[geos-commits] [SCM] GEOS branch main updated. 4a7fd4c5c726441ecf47be31f1654a803eac52a2
Mon Oct 18 15:08:03 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  4a7fd4c5c726441ecf47be31f1654a803eac52a2 (commit)
       via  f9a224287036b8dac449b2775e01b2ac2a3553f3 (commit)
      from  655aacfea244e9ab0c57d96312522a4b5ac636af (commit)
revisions in full, below.
commit 4a7fd4c5c726441ecf47be31f1654a803eac52a2
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 19 00:07:09 2021 +0200
    Do not terminate() upon receiving non-numeric second positional arg
    References #1126
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 483b3a3ca..c611dbe46 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -125,6 +125,10 @@ int main(int argc, char** argv) {
         auto& v = result["opArgs"].as<std::vector<std::string>>();
         if (v.size() >= 1) {
+            if ( v.size() > 1 )
+                std::cerr << "positional arguments after the second one are discarded" << std::endl;
             auto val = v[0];
              * To get around cmdline parset limitation for parsing neg numbers,
@@ -133,7 +137,15 @@ int main(int argc, char** argv) {
             if (startsWith(val, "N")) {
                 val = val.substr(1, val.size()-1);
-            cmdArgs.opArg1 = std::stod(val);
+            try {
+                cmdArgs.opArg1 = std::stod(val);
+            } catch (const std::invalid_argument&) {
+                std::cerr << "Invalid positional argument '" << val << "' (expected number)" << std::endl;
+                exit(1);
+            } catch (const std::out_of_range&) {
+                std::cerr << "Out of range positional argument '" << val << "' (expected double)" << std::endl;
+                exit(1);
commit f9a224287036b8dac449b2775e01b2ac2a3553f3
Date:   Mon Oct 18 23:40:01 2021 +0200
    Add --enable-debug support in the configure wrapper
diff --git a/configure b/configure
index 811a09b94..f39e9edac 100755
--- a/configure
+++ b/configure
@@ -8,12 +8,12 @@ which cmake > /dev/null 2>&1 || {
 srcdir=$(dirname $0)
 usage() {
-  echo "$0 [--prefix=<prefix>] [--help]"
+  echo "$0 [--prefix=<prefix>] [--enable-debug] [--help]"
 cmd=cmake
-options=$(getopt -l "help,prefix:" "" "$@")
+options=$(getopt -l "help,enable-debug,prefix:" "" "$@")
 #echo XXXX ${options}
 eval set -- "$options"
@@ -23,6 +23,9 @@ while true; do
       shift
       cmd="${cmd} -DCMAKE_INSTALL_PREFIX:PATH=$1"
+    --enable-debug)
+      cmd="${cmd} -DCMAKE_BUILD_TYPE=Debug"
     --help)
       usage
       exit
Summary of changes:
 configure              |  7 +++++--
 util/geosop/GeosOp.cpp | 14 +++++++++++++-
 2 files changed, 18 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
