[geos-commits] [SCM] GEOS branch main updated. 756021b91ce734f471cea8a7d007340816526273
git at osgeo.org
git at osgeo.org
Sat Oct 30 14:54:14 PDT 2021
the project "GEOS".
The branch, main has been updated
via 756021b91ce734f471cea8a7d007340816526273 (commit)
via f63cfeffce584945c2e1827d342cc884a732b084 (commit)
from 07a27b6173daf842948465faedb540a1258e3490 (commit)
revisions in full, below.
commit 756021b91ce734f471cea8a7d007340816526273
Merge: 07a27b617 f63cfeffc
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Oct 30 14:54:09 2021 -0700
Merge branch 'main-cmath' into main
commit f63cfeffce584945c2e1827d342cc884a732b084
Date: Sat Oct 30 14:32:08 2021 -0700
Use cmath and std::sqrt exclusively
diff --git a/include/geos/triangulate/quadedge/Vertex.h b/include/geos/triangulate/quadedge/Vertex.h
index a34f63eeb..5e6d19f78 100644
--- a/include/geos/triangulate/quadedge/Vertex.h
+++ b/include/geos/triangulate/quadedge/Vertex.h
@@ -19,7 +19,7 @@
#ifndef GEOS_TRIANGULATE_QUADEDGE_VERTEX_H
#define GEOS_TRIANGULATE_QUADEDGE_VERTEX_H
-#include <math.h>
+#include <cmath>
#include <memory>
#include <cstring>
@@ -234,8 +234,8 @@ private:
inline double
distance(const Vertex& v1, const Vertex& v2)
- return sqrt(pow(v2.getX() - v1.getX(), 2.0)
- + pow(v2.getY() - v1.getY(), 2.0));
+ return std::sqrt(pow(v2.getX() - v1.getX(), 2.0) +
diff --git a/include/geos/util.h b/include/geos/util.h
index fd4f1ee46..8e1d662d9 100644
--- a/include/geos/util.h
+++ b/include/geos/util.h
@@ -21,15 +21,10 @@
#ifndef GEOS_UTIL_H
#define GEOS_UTIL_H
-//#include <geos/util/AssertionFailedException.h>
#include <geos/util/GEOSException.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/util/TopologyException.h>
-//#include <geos/util/UnsupportedOperationException.h>
-//#include <geos/util/CoordinateArrayFilter.h>
-//#include <geos/util/UniqueCoordinateArrayFilter.h>
#include <geos/util/GeometricShapeFactory.h>
-//#include <geos/util/math.h>
#include <memory>
#include <type_traits>
diff --git a/src/algorithm/Distance.cpp b/src/algorithm/Distance.cpp
index a8c6e6cbb..2c8503601 100644
--- a/src/algorithm/Distance.cpp
+++ b/src/algorithm/Distance.cpp
@@ -75,7 +75,7 @@ Distance::pointToSegment(const geom::Coordinate& p,
double s = ((A.y - p.y) * (B.x - A.x) - (A.x - p.x) * (B.y - A.y)) /
((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y));
- return fabs(s) * sqrt(((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y)));
+ return std::fabs(s) * std::sqrt(((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y)));
/*public static*/
@@ -97,7 +97,7 @@ Distance::pointToLinePerpendicular(const geom::Coordinate& p,
/*public static*/
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 154de20b4..10c729b9e 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -229,7 +229,7 @@ LineIntersector::interpolateZ(const Coordinate& p,
xoff = (p.x - p1.x);
yoff = (p.y - p1.y);
double pdist = (xoff * xoff + yoff * yoff);
- double fract = sqrt(pdist / seglen);
+ double fract = std::sqrt(pdist / seglen);
double zoff = zgap * fract;
//double interpolated = p1.z < p2.z ? p1.z+zoff : p1.z-zoff;
double interpolated = p1.z + zoff;
@@ -600,7 +600,7 @@ LineIntersector::zInterpolate(const Coordinate& p, const Coordinate& p1, const C
double xoff = (p.x - p1.x);
double yoff = (p.y - p1.y);
double plen = (xoff * xoff + yoff * yoff);
- double frac = sqrt(plen / seglen);
+ double frac = std::sqrt(plen / seglen);
double zoff = dz * frac;
double zInterpolated = p1z + zoff;
#if GEOS_DEBUG
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 5506b7989..87b7acc33 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -31,7 +31,7 @@
#include <geos/geom/Triangle.h>
-#include <math.h> // sqrt
+#include <cmath> // sqrt
#include <memory> // for unique_ptr
#include <typeinfo>
#include <vector>
@@ -316,7 +316,7 @@ MinimumBoundingCircle::pointWitMinAngleWithX(std::vector<Coordinate>& pts, Coord
if(dy < 0) {
dy = -dy;
- double len = sqrt(dx * dx + dy * dy);
+ double len = std::sqrt(dx * dx + dy * dy);
double sin = dy / len;
if(sin < minSin) {
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 0d17fdd9f..ee475cd7a 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -279,7 +279,7 @@ LineSegment::pointAlongOffset(double segmentLengthFraction,
double dx = p1.x - p0.x;
double dy = p1.y - p0.y;
double ux = 0.0;
double uy = 0.0;
diff --git a/src/geom/util/Densifier.cpp b/src/geom/util/Densifier.cpp
index 15f77fd0a..769c90094 100644
--- a/src/geom/util/Densifier.cpp
+++ b/src/geom/util/Densifier.cpp
@@ -18,7 +18,7 @@
-#include <math.h>
+#include <cmath>
#include <geos/geom/util/Densifier.h>
#include <geos/geom/CoordinateSequenceFactory.h>
diff --git a/src/triangulate/VoronoiDiagramBuilder.cpp b/src/triangulate/VoronoiDiagramBuilder.cpp
index 5adfbd623..0005700a5 100644
--- a/src/triangulate/VoronoiDiagramBuilder.cpp
+++ b/src/triangulate/VoronoiDiagramBuilder.cpp
@@ -19,7 +19,7 @@
#include <geos/triangulate/VoronoiDiagramBuilder.h>
#include <algorithm>
-#include <math.h>
+#include <cmath>
#include <vector>
#include <iostream>
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index fceb19977..84f44e259 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -11,7 +11,7 @@
#include <cstdlib>
#include <fenv.h>
#include <memory>
-#include <math.h>
+#include <cmath>
#include "capi_test_utils.h"
@@ -134,7 +134,7 @@ void object::test<4>
int status = GEOSDistance(g1, g2, &d);
ensure_equals(status, 1);
- ensure_equals(d, sqrt(2));
+ ensure_equals(d, std::sqrt(2));
// check for floating point overflow exceptions
int raised = fetestexcept(FE_OVERFLOW);
@@ -160,7 +160,7 @@ void object::test<5>
- // ensure_equals(d, sqrt(2));
+ // ensure_equals(d, std::sqrt(2));
diff --git a/tests/unit/capi/GEOSFrechetDistanceTest.cpp b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
index b40b18c20..a3b438c0b 100644
--- a/tests/unit/capi/GEOSFrechetDistanceTest.cpp
+++ b/tests/unit/capi/GEOSFrechetDistanceTest.cpp
@@ -9,7 +9,7 @@
#include <cstdio>
#include <cstdlib>
#include <memory>
-#include <math.h>
+#include <cmath>
diff --git a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
index 8a530819c..b56888c8a 100644
--- a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
+++ b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
@@ -9,7 +9,7 @@
#include <cstdio>
#include <cstdlib>
#include <memory>
-#include <math.h>
+#include <cmath>
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index 3a5be832a..8540a244a 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -38,7 +38,7 @@ INTPOINT_dist(const void* a, const void* b, double* distance, void*)
int dx = p2->x - p1->x;
int dy = p2->y - p1->y;
- *distance = sqrt(static_cast<double>(dx * dx) + dy * dy);
+ *distance = std::sqrt(static_cast<double>(dx * dx) + dy * dy);
return 1;
Summary of changes:
include/geos/triangulate/quadedge/Vertex.h | 6 +++---
include/geos/util.h | 5 -----
src/algorithm/Distance.cpp | 4 ++--
src/algorithm/LineIntersector.cpp | 4 ++--
src/algorithm/MinimumBoundingCircle.cpp | 4 ++--
src/geom/LineSegment.cpp | 2 +-
src/geom/util/Densifier.cpp | 2 +-
src/triangulate/VoronoiDiagramBuilder.cpp | 2 +-
tests/unit/capi/GEOSDistanceTest.cpp | 6 +++---
tests/unit/capi/GEOSFrechetDistanceTest.cpp | 2 +-
tests/unit/capi/GEOSHausdorffDistanceTest.cpp | 2 +-
tests/unit/capi/GEOSSTRtreeTest.cpp | 2 +-
12 files changed, 18 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits
