[geos-commits] [SCM] GEOS branch main updated. beb9207f650abeff96e9872903cf2a20b8011654
git at osgeo.org
git at osgeo.org
Tue Sep 28 14:35:05 PDT 2021
the project "GEOS".
The branch, main has been updated
via beb9207f650abeff96e9872903cf2a20b8011654 (commit)
from 87f56eacce1f40ffb730dc8152aa9038b59873f2 (commit)
revisions in full, below.
commit beb9207f650abeff96e9872903cf2a20b8011654
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Sep 28 14:35:01 2021 -0700
Attempt to address performance in triangulating large multipolygons, by creating a separate TriList for each incoming Polygon
diff --git a/include/geos/triangulate/tri/TriList.h b/include/geos/triangulate/tri/TriList.h
index 64777e3..e311c93 100644
--- a/include/geos/triangulate/tri/TriList.h
+++ b/include/geos/triangulate/tri/TriList.h
@@ -68,7 +68,12 @@ public:
add(corner[0], corner[1], corner[2]);
- std::unique_ptr<Geometry> toGeometry(const GeometryFactory* geomFact) const;
+ std::unique_ptr<Geometry> toGeometry(
+ const GeometryFactory* geomFact) const;
+ static std::unique_ptr<Geometry> toGeometry(
+ const geom::GeometryFactory* geomFact,
+ const std::vector<std::unique_ptr<TriList>>& allTriLists);
friend std::ostream& operator << (std::ostream& os, TriList& te);
diff --git a/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp b/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp
index 0d42754..2e709e3 100644
--- a/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp
+++ b/src/triangulate/polygon/ConstrainedDelaunayTriangulator.cpp
@@ -50,14 +50,16 @@ ConstrainedDelaunayTriangulator::compute()
std::vector<const Polygon*> polys;
geom::util::PolygonExtracter::getPolygons(*inputGeom, polys);
- TriList triList;
+ std::vector<std::unique_ptr<TriList>> allTriLists;
for (const Polygon* poly : polys) {
+ std::unique_ptr<TriList> triList(new TriList());
// Skip empty component polygons
if (poly->isEmpty())
continue;
- triangulatePolygon(poly, triList);
+ triangulatePolygon(poly, *triList);
+ allTriLists.emplace_back(triList.release());
- return triList.toGeometry(geomFact);
+ return TriList::toGeometry(geomFact, allTriLists);
diff --git a/src/triangulate/tri/TriList.cpp b/src/triangulate/tri/TriList.cpp
index 40f4081..80099b5 100644
--- a/src/triangulate/tri/TriList.cpp
+++ b/src/triangulate/tri/TriList.cpp
@@ -55,6 +55,21 @@ TriList::toGeometry(const geom::GeometryFactory* geomFact) const
return geomFact->createGeometryCollection(std::move(geoms));
+/* public static */
+std::unique_ptr<Geometry>
+TriList::toGeometry(
+ std::vector<std::unique_ptr<Geometry>> geoms;
+ for (const std::unique_ptr<TriList>& triList: allTriLists) {
+ for (const Tri* tri: *triList) {
+ std::unique_ptr<Geometry> geom = tri->toPolygon(geomFact);
+ geoms.emplace_back(geom.release());
+ return geomFact->createGeometryCollection(std::move(geoms));
std::ostream&
operator<<(std::ostream& os, TriList& triList)
Summary of changes:
include/geos/triangulate/tri/TriList.h | 7 ++++++-
.../polygon/ConstrainedDelaunayTriangulator.cpp | 8 +++++---
src/triangulate/tri/TriList.cpp | 15 +++++++++++++++
3 files changed, 26 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
