h | 2 +-
src/algorithm/InteriorPointLine.cpp | 2 +-
src/algorithm/InteriorPointPoint.cpp | 2 +-
src/algorithm/MinimumBoundingCircle.cpp | 4 ++--
src/algorithm/MinimumDiameter.cpp | 8 +++----
src/geom/LineSegment.cpp | 2 +-
src/operation/distance/DistanceOp.cpp | 6 ++---
tests/unit/capi/GEOSDistanceTest.cpp | 27 ++++++++++++++++++++++
tests/unit/capi/GEOSSTRtreeTest.cpp | 3 ++-
10 files changed, 43 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits
