[geos-commits] [SCM] GEOS branch 3.10 updated. 0543d5b59dd0141bc13cf714dcdcf3c90ce19344
git at osgeo.org
git at osgeo.org
Sun Oct 31 16:35:40 PDT 2021
the project "GEOS".
The branch, 3.10 has been updated
via 0543d5b59dd0141bc13cf714dcdcf3c90ce19344 (commit)
from c25b324da01040ed681b59d4af6009bfbc20866e (commit)
revisions in full, below.
commit 0543d5b59dd0141bc13cf714dcdcf3c90ce19344
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sun Oct 31 16:35:36 2021 -0700
Update azure pipelines to latest versions on main
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
index 6eb4fc06e..c50955971 100644
--- a/.azure-pipelines.yml
+++ b/.azure-pipelines.yml
@@ -29,64 +29,114 @@ stages:
jobs:
- job: 'Linux'
- pool:
- vmImage: 'ubuntu-18.04'
strategy:
matrix:
+ GCC 11:
+ CXXSTD: 11, 20
+ CXX: g++-11
+ PACKAGES: g++-11
+ VM_IMAGE: ubuntu-20.04
+ VM_NAME: focal
+ GCC 10:
+ CXXSTD: 11, 17
+ CXX: g++-10
+ PACKAGES: g++-10
+ VM_NAME: focal
+ GCC 9:
+ CXXSTD: 11, 14
+ CXX: g++-9
+ PACKAGES: g++-9
+ VM_NAME: focal
GCC 8:
- CXXSTD: 11, 14, 17, 20
+ CXXSTD: 11
CXX: g++-8
PACKAGES: g++-8
+ VM_NAME: focal
GCC 7:
+ CXXSTD: 11
CXX: g++-7
PACKAGES: g++-7
+ VM_NAME: focal
GCC 6:
- CXXSTD: 11, 14
+ CXXSTD: 11
CXX: g++-6
PACKAGES: g++-6
+ VM_IMAGE: ubuntu-18.04
+ VM_NAME: focal
GCC 5:
CXXSTD: 11
CXX: g++-5
PACKAGES: g++-5
- # GCC 4.9:
- # CXXSTD: 11
- # CXX: g++-4.9
- # PACKAGES: g++-4.9
+ VM_NAME: focal
GCC 4.8:
CXXSTD: 11
CXX: g++-4.8
PACKAGES: g++-4.8
+ VM_NAME: focal
+ Clang 12:
+ CXXSTD: 11, 20
+ CXX: clang++-12
+ PACKAGES: clang-12
+ LLVM_REPO: llvm-toolchain-focal-12
+ VM_NAME: focal
+ Clang 11:
+ CXXSTD: 11, 17
+ CXX: clang++-11
+ PACKAGES: clang-11
+ LLVM_REPO: llvm-toolchain-focal-11
+ VM_NAME: focal
Clang 10:
+ CXXSTD: 11, 14
CXX: clang++-10
PACKAGES: clang-10
- LLVM_REPO: llvm-toolchain-bionic-10
+ LLVM_REPO: llvm-toolchain-focal-10
+ VM_NAME: focal
Clang 9:
+ CXXSTD: 11
CXX: clang++-9
PACKAGES: clang-9
- LLVM_REPO: llvm-toolchain-bionic-9
+ LLVM_REPO: llvm-toolchain-focal-9
+ VM_NAME: focal
Clang 8:
+ CXXSTD: 11
CXX: clang++-8
PACKAGES: clang-8
LLVM_REPO: llvm-toolchain-bionic-8
+ VM_NAME: bionic
Clang 7:
- CXXSTD: 11, 14
+ CXXSTD: 11
CXX: clang++-7
PACKAGES: clang-7
LLVM_REPO: llvm-toolchain-bionic-7
- Clang 6:
- CXXSTD: 11, 14
- CXX: clang++-6.0
- PACKAGES: clang-6.0
- LLVM_REPO: llvm-toolchain-bionic-6.0
- Clang 5:
- CXXSTD: 11, 14
- PACKAGES: clang-5.0
- CXX: clang++-5.0
- LLVM_REPO: llvm-toolchain-bionic-5.0
+ VM_NAME: bionic
+ # Clang 6:
+ # CXXSTD: 11
+ # CXX: clang++-6.0
+ # PACKAGES: clang-6.0
+ # LLVM_REPO: llvm-toolchain-bionic-6.0
+ # VM_IMAGE: ubuntu-18.04
+ # VM_NAME: bionic
+ # Clang 5:
+ # CXXSTD: 11
+ # PACKAGES: clang-5.0
+ # CXX: clang++-5.0
+ # LLVM_REPO: llvm-toolchain-bionic-5.0
+ # VM_NAME: bionic
+ pool:
+ vmImage: $(VM_IMAGE)
steps:
- script: |
set -e
@@ -94,7 +144,7 @@ stages:
sudo -E apt-add-repository -y "ppa:ubuntu-toolchain-r/test"
if test -n "${LLVM_REPO}" ; then
wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
- sudo -E apt-add-repository "deb http://apt.llvm.org/bionic/ ${LLVM_REPO} main"
+ sudo -E apt-add-repository "deb http://apt.llvm.org/${VM_NAME}/ ${LLVM_REPO} main"
fi
sudo -E apt-get update
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cmake ${PACKAGES}
@@ -129,34 +179,28 @@ stages:
ctest -V --output-on-failure -C $BUILD_TYPE
displayName: 'Build C++17'
condition: contains(variables['CXXSTD'], '17')
- # - script: |
- # set -e
- # mkdir build.cxx20
- # cd build.cxx20
- # cmake --version
- # cmake -DCMAKE_CXX_STANDARD=20 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
- # cmake --build . --config $BUILD_TYPE
- # ctest -V --output-on-failure -C $BUILD_TYPE
- # displayName: 'Build C++20'
- # condition: contains(variables['CXXSTD'], '20')
+ - script: |
+ set -e
+ mkdir build.cxx20
+ cd build.cxx20
+ cmake --version
+ cmake -DCMAKE_CXX_STANDARD=20 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ cmake --build . --config $BUILD_TYPE
+ ctest -V --output-on-failure -C $BUILD_TYPE
+ displayName: 'Build C++20'
+ condition: contains(variables['CXXSTD'], '20')
- job: 'Windows'
strategy:
matrix:
- #Disabled until MSVC 16.4 is released
- #(see https://developercommunity.visualstudio.com/content/problem/726778/this-snippet-compiles-totally-fine-on-godbolt-msvc.html?childToView=744771#comment-744771)
- VS 2019 C++20 Strict:
+ # VS 2022 C++20:
+ # TOOLSET: msvc-14.3
+ # CXXSTD: 20
+ # VM_IMAGE: 'windows-2022'
+ VS 2019 C++20:
TOOLSET: msvc-14.2
CXXSTD: 20
VM_IMAGE: 'windows-2019'
- VS 2017 C++17:
- TOOLSET: msvc-14.1
- CXXSTD: 17
- VM_IMAGE: 'vs2017-win2016'
- VS 2017 C++14:
- CXXSTD: 14 # default
pool:
steps:
@@ -184,19 +228,22 @@ stages:
- job: 'macOS'
pool:
- vmImage: 'macOS-10.14'
+ vmImage: 'macOS-10.15'
strategy:
matrix:
- Xcode 10.1:
+ # https://github.com/actions/virtual-environments/blob/main/images/macos/macos-10.15-Readme.md#xcode
+ Xcode 12.4:
TOOLSET: clang
- CXXSTD: 14, 17
- XCODE_APP: /Applications/Xcode_10.1.app
- Xcode 10.0:
- CXXSTD: 14, 17
- XCODE_APP: /Applications/Xcode_10.app
- Xcode 9.4.1:
- XCODE_APP: /Applications/Xcode_9.4.1.app
+ CXXSTD: 11, 14, 20
+ XCODE_APP: /Applications/Xcode_12.4.app
+ Xcode 11.7:
+ TOOLSET: clang
+ CXXSTD: 11, 17
+ XCODE_APP: /Applications/Xcode_11.7.app
+ Xcode 10.3:
+ TOOLSET: clang
+ CXXSTD: 11
+ XCODE_APP: /Applications/Xcode_10.3.app
steps:
- script: |
set -e
Summary of changes:
.azure-pipelines.yml | 161 +++++++++++++++++++++++++++++++++------------------
1 file changed, 104 insertions(+), 57 deletions(-)
hooks/post-receive
More information about the geos-commits
