[geos-commits] [SCM] GEOS branch main updated. 5e44ec3f6d46693a95465e230726220938752a0d
git at osgeo.org
git at osgeo.org
Fri Oct 29 14:43:52 PDT 2021
the project "GEOS".
The branch, main has been updated
via 5e44ec3f6d46693a95465e230726220938752a0d (commit)
from 2b426f7118b5d0a8a1e4492d8ee75b4cc03889ad (commit)
revisions in full, below.
commit 5e44ec3f6d46693a95465e230726220938752a0d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 29 14:33:35 2021 -0700
Check for empty Sequence when collapsing linear ring. References #1135
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index faa7f8f3f..19c4bd5f0 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -202,7 +202,7 @@ GeometryTransformer::transformLinearRing(
CoordinateSequence::Ptr seq(transformCoordinates(
geom->getCoordinatesRO(), geom));
- auto seqSize = seq->size();
+ std::size_t seqSize = seq ? seq->size() : 0;
// ensure a valid LinearRing
if(seqSize > 0 && seqSize < 4 && ! preserveType) {
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 06f4148fa..4864d02a0 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -158,5 +158,16 @@ void object::test<9> ()
ensure_geometry_equals(geom2_, "LINESTRING (0 0, 0 0)");
+// Collapse a linearRing / Trac #1135
+template<>
+template<>
+void object::test<10> ()
+ geom1_ = fromWKT("LINEARRING (0 0, 0.1 0, 0.1 0.1, 0 0.1, 0 0)");
+ geom2_ = GEOSGeom_setPrecision(geom1_, 1.0, 0);
+ ensure_geometry_equals(geom2_, "LINEARRING EMPTY");
} // namespace tut
Summary of changes:
src/geom/util/GeometryTransformer.cpp | 2 +-
tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 11 +++++++++++
2 files changed, 12 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
