[geos-commits] [SCM] GEOS branch main updated. 7f40256c66273f2dfaaf57cc56e6ad1347b17d6e
Thu Sep 30 15:47:20 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  7f40256c66273f2dfaaf57cc56e6ad1347b17d6e (commit)
       via  d0f8b75b42065a866cd58c913812c28873422637 (commit)
      from  3972990a4746966a2b33932c71b9087b8b87c9dc (commit)
revisions in full, below.
commit 7f40256c66273f2dfaaf57cc56e6ad1347b17d6e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Sep 30 15:47:15 2021 -0700
    Hold dev tag until release
diff --git a/Version.txt b/Version.txt
index 8601ce3..d0a7ea8 100644
--- a/Version.txt
+++ b/Version.txt
@@ -5,7 +5,7 @@ GEOS_VERSION_MINOR=10
 GEOS_VERSION_PATCH=0
 # OPTIONS: "", "dev", "rc1" etc.
-GEOS_PATCH_WORD=beta1
+GEOS_PATCH_WORD=dev
 # GEOS CAPI Versions
commit d0f8b75b42065a866cd58c913812c28873422637
Date:   Thu Sep 30 15:46:22 2021 -0700
    Bumps for pre-release
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index efd1d74..3393559 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,5 +1,5 @@
 1. Verify that the versions currently set in Version.txt
-   make sense for this release.
+   make sense for this release. See file for instructions.
     - GEOS_VERSION_PATCH
     - GEOS_VERSION_MINOR
@@ -9,38 +9,46 @@
     - CAPI_INTERFACE_REVISION
     - CAPI_INTERFACE_AGE
-2. Run 'make distcheck', fix any problem with it.
+2. Prepare the build directory.
-3. Update the NEWS file (extract most important things from the
+   $ mkdir _build && cd _build && cmake ..
+3. Run the distcheck target, fix any problem with it.
+   $ cmake --build . --target distcheck
+4. Update the NEWS file (extract most important things from the
    repository log). Make sure to update the release date.
-4. Commit the changes in the NEWS file.
+5. Commit the changes in the NEWS file.
-5. Run 'make dist-bzip2'.
+6. Build the distribution package.
-   $ mkdir build && cd build && cmake .. && cmake --build . --target dist
-6. Verify that you can un-pack and build the tarball.
+7. Verify that you can un-pack and build the tarball.
-   - mkdir build && cd build && cmake .. && make && make check
+   $ tar xvfz geos-VERSION.tar.bz2
+   $ cd geos-VERSION
+   $ mkdir _build && cd _build && cmake .. && make && make check
-7. Copy the tarball to upload.osgeo.org:/osgeo/download/geos
+8. Copy the tarball to upload.osgeo.org:/osgeo/download/geos
-8. Tag the release:
+9. Tag the release:
    $ git tag MAJOR.MINOR.PATCH
    $ git push origin MAJOR.MINOR.PATCH
-9. Create and push a release branch if this was a PATCH=0 release,
-   update the versions for next release in Version.txt (both in
-   main and release branch if this was a PATCH=0 release).
+10. Create and push a release branch if this was a PATCH=0 release,
+    update the versions for next release in Version.txt (both in
+    main and release branch if this was a PATCH=0 release).
-10. Update wiki page https://trac.osgeo.org/geos/ at Download section
+11. Update wiki page https://trac.osgeo.org/geos/ at Download section
     - Add latest release
     - Remove previous patch level release (if any)
-11. Close current trac milestone and add new one for next release,
+12. Close current trac milestone and add new one for next release,
     add new trac version for this release.
 12. Announce on geos-devel
index b257748..8601ce3 100644
--- a/Version.txt
+++ b/Version.txt
-GEOS_PATCH_WORD=dev
+GEOS_PATCH_WORD=beta1
@@ -15,9 +15,9 @@ GEOS_PATCH_WORD=dev
 # - Deleting interfaces / compatibility issues - bump CURRENT, others to zero
 #   ( THIS MUST BE CAREFULLY AVOIDED )
-CAPI_INTERFACE_CURRENT=16
+CAPI_INTERFACE_CURRENT=17
 CAPI_INTERFACE_REVISION=0
-CAPI_INTERFACE_AGE=15
+CAPI_INTERFACE_AGE=16
 # JTS Port
-JTS_PORT=1.17.0
+JTS_PORT=1.18.0
Summary of changes:
 HOWTO_RELEASE | 38 +++++++++++++++++++++++---------------
 Version.txt   |  6 +++---
 2 files changed, 26 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
