[geos-commits] [SCM] GEOS branch 3.9 updated. 4e0008c232831d95c909982b2981e3556111760b
Fri Sep 17 14:50:16 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
       via  4e0008c232831d95c909982b2981e3556111760b (commit)
      from  2d9cfd05594fdacc53a818f353f90c55b7b3ab9a (commit)
revisions in full, below.
commit 4e0008c232831d95c909982b2981e3556111760b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Sep 17 14:50:10 2021 -0700
    Fix DiscreteFrechetDistance initialization problem
diff --git a/NEWS b/NEWS
index 1e29d50..8a066d0 100644
--- a/NEWS
+++ b/NEWS
@@ -10,7 +10,7 @@ Changes in 3.9.2
   - Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
   - Performance improvement in SegmentNodeList (Even Rouault)
   - Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
+  - Fix DiscreteFrechetDistance to use initial points of input lines (#1128, Martin Davis)
 Changes in 3.9.1
 2021-02-10
diff --git a/src/algorithm/distance/DiscreteFrechetDistance.cpp b/src/algorithm/distance/DiscreteFrechetDistance.cpp
index b41225f..4e5cc66 100644
--- a/src/algorithm/distance/DiscreteFrechetDistance.cpp
+++ b/src/algorithm/distance/DiscreteFrechetDistance.cpp
@@ -91,7 +91,7 @@ DiscreteFrechetDistance::getFrecheDistance(std::vector< std::vector<PointPairDis
     p_ptDist.initialize(getSegementAt(p, i), getSegementAt(q, j));
     if(i == 0 && j == 0) {
-        ca[i][j] = ptDist;
+        ca[i][j] = p_ptDist;
     else if(i > 0 && j == 0) {
         PointPairDistance nextDist = getFrecheDistance(ca, i - 1, 0, p, q);
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index 203657d..effe5a8 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -132,4 +132,13 @@ void object::test<4>
     runTest("LINESTRING (0 0, 100 0)", "LINESTRING (0 0, 50 50, 100 0)", 0.5, 50.0);
+// 5 - test Line Segments revealing distance intialization bug
+template<>
+template<>
+void object::test<5>
+    runTest("LINESTRING (1 1, 2 2)", "LINESTRING (1 4, 2 3)", 3);
 } // namespace tut
Summary of changes:
 NEWS                                                          | 2 +-
 src/algorithm/distance/DiscreteFrechetDistance.cpp            | 2 +-
 tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp | 9 +++++++++
 3 files changed, 11 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
