[geos-commits] [SCM] GEOS branch main updated. 64eaf3e53c82539f509033fdece2e77e4be41c5c
git at osgeo.org
git at osgeo.org
Sat Sep 25 19:01:10 PDT 2021
the project "GEOS".
The branch, main has been updated
via 64eaf3e53c82539f509033fdece2e77e4be41c5c (commit)
from 22358039bdad5216082a86de7f81a552e186becd (commit)
revisions in full, below.
commit 64eaf3e53c82539f509033fdece2e77e4be41c5c
Author: Martin Davis <mtnclimb at gmail.com>
Date: Sat Sep 25 19:01:06 2021 -0700
Improve geosop op descriptions
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 01d4ff4..8a48cb5 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -30,6 +30,9 @@
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
#include <geos/geom/util/Densifier.h>
+#include <geos/operation/buffer/BufferBuilder.h>
+#include <geos/operation/buffer/BufferOp.h>
+#include <geos/operation/buffer/BufferParameters.h>
#include <geos/operation/linemerge/LineMerger.h>
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/intersection/RectangleIntersection.h>
@@ -98,13 +101,13 @@ GeomFunction::init()
return new Result( geom->getCentroid() );
add("isEmpty", 1, 0, Result::typeBool, catGeom,
- "tests if geometry is empty",
+ "test if geometry is empty",
[](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
(void) geomB; (void)d; // prevent unused variable warning
return new Result( geom->isEmpty() );
add("normalize", 1, 0, Result::typeGeometry, catGeom,
- "normalizes geometry",
+ "normalize geometry",
auto res = geom->clone();
@@ -113,7 +116,7 @@ GeomFunction::init()
add("lineMerge", 1, 0, Result::typeGeometry, catGeom,
- "merges the lines of geometry",
+ "merge the lines of geometry",
geos::operation::linemerge::LineMerger lmrgr;
@@ -129,14 +132,14 @@ GeomFunction::init()
add("reducePrecision", 1, 1, Result::typeGeometry, catGeom,
- "reduces precision of geometry to a precision scale factor",
+ "reduce precision of geometry to a precision scale factor",
(void)geomB; // prevent unused variable warning
PrecisionModel pm(d);
return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
add("reverse", 1, 0, Result::typeGeometry, catGeom,
- "reverses geometry",
+ "reverse geometry",
return new Result( geom->reverse() );
@@ -156,14 +159,14 @@ GeomFunction::init()
add("isSimple", 1, 0, Result::typeBool, catValid,
- "tests if geometry is simple",
+ "test if geometry is simple",
return new Result( geom->isSimple() );
add("isValid", 1, 0, Result::typeBool, catValid,
- "tests if geometry is valid",
+ "test if geometry is valid",
return new Result( geom->isValid() );
@@ -181,11 +184,25 @@ GeomFunction::init()
return new Result( geom->getBoundary() );
add("buffer", 1, 1, Result::typeGeometry,
- catConst, "computes the buffer of geometry by a distance",
+ catConst, "compute the buffer of geometry by a distance",
(void) geomB; // prevent unused variable warning
return new Result( geom->buffer( d ) );
+ add("offsetCurve", 1, 1, Result::typeGeometry,
+ catConst, "compute the offset curve of geometry by a distance",
+ [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+ (void) geomB; // prevent unused variable warning
+ geos::operation::buffer::BufferParameters bp;
+ bool isLeftSide = true;
+ if(d < 0) {
+ isLeftSide = false;
+ d = -d;
+ geos::operation::buffer::BufferBuilder bufBuilder(bp);
+ return new Result( bufBuilder.bufferLineSingleSided(geom.get(), d, isLeftSide) );
add("centroid", Result::typeGeometry, catConst,
@@ -198,7 +215,7 @@ GeomFunction::init()
add("densify", 1, 1, Result::typeGeometry, catConst,
- "densifies geometry to a distance ",
+ "densify geometry to a distance ",
geos::geom::util::Densifier densifier( geom.get() );
@@ -215,7 +232,7 @@ GeomFunction::init()
add("largestEmptyCircle", 1, 1, Result::typeGeometry, catConst,
- "computes radius line of largest empty circle of geometry up to a distance tolerance",
+ "compute radius line of largest empty circle of geometry up to a distance tolerance",
geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), d );
@@ -224,7 +241,7 @@ GeomFunction::init()
add("maxInscribedCircle", 1, 1, Result::typeGeometry, catConst,
- "computes maximum inscribed circle radius of Polygon up to a distance tolerance",
+ "compute maximum inscribed circle radius of Polygon up to a distance tolerance",
geos::algorithm::construct::MaximumInscribedCircle mc( geom.get(), d );
@@ -241,7 +258,7 @@ GeomFunction::init()
add("delaunay", 1, 0, Result::typeGeometry, catConst,
- "computes the Delaunay Triangulation of geometry vertices",
+ "compute the Delaunay Triangulation of geometry vertices",
geos::triangulate::DelaunayTriangulationBuilder builder;
@@ -264,7 +281,7 @@ GeomFunction::init()
add("voronoi", 1, 0, Result::typeGeometry, catConst,
- "computes the Voronoi Diagram of geometry vertices",
+ "Voronoi Diagram of geometry vertices",
geos::triangulate::VoronoiDiagramBuilder builder;
@@ -294,13 +311,13 @@ GeomFunction::init()
return new Result( std::move(geoms) ) ;
add("simplifyDP", 1, 1, Result::typeGeometry, catConst,
- "simplifies geometry using Douglas-Peucker with a distance tolerance",
+ "simplify geometry using Douglas-Peucker with a distance tolerance",
return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
add("simplifyTP", 1, 1, Result::typeGeometry, catConst,
- "simplifies geometry using Douglas-Peucker with a distance tolerance, preserving topology",
+ "simplify geometry using Douglas-Peucker with a distance tolerance, preserving topology",
return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
@@ -308,25 +325,25 @@ GeomFunction::init()
add("contains", 2, 0, Result::typeBool, catRel,
- "tests if geometry A contains geometry B",
+ "test if geometry A contains geometry B",
return new Result( geom->contains( geomB.get() ) );
add("covers", 2, 0, Result::typeBool, catRel,
- "tests if geometry A covers geometry B",
+ "test if geometry A covers geometry B",
return new Result( geom->covers( geomB.get() ) );
add("intersects", 2, 0, Result::typeBool, catRel,
- "tests if geometry A and B intersect",
+ "test if geometry A and B intersect",
return new Result( geom->intersects( geomB.get() ) );
add("relate", 2, 0, Result::typeString, catRel,
- "computes DE-9IM matrix for geometry A and B",
+ "compute DE-9IM matrix for geometry A and B",
std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
@@ -334,25 +351,25 @@ GeomFunction::init()
add("containsPrep", 2, 0, Result::typeBool, catRel,
- "tests if geometry A contains geometry B, using PreparedGeometry",
+ "test if geometry A contains geometry B, using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
add("containsProperlyPrep", 2, 0, Result::typeBool, catRel,
- "tests if geometry A properly contains geometry B using PreparedGeometry",
+ "test if geometry A properly contains geometry B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
add("coversPrep", 2, 0, Result::typeBool, catRel,
- "tests if geometry A covers geometry B using PreparedGeometry",
+ "test if geometry A covers geometry B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
add("intersectsPrep", 2, 0, Result::typeBool, catRel,
- "tests if geometry A intersects B using PreparedGeometry",
+ "test if geometry A intersects B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
@@ -361,13 +378,13 @@ GeomFunction::init()
add("distance", 2, 0, Result::typeDouble, catDist,
- "computes distance between geometry A and B",
+ "compute distance between geometry A and B",
return new Result( geom->distance( geomB.get() ) );
add("nearestPoints", 2, 0, Result::typeGeometry, catDist,
- "computes a line containing the nearest points of geometry A and B",
+ "compute a line containing the nearest points of geometry A and B",
std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
@@ -376,7 +393,7 @@ GeomFunction::init()
return new Result( std::move(res) );
add("frechetDistance", 2, 0, Result::typeDouble, catDist,
- "computes discrete Frechet distance between geometry A and B",
+ "compute discrete Frechet distance between geometry A and B",
return new Result( geos::algorithm::distance::DiscreteFrechetDistance::distance(*geom, *geomB ) );
@@ -405,13 +422,13 @@ GeomFunction::init()
add("distancePrep", 2, 0, Result::typeDouble, catDist,
- "computes distance between geometry A and B using PreparedGeometry",
+ "compute distance between geometry A and B using PreparedGeometry",
return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
add("nearestPointsPrep", 2, 0, Result::typeGeometry, catDist,
- "computes a line containing the nearest points of geometry A and B using PreparedGeometry",
+ "compute a line containing the nearest points of geometry A and B using PreparedGeometry",
auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
@@ -423,19 +440,19 @@ GeomFunction::init()
add("difference", 2, 0, Result::typeGeometry, catOverlay,
- "computes difference of geometry A from B",
+ "compute difference of geometry A from B",
return new Result( geom->difference( geomB.get() ) );
add("intersection", 2, 0, Result::typeGeometry, catOverlay,
- "computes intersection of geometry A and B",
+ "compute intersection of geometry A and B",
return new Result( geom->intersection( geomB.get() ) );
add("symDifference", 2, 0, Result::typeGeometry, catOverlay,
- "computes symmetric difference of geometry A and B",
+ "compute symmetric difference of geometry A and B",
return new Result( geom->symDifference( geomB.get() ) );
@@ -446,39 +463,39 @@ GeomFunction::init()
return new Result( geom->Union() );
add("union", 2, 0, Result::typeGeometry, catOverlay,
- "computes union of geometry A and B",
+ "compute union of geometry A and B",
return new Result( geom->Union( geomB.get() ) );
add("differenceSR", 2, 1, Result::typeGeometry, catOverlay,
- "computes difference of geometry A from B, snap-rounding to a precision scale factor",
+ "compute difference of geometry A from B, snap-rounding to a precision scale factor",
geos::geom::PrecisionModel pm(d);
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::DIFFERENCE, &pm) );
add("intersectionSR", 2, 1, Result::typeGeometry, catOverlay,
- "computes intersection of geometry A and B, snap-rounding to a precision scale factor",
+ "compute intersection of geometry A and B, snap-rounding to a precision scale factor",
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::INTERSECTION, &pm) );
add("symDifferenceSR", 2, 1, Result::typeGeometry, catOverlay,
- "computes symmetric difference of geometry A and B, snap-rounding to a precision scale factor",
+ "compute symmetric difference of geometry A and B, snap-rounding to a precision scale factor",
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::SYMDIFFERENCE, &pm) );
add("unionSR", 2, 1, Result::typeGeometry, catOverlay,
- "computes union of geometry A and B, snap-rounding to a precision scale factor",
+ "compute union of geometry A and B, snap-rounding to a precision scale factor",
return new Result( OverlayNG::overlay(geom.get(), geomB.get(), OverlayNG::UNION, &pm) );
add("clipRect", 2, 0, Result::typeGeometry, catOverlay,
- "clips geometry A to envelope of B",
+ "clip geometry A to envelope of B",
using geos::operation::intersection::Rectangle;
@@ -504,7 +521,7 @@ void
GeomFunction::add(std::string name, int resultType, std::string category, geomFunSig geomfun)
add(name, 1, 0, resultType, category,
- "computes " + name + " of geometry",
+ "compute " + name + " of geometry",
geomfun);
Summary of changes:
util/geosop/GeomFunction.cpp | 93 ++++++++++++++++++++++++++------------------
1 file changed, 55 insertions(+), 38 deletions(-)
hooks/post-receive
More information about the geos-commits
