[geos-commits] [SCM] GEOS branch main updated. c355bb2a766d60581d7fe8ecd7e0a3fe186cc48f
git at osgeo.org
git at osgeo.org
Thu Sep 16 13:26:59 PDT 2021
the project "GEOS".
The branch, main has been updated
via c355bb2a766d60581d7fe8ecd7e0a3fe186cc48f (commit)
from 921f88d1e829f8114c2ff1ccd4fa7858960e880f (commit)
revisions in full, below.
commit c355bb2a766d60581d7fe8ecd7e0a3fe186cc48f
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Sep 16 13:26:55 2021 -0700
Improve geosop function descriptions
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index aec9a49..d5984df 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -76,48 +76,52 @@ PreparedGeometryCache prepGeomCache;
void
GeomFunction::init()
- add("area",
+ add("area", Result::typeDouble,
[](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
(void) geomB; (void)d; // prevent unused variable warning
return new Result( geom->getArea() );
- add("boundary",
+ add("boundary", Result::typeGeometry,
return new Result( geom->getBoundary() );
- add("buffer", "computes the buffer of geometry A to a distance", 1, 1,
+ add("buffer", 1, 1, Result::typeGeometry,
+ "computes the buffer of geometry by a distance",
(void) geomB; // prevent unused variable warning
return new Result( geom->buffer( d ) );
- add("centroid",
+ add("centroid", Result::typeGeometry,
return new Result( geom->getCentroid() );
- add("copy",
+ add("copy", Result::typeGeometry,
return new Result( geom->clone() );
- add("convexHull",
+ add("convexHull", Result::typeGeometry,
return new Result( geom->convexHull() );
- add("contains", "tests if geometry A contains geometry B", 2, 0,
+ add("contains", 2, 0, Result::typeBool,
+ "tests if geometry A contains geometry B",
return new Result( geom->contains( geomB.get() ) );
- add("covers", "tests if geometry A covers geometry B", 2, 0,
+ add("covers", 2, 0, Result::typeBool,
+ "tests if geometry A covers geometry B",
return new Result( geom->covers( geomB.get() ) );
- add("densify", "densifies geometry A to a distance ", 1, 1,
+ add("densify", 1, 1, Result::typeGeometry,
+ "densifies geometry to a distance ",
(void)geomB; // prevent unused variable warning
geos::geom::util::Densifier densifier( geom.get() );
@@ -125,49 +129,55 @@ GeomFunction::init()
return new Result( densifier.getResultGeometry() );
- add("distance", "computes distance between geometry A and B", 2, 0,
+ add("distance", 2, 0, Result::typeDouble,
+ "computes distance between geometry A and B",
return new Result( geom->distance( geomB.get() ) );
- add("envelope",
+ add("envelope", Result::typeGeometry,
- add("interiorPoint",
+ add("interiorPoint", Result::typeGeometry,
return new Result( geom->getInteriorPoint() );
- add("intersects", "tests if geometry A and B intersect", 2, 0,
+ add("intersects", 2, 0, Result::typeBool,
+ "tests if geometry A and B intersect",
return new Result( geom->intersects( geomB.get() ) );
- add("isEmpty", "tests if geometry A is empty", 1, 0,
+ add("isEmpty", 1, 0, Result::typeBool,
+ "tests if geometry is empty",
return new Result( geom->isEmpty() );
- add("isSimple", "tests if geometry A is simple", 1, 0,
+ add("isSimple", 1, 0, Result::typeBool,
+ "tests if geometry is simple",
return new Result( geom->isSimple() );
- add("isValid", "tests if geometry A is valid", 1, 0,
+ add("isValid", 1, 0, Result::typeBool,
+ "tests if geometry is valid",
return new Result( geom->isValid() );
- add("largestEmptyCircle", "computes radius of largest empty circle of Geometry A up to a distance tolerance", 1, 1,
+ add("largestEmptyCircle", 1, 1, Result::typeGeometry,
+ "computes radius line of largest empty circle of geometry up to a distance tolerance",
geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), d );
@@ -175,26 +185,27 @@ GeomFunction::init()
return new Result( std::move(res) );
- add("length",
+ add("length", Result::typeDouble,
return new Result( geom->getLength() );
- add("makeValid",
+ add("makeValid", Result::typeGeometry,
return new Result( geos::operation::valid::MakeValid().build( geom.get() ) );
- add("maxInscribedCircle", "computes maximum inscribed circle radius of Polygon A up to a distance tolerance", 1, 1,
+ add("maxInscribedCircle", 1, 1, Result::typeGeometry,
+ "computes maximum inscribed circle radius of Polygon up to a distance tolerance",
geos::algorithm::construct::MaximumInscribedCircle mc( geom.get(), d );
std::unique_ptr<Geometry> res = mc.getRadiusLine();
- add("minBoundingCircle",
+ add("minBoundingCircle", Result::typeGeometry,
geos::algorithm::MinimumBoundingCircle mc( geom.get() );
@@ -202,7 +213,8 @@ GeomFunction::init()
- add("nearestPoints", "computes a line containing the nearest points of geometry A and B", 2, 0,
+ add("nearestPoints", 2, 0, Result::typeGeometry,
+ "computes a line containing the nearest points of geometry A and B",
std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
@@ -210,7 +222,8 @@ GeomFunction::init()
auto res = factory->createLineString( std::move(cs) );
- add("normalize", "normalizes geometry A", 1, 0,
+ add("normalize", 1, 0, Result::typeGeometry,
+ "normalizes geometry",
auto res = geom->clone();
@@ -218,7 +231,8 @@ GeomFunction::init()
- add("lineMerge", "merges the lines of geometry A", 1, 0,
+ add("lineMerge", 1, 0, Result::typeGeometry,
+ "merges the lines of geometry",
geos::operation::linemerge::LineMerger lmrgr;
@@ -233,7 +247,8 @@ GeomFunction::init()
return new Result( std::move(geoms) ) ;
- add("delaunay", "computes the Delaunay Triangulation of geometry A vertices", 1, 0,
+ add("delaunay", 1, 0, Result::typeGeometry,
+ "computes the Delaunay Triangulation of geometry vertices",
geos::triangulate::DelaunayTriangulationBuilder builder;
@@ -249,7 +264,8 @@ GeomFunction::init()
- add("voronoi", "computes the Voronoi Diagram of geometry A vertices", 1, 0,
+ add("voronoi", 1, 0, Result::typeGeometry,
+ "computes the Voronoi Diagram of geometry vertices",
geos::triangulate::VoronoiDiagramBuilder builder;
@@ -265,7 +281,7 @@ GeomFunction::init()
- add("polygonize",
+ add("polygonize", Result::typeGeometry,
geos::operation::polygonize::Polygonizer p;
@@ -279,62 +295,73 @@ GeomFunction::init()
- add("reducePrecision", "reduces precision of geometry to a precision scale factor", 1, 1,
+ add("reducePrecision", 1, 1, Result::typeGeometry,
+ "reduces precision of geometry to a precision scale factor",
PrecisionModel pm(d);
return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
- add("relate", "computes DE-9IM matrix for geometry A and B", 2, 0,
+ add("relate", 2, 0, Result::typeString,
+ "computes DE-9IM matrix for geometry A and B",
std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
return new Result( im->toString() );
- add("reverse", "reverses geometry A", 1, 0,
+ add("reverse", 1, 0, Result::typeGeometry,
+ "reverses geometry",
return new Result( geom->reverse() );
- add("simplifyDP", "simplifies geometry A using Douglas-Peucker with a distance tolerance", 1, 1,
+ add("simplifyDP", 1, 1, Result::typeGeometry,
+ "simplifies geometry using Douglas-Peucker with a distance tolerance",
return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
- add("simplifyTP", "simplifies geometry A using Douglas-Peucker with a distance tolerance, preserving topology", 1, 1,
+ add("simplifyTP", 1, 1, Result::typeGeometry,
+ "simplifies geometry using Douglas-Peucker with a distance tolerance, preserving topology",
return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
- add("containsPrep", "tests if geometry A contains geometry B, using PreparedGeometry", 2, 0,
+ add("containsPrep", 2, 0, Result::typeBool,
+ "tests if geometry A contains geometry B, using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
- add("containsProperlyPrep", "tests if geometry A properly contains geometry B using PreparedGeometry", 2, 0,
+ add("containsProperlyPrep", 2, 0, Result::typeBool,
+ "tests if geometry A properly contains geometry B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
- add("coversPrep", "tests if geometry A covers geometry B using PreparedGeometry", 2, 0,
+ add("coversPrep", 2, 0, Result::typeBool,
+ "tests if geometry A covers geometry B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
- add("intersectsPrep", "tests if geometry A intersects B using PreparedGeometry", 2, 0,
+ add("intersectsPrep", 2, 0, Result::typeBool,
+ "tests if geometry A intersects B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
- add("distancePrep", "computes distance between geometry A and B using PreparedGeometry", 2, 0,
+ add("distancePrep", 2, 0, Result::typeDouble,
+ "computes distance between geometry A and B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
- add("nearestPointsPrep", "computes a line containing the nearest points of geometry A and B using PreparedGeometry", 2, 0,
+ add("nearestPointsPrep", 2, 0, Result::typeGeometry,
+ "computes a line containing the nearest points of geometry A and B using PreparedGeometry",
auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
@@ -345,54 +372,63 @@ GeomFunction::init()
- add("difference", "computes difference of geometry A from B", 2, 0,
+ add("difference", 2, 0, Result::typeGeometry,
+ "computes difference of geometry A from B",
return new Result( geom->difference( geomB.get() ) );
- add("intersection", "computes intersection of geometry A and B", 2, 0,
+ add("intersection", 2, 0, Result::typeGeometry,
+ "computes intersection of geometry A and B",
return new Result( geom->intersection( geomB.get() ) );
- add("symDifference", "computes symmetric difference of geometry A and B", 2, 0,
+ add("symDifference", 2, 0, Result::typeGeometry,
+ "computes symmetric difference of geometry A and B",
return new Result( geom->symDifference( geomB.get() ) );
- add("unaryUnion",
+ add("unaryUnion", Result::typeGeometry,
(void)geomB; (void)d; // prevent unused variable warning
return new Result( geom->Union() );
- add("union", "computes union of geometry A and B", 2, 0,
+ add("union", 2, 0, Result::typeGeometry,
+ "computes union of geometry A and B",
return new Result( geom->Union( geomB.get() ) );
- add("differenceSR", "computes difference of geometry A from B, snap-rounding to a precision scale factor", 2, 1,
+ add("differenceSR", 2, 1, Result::typeGeometry,
+ "computes difference of geometry A from B, snap-rounding to a precision scale factor",
geos::geom::PrecisionModel pm(d);
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::DIFFERENCE, &pm) );
- add("intersectionSR", "computes intersection of geometry A and B, snap-rounding to a precision scale factor", 2, 1,
+ add("intersectionSR", 2, 1, Result::typeGeometry,
+ "computes intersection of geometry A and B, snap-rounding to a precision scale factor",
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::INTERSECTION, &pm) );
- add("symDifferenceSR", "computes symmetric difference of geometry A and B, snap-rounding to a precision scale factor", 2, 1,
+ add("symDifferenceSR", 2, 1, Result::typeGeometry,
+ "computes symmetric difference of geometry A and B, snap-rounding to a precision scale factor",
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::SYMDIFFERENCE, &pm) );
- add("unionSR", "computes union of geometry A and B, snap-rounding to a precision scale factor", 2, 1,
+ add("unionSR", 2, 1, Result::typeGeometry,
+ "computes union of geometry A and B, snap-rounding to a precision scale factor",
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::UNION, &pm) );
- add("clipRect", "clips geometry A to envelope of B", 2, 0,
+ add("clipRect", 2, 0, Result::typeGeometry,
+ "clips geometry A to envelope of B",
using geos::operation::intersection::Rectangle;
@@ -415,19 +451,20 @@ GeomFunction::find(std::string name)
/* static */
void
-GeomFunction::add(std::string name, geomFunSig geomfun)
+GeomFunction::add(std::string name, int resultType, geomFunSig geomfun)
- add(name,
- "computes " + name + " for geometry A",
- 1, 0, geomfun);
+ add(name, 1, 0, resultType,
+ "computes " + name + " of geometry",
+ geomfun);
/* static */
void
- std::string desc,
int nGeomParam,
int nParam,
+ int typeCode,
+ std::string desc,
geomFunSig geomfun)
auto fun = new GeomFunction();
@@ -436,6 +473,7 @@ GeomFunction::add(std::string name,
fun->geomfun = geomfun;
fun->numGeomParam = nGeomParam;
fun->numParam = nParam;
+ fun->resultType = typeCode;
registry.insert( std::pair<std::string, GeomFunction *>(name, fun) );
@@ -451,11 +489,13 @@ bool GeomFunction::isBinary()
std::string GeomFunction::signature() {
- std::string sig = funName + " A";
- if (isBinary()) {
- sig += " B";
+ std::string sig = " A";
+ sig += isBinary() ? " B" : " ";
+ sig += " ";
+ sig += funName;
if (numParam > 0) sig += " N";
+ sig += " >";
+ sig += Result::code(resultType);
return sig;
@@ -583,3 +623,16 @@ Result::metadata() {
return "Unknonwn type";
+std::string
+Result::code(int code) {
+ switch (code) {
+ case typeBool: return "B";
+ case typeInt: return "I";
+ case typeDouble: return "D";
+ case typeString: return "S";
+ case typeGeometry: return "G";
+ case typeGeomList: return "[G]";
+ return "U";
diff --git a/util/geosop/GeomFunction.h b/util/geosop/GeomFunction.h
index 5d9938a..4e13783 100644
--- a/util/geosop/GeomFunction.h
+++ b/util/geosop/GeomFunction.h
@@ -44,12 +44,13 @@ public:
Result(Geometry * val);
~Result();
+ static std::string code(int typeCode);
bool isGeometry();
bool isGeometryList();
std::string metadata();
std::string toString();
-private:
enum {
typeBool = 1, typeInt, typeDouble, typeString, typeGeometry, typeGeomList
} typeCode;
@@ -73,11 +74,12 @@ public:
const std::unique_ptr<Geometry>& geomB, double d );
private:
- static void add(std::string name, geomFunSig geomfun);
+ static void add(std::string name, int resultType, geomFunSig geomfun);
- std::string desc,
int nGeom,
int nParam,
+ int resultType,
+ std::string desc,
static std::map<std::string, GeomFunction*> registry;
@@ -93,6 +95,7 @@ private:
int numGeomParam; // number of *required* geometry parameters (0,1,2)
int numParam; // number of none-geometry parameters (0 or 1 currently)
//TODO: add result type?
+ int resultType;
geomFunSig geomfun;
Summary of changes:
util/geosop/GeomFunction.cpp | 167 ++++++++++++++++++++++++++++---------------
util/geosop/GeomFunction.h | 9 ++-
2 files changed, 116 insertions(+), 60 deletions(-)
hooks/post-receive
More information about the geos-commits
