[geos-commits] [SCM] GEOS branch 3.9 updated. b14c2287a1b0e0242de0308bf60f8c03f2bca0e6
git at osgeo.org
git at osgeo.org
Fri Oct 29 14:57:20 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via b14c2287a1b0e0242de0308bf60f8c03f2bca0e6 (commit)
from 17658cbe9c48d6ddc8856201944ee6e67b701a1a (commit)
revisions in full, below.
commit b14c2287a1b0e0242de0308bf60f8c03f2bca0e6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 29 14:33:35 2021 -0700
Fix crasher reducing LinearRing precision, references #1135
diff --git a/NEWS b/NEWS
index df5521027..44d849ee9 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ Changes in 3.9.2
- Avoid stack overflow in KdTree::queryNode (Even Roualt)
- Avoid raising double overflow signals in distance calcs (Paul Ramsey)
- Fix performance issue in buffer building (Paul Ramsey)
+ - Fix crash when precision reducing LinearRing (#1135, Paul Ramsey)
Changes in 3.9.1
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 38efefd42..3167f006e 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -198,7 +198,7 @@ GeometryTransformer::transformLinearRing(
CoordinateSequence::Ptr seq(transformCoordinates(
geom->getCoordinatesRO(), geom));
- auto seqSize = seq->size();
+ std::size_t seqSize = seq ? seq->size() : 0;
// ensure a valid LinearRing
if(seqSize > 0 && seqSize < 4 && ! preserveType) {
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 13000d3d9..ef4d07959 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -163,5 +163,56 @@ void object::test<5>
ensure_equals(toWKT(geom3_), "LINESTRING (0 0, 0 0)");
+// Retain (or not) collapsed elements
+template<>
+template<>
+void object::test<6> ()
+ geom1_ = fromWKT("LINESTRING (0 0, 0.1 0.1)");
+ geom2_ = GEOSGeom_setPrecision(geom1_, 1.0, 0);
+ ensure_geometry_equals(geom2_, "LINESTRING EMPTY");
+template<>
+template<>
+void object::test<7> ()
+ geom2_ = GEOSGeom_setPrecision(geom1_, 1.0, GEOS_PREC_NO_TOPO);
+ ensure_geometry_equals(geom2_, "LINESTRING (0 0, 0 0)");
+template<>
+template<>
+void object::test<8> ()
+ geom2_ = GEOSGeom_setPrecision(geom1_, 1.0, GEOS_PREC_KEEP_COLLAPSED);
+template<>
+template<>
+void object::test<9> ()
+ geom2_ = GEOSGeom_setPrecision(geom1_, 1.0, GEOS_PREC_KEEP_COLLAPSED | GEOS_PREC_NO_TOPO);
+// Collapse a linearRing / Trac #1135
+template<>
+template<>
+void object::test<10> ()
+ geom1_ = fromWKT("LINEARRING (0 0, 0.1 0, 0.1 0.1, 0 0.1, 0 0)");
+ ensure_geometry_equals(geom2_, "LINEARRING EMPTY");
} // namespace tut
Summary of changes:
NEWS | 1 +
src/geom/util/GeometryTransformer.cpp | 2 +-
tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 51 +++++++++++++++++++++++++++
3 files changed, 53 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
