[geos-commits] [SCM] GEOS branch main updated. 461fe54d22c96a94d361870ca64b1da355cd6e56
git at osgeo.org
git at osgeo.org
Wed Oct 6 09:35:38 PDT 2021
the project "GEOS".
The branch, main has been updated
via 461fe54d22c96a94d361870ca64b1da355cd6e56 (commit)
from f5df3ec15794cbabf0486c681c5ae9d8fe6f47a0 (commit)
revisions in full, below.
commit 461fe54d22c96a94d361870ca64b1da355cd6e56
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Oct 6 09:35:06 2021 -0700
update readme and install
diff --git a/INSTALL b/INSTALL.md
similarity index 81%
rename from INSTALL
rename to INSTALL.md
index c9895a8..589b0d9 100644
--- a/INSTALL
+++ b/INSTALL.md
@@ -19,11 +19,17 @@ from that location:
Setting `CMAKE_BUILD_TYPE` to `Release` is necessary to enable compiler
optimizations.
-Once the `cmake` tool has run, GEOS can be built by running `make` and
-installed by running `make install`.
+Once the `cmake` tool has run, GEOS can be built by
-The entire test suite can be run using `make check`.
-Alternatively, the `ctest` command can be used, which provides more control over test execution.
+* running `make` and installed by running `make install`, or
+* running `cmake --build .` and `cmake --build . --target install`
+The entire test suite can be run by
+* using `make check`, or
+* using `ctest --output-on-failure .`
+The `ctest` command can be used to control which tests are run.
For example, `ctest -R unit-capi -j2` uses a regular expression to run all tests
associated with the C API, using two processes in parallel.
A list of available tests can be obtained using `ctest -N`.
@@ -62,14 +68,3 @@ cmake -S . -B _build_vs2019x32 -G "Visual Studio 16 2019" -A x32 -DCMAKE_GENERAT
cmake --build _build_vs2019x32 --config Release -j 16 --verbose
-#### Test using CMake
-cd <build directory>
-ctest --show-only
-ctest
-ctest --output-on-failure
-ctest -V
-ctest -VV
diff --git a/README.md b/README.md
index 1a7322a..6155355 100644
--- a/README.md
+++ b/README.md
@@ -114,7 +114,7 @@ API documentation can be generated using Doxygen. Documentation is not included
in the default build. To build the documentation, run:
cmake -DBUILD_DOCUMENTATION=YES
- make docs
+ cmake --build . --target docs
## Style
Summary of changes:
INSTALL => INSTALL.md | 25 ++++++++++---------------
README.md | 2 +-
2 files changed, 11 insertions(+), 16 deletions(-)
rename INSTALL => INSTALL.md (81%)
hooks/post-receive
More information about the geos-commits
