[geos-commits] [SCM] GEOS branch main updated. 97c55f5a82b63cdeaa5ca149ed81190ae35c9434
    git at osgeo.org
    git at osgeo.org
    Thu Sep 30 13:40:09 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  97c55f5a82b63cdeaa5ca149ed81190ae35c9434 (commit)
       via  7edd5cb3471e8f07fcbfa55a826f2dc67670f26d (commit)
       via  f200199f441ca55f73cd9829b4c9ed88ccbdb854 (commit)
      from  7c00a972517362d29c57396bcbc3afed0beb3846 (commit)
revisions in full, below.
commit 97c55f5a82b63cdeaa5ca149ed81190ae35c9434
Merge: 7c00a97 7edd5cb
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Sep 30 13:14:04 2021 -0700
    Merge branch 'mwtoews-gnudirs' into main
commit 7edd5cb3471e8f07fcbfa55a826f2dc67670f26d
Merge: 7c00a97 f200199
Date:   Thu Sep 30 13:13:37 2021 -0700
    Merge branch 'gnudirs' of https://github.com/mwtoews/geos into mwtoews-gnudirs
diff --cc tools/CMakeLists.txt
index 69e54d9,03bcf4a..a6976c4
--- a/tools/CMakeLists.txt
+++ b/tools/CMakeLists.txt
@@@ -37,15 -54,14 +54,19 @@@ function(configure_install_geos_pc
    install(FILES
      ${CMAKE_CURRENT_BINARY_DIR}/geos.pc
      DESTINATION ${CMAKE_INSTALL_LIBDIR}/pkgconfig)
+ endfunction()
+ if(NOT MSVC)
+   configure_install_geos_config()
+   configure_install_geos_pc()
  endif()
 -add_subdirectory(astyle)
 +option(BUILD_ASTYLE "Build astyle (Artistic Style) tool" ON)
 +message(STATUS "GEOS: Build astyle ${BUILD_ASTYLE}")
 +if(BUILD_ASTYLE)
 +  add_subdirectory(astyle)
 +endif()
  # if(UNIX OR MINGW)
commit f200199f441ca55f73cd9829b4c9ed88ccbdb854
Author: Mike Taves <mwtoews at gmail.com>
Date:   Thu May 6 10:16:50 2021 +1200
    CMake: Configure geos-config and geos.pc using functions
    * Use GNUInstallDir variables for correct LIBDIR (e.g. lib or lib64)
    * Use existing *.in files; remove redundant/misleading *.cmake files
diff --git a/tools/CMakeLists.txt b/tools/CMakeLists.txt
index 5cfa885..03bcf4a 100644
@@ -11,12 +11,19 @@
+# Configure geos-config
+function(configure_install_geos_config)
+  string(REPLACE " " "\\ " prefix ${CMAKE_INSTALL_PREFIX})
+  set(exec_prefix "$\{prefix\}")
+  set(includedir "$\{prefix\}/${CMAKE_INSTALL_INCLUDEDIR}")
+  set(libdir "$\{exec_prefix\}/${CMAKE_INSTALL_LIBDIR}")
+  set(VERSION_RELEASE ${GEOS_VERSION_MAJOR})
+  set(VERSION ${GEOS_VERSION})
-if(NOT MSVC)
-  # Consider CMAKE_INSTALL_PREFIX with spaces
-  string(REPLACE " " "\\ " ESCAPED_INSTALL_PREFIX ${CMAKE_INSTALL_PREFIX})
   configure_file(
-    ${CMAKE_CURRENT_SOURCE_DIR}/geos-config.cmake
+    ${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
     ${CMAKE_CURRENT_BINARY_DIR}/geos-config
     @ONLY NEWLINE_STYLE UNIX)
@@ -27,17 +34,31 @@ if(NOT MSVC)
       OWNER_READ OWNER_EXECUTE
       GROUP_READ GROUP_EXECUTE
       WORLD_READ WORLD_EXECUTE)
+endfunction()
+# Configure pkg-config file geos.pc
+function(configure_install_geos_pc)
-  # pkg-config support
   configure_file(
-    ${CMAKE_CURRENT_SOURCE_DIR}/geos.pc.cmake
+    ${CMAKE_CURRENT_SOURCE_DIR}/geos.pc.in
     @ONLY)
   install(FILES
+endfunction()
+if(NOT MSVC)
 endif()
diff --git a/tools/geos-config.cmake b/tools/geos-config.cmake
deleted file mode 100644
index 6730e21..0000000
--- a/tools/geos-config.cmake
+++ /dev/null
@@ -1,77 +0,0 @@
-#!/bin/sh
-prefix=@ESCAPED_INSTALL_PREFIX@
-libdir=${prefix}/lib
-usage()
-  cat <<EOF
-Usage: geos-config [OPTIONS]
-Options:
-     [--prefix]
-     [--version]
-     [--libs]
-     [--clibs]
-     [--cclibs]
-     [--static-clibs]
-     [--static-cclibs]
-     [--cflags]
-     [--ldflags]
-     [--includes]
-     [--jtsport]
-EOF
-  exit $1
-if test $# -eq 0; then
-  usage 1 1>&2
-fi
-while test $# -gt 0; do
-  case "$1" in
-    -*=*) optarg=`echo "$1" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
-    *) optarg= ;;
-  esac
-  case $1 in
-    --prefix)
-      echo ${prefix}
-    --version)
-      echo @GEOS_VERSION@
-    --libs)
-      # TODO: make an alias for --clibs
-      # see http://trac.osgeo.org/geos/ticket/497
-      echo -L${libdir} -lgeos- at GEOS_VERSION_MAJOR@
-    --clibs)
-      echo -L${libdir} -lgeos_c
-    --cclibs)
-    --static-clibs)
-      echo -L${libdir} -lgeos_c -lgeos -lm
-    --static-cclibs)
-      echo -L${libdir} -lgeos -lm
-    --cflags)
-      echo -I${prefix}/include
-    --ldflags)
-      echo -L${libdir}
-    --includes)
-      echo ${prefix}/include
-    --jtsport)
-      echo @JTS_PORT@
-      usage 1 1>&2
-  esac
-  shift
-done
diff --git a/tools/geos-config.in b/tools/geos-config.in
index 89de835..6eff1eb 100644
--- a/tools/geos-config.in
+++ b/tools/geos-config.in
@@ -1,14 +1,9 @@
 #!/bin/sh
-# escape paths
-escape() {
-  echo "$1" | sed 's/ /\\ /g'
-prefix=`escape "@prefix@"`
-# exec_prefix is interpolated in @libdir@
-exec_prefix=`escape "@exec_prefix@"`
-libdir=`escape "@libdir@"`
+prefix=@prefix@
+exec_prefix=@exec_prefix@
+includedir=@includedir@
+libdir=@libdir@
 usage()
@@ -64,13 +59,13 @@ while test $# -gt 0; do
     --cflags)
+      echo -I${includedir}
     --ldflags)
       echo -L${libdir}
     --includes)
+      echo ${includedir}
     --jtsport)
       echo @JTS_PORT@
diff --git a/tools/geos.pc.cmake b/tools/geos.pc.cmake
index 0a9df7f..0000000
--- a/tools/geos.pc.cmake
+++ /dev/null
@@ -1,11 +0,0 @@
-exec_prefix=${prefix}
-includedir=${prefix}/include
-Name: GEOS
-Description: Geometry Engine, Open Source - C API
-Requires:
-Version: @GEOS_VERSION@
-Cflags: -I${includedir}
-Libs: -L${libdir} -lgeos_c
Summary of changes:
 tools/CMakeLists.txt    | 33 +++++++++++++++++----
 tools/geos-config.cmake | 77 -------------------------------------------------
 tools/geos-config.in    | 17 ++++-------
 tools/geos.pc.cmake     | 11 -------
 4 files changed, 33 insertions(+), 105 deletions(-)
 delete mode 100644 tools/geos-config.cmake
 delete mode 100644 tools/geos.pc.cmake
hooks/post-receive
More information about the geos-commits
