[geos-commits] [SCM] GEOS branch main updated. 848f978b8906c9a3515743b52caa86c1ca81d909
Fri Sep 17 13:36:28 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  848f978b8906c9a3515743b52caa86c1ca81d909 (commit)
      from  7315c299aaace9fdf9ae55042bc7ae1f32856009 (commit)
revisions in full, below.
commit 848f978b8906c9a3515743b52caa86c1ca81d909
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Sep 17 13:36:23 2021 -0700
    Fix DiscreteFrechetDistance initialization problem
diff --git a/src/algorithm/distance/DiscreteFrechetDistance.cpp b/src/algorithm/distance/DiscreteFrechetDistance.cpp
index 4068bcb..1ea8509 100644
--- a/src/algorithm/distance/DiscreteFrechetDistance.cpp
+++ b/src/algorithm/distance/DiscreteFrechetDistance.cpp
@@ -109,7 +109,7 @@ DiscreteFrechetDistance::getFrecheDistance(std::vector< std::vector<PointPairDis
     p_ptDist.initialize(getSegementAt(p, i), getSegementAt(q, j));
     if(i == 0 && j == 0) {
-        ca[i][j] = ptDist;
+        ca[i][j] = p_ptDist;
     else if(i > 0 && j == 0) {
         PointPairDistance nextDist = getFrecheDistance(ca, i - 1, 0, p, q);
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index a31c26f..1ea5e75 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -156,4 +156,13 @@ void object::test<4>
     runTest("LINESTRING (0 0, 100 0)", "LINESTRING (0 0, 50 50, 100 0)", 0.5, 50.0);
+// 5 - test Line Segments revealing distance intialization bug
+template<>
+template<>
+void object::test<5>
+    runTest("LINESTRING (1 1, 2 2)", "LINESTRING (1 4, 2 3)", 3);
 } // namespace tut
Summary of changes:
 src/algorithm/distance/DiscreteFrechetDistance.cpp            | 2 +-
 tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp | 9 +++++++++
 2 files changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
