[geos-commits] [SCM] GEOS branch main updated. 5ab8087560e2b01273dd2835b502e9a0d033305f
Tue Apr 11 18:34:46 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  5ab8087560e2b01273dd2835b502e9a0d033305f (commit)
       via  98ab44a8251d6a0eba2d7d419580d3226a4a4a77 (commit)
       via  f8d92f8460dd452292c070c15908ea326a3de559 (commit)
      from  dd92d34f74fdda129fa0f1c32ee65d323cd471fb (commit)
revisions in full, below.
commit 5ab8087560e2b01273dd2835b502e9a0d033305f
Author: Mike Taves <mwtoews at gmail.com>
Date:   Wed Apr 12 13:34:20 2023 +1200
    Add Point::getM() to C++ API and GEOSGeomGetM to C API (#864)
    * Add GEOSGeomGetM (and GEOSGeomGetM_r) to C API
    * Add Point::getM() to C++ API
    * Refactor Point::getZ() to use CoordianteSequence::getOrdinate(0, CoordinateSequence::Z)
    * Rename GEOSGeomGetXYZTest.cpp to GEOSGeomGetXYZMTest.cpp
    * CoordinateSequence: Fix getOrdinate for XYM-backed sequence
    Co-authored-by: Daniel Baston <dbaston at gmail.com>
diff --git a/NEWS.md b/NEWS.md
index f0eac88a8..5cdf51ad1 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -17,6 +17,7 @@ xxxx-xx-xx
   - CAPI: GEOSEqualsIdentical (GH-810, Dan Baston)
   - CAPI: GEOSSTRtree_build (GH-835, Dan Baston)
   - CAPI: GEOSConcaveHullByLength (GH-849, Martin Davis)
+  - CAPI: GEOSGeomGetM (GH-864, Mike Taves)
   - Voronoi: Add option to create diagram in order consistent with inputs (GH-781, Dan Baston)
 - Fixes/Improvements:
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 7f77e5d3a..f67db11c2 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -794,6 +794,16 @@ extern "C" {
         return GEOSGeomGetZ_r(handle, g1, z);
+     * For POINT
+     * returns 0 on exception, otherwise 1
+    int
+    GEOSGeomGetM(const Geometry* g1, double* m)
+        return GEOSGeomGetM_r(handle, g1, m);
      * Call only on polygon
      * Return a copy of the internal Geometry.
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 40985aa86..a1cb103a0 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1559,6 +1559,12 @@ extern int GEOS_DLL GEOSGeomGetZ_r(
     const GEOSGeometry *g,
     double *z);
+/** \see GEOSGeomGetM */
+extern int GEOS_DLL GEOSGeomGetM_r(
+    GEOSContextHandle_t handle,
+    const GEOSGeometry *g,
+    double *m);
 /** \see GEOSGetInteriorRingN */
 extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN_r(
@@ -2558,6 +2564,17 @@ extern int GEOS_DLL GEOSGeomGetY(const GEOSGeometry *g, double *y);
 extern int GEOS_DLL GEOSGeomGetZ(const GEOSGeometry *g, double *z);
+* Returns the M coordinate, for a Point input, or an
+* exception otherwise.
+* \param[in] g Input Point geometry
+* \param[out] m Pointer to hold return value
+* \returns 1 on success, 0 on exception
+* \since 3.12
+extern int GEOS_DLL GEOSGeomGetM(const GEOSGeometry *g, double *m);
 * Returns the N'th ring for a Polygon input.
 * \note Returned object is a pointer to internal storage:
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 922eebf23..facefb9e3 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1862,6 +1862,25 @@ extern "C" {
+     * For POINT
+    int
+    GEOSGeomGetM_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* m)
+        using geos::geom::Point;
+        return execute(extHandle, 0, [&]() {
+            const Point* po = dynamic_cast<const Point*>(g1);
+            if(!po) {
+                throw IllegalArgumentException("Argument is not a Point");
+            *m = po->getM();
+            return 1;
      * Return a pointer to the internal Geometry.
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index f03abba45..cc944d972 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -129,6 +129,7 @@ public:
     double getX() const;
     double getY() const;
     double getZ() const;
+    double getM() const;
     std::string getGeometryType() const override;
     GeometryTypeId getGeometryTypeId() const override;
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index 237a17145..a0ff67944 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -289,7 +289,9 @@ CoordinateSequence::getOrdinate(std::size_t index, std::size_t ordinateIndex) co
         case CoordinateSequence::Z:
             return hasZ() ? getAt<Coordinate>(index).z : DoubleNotANumber;
         case CoordinateSequence::M:
-            return hasM() ? (hasZ() ? getAt<CoordinateXYZM>(index).m : getAt<CoordinateXYM>(index).m) : DoubleNotANumber;
+            return getCoordinateType() == CoordinateType::XYZM ? getAt<CoordinateXYZM>(index).m :
+        getCoordinateType() == CoordinateType::XYM ? getAt<CoordinateXYM>(index).m :
+        DoubleNotANumber;
         default:
             return DoubleNotANumber;
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 897d28a9a..86cf54ccc 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -177,7 +177,16 @@ Point::getZ() const
     if(isEmpty()) {
         throw util::UnsupportedOperationException("getZ called on empty Point\n");
-    return coordinates.getAt<Coordinate>(0).z;
+    return coordinates.getOrdinate(0, CoordinateSequence::Z);
+double
+Point::getM() const
+    if(isEmpty()) {
+        throw util::UnsupportedOperationException("getM called on empty Point\n");
+    return coordinates.getOrdinate(0, CoordinateSequence::M);
 std::string
diff --git a/tests/unit/capi/GEOSGeomGetXYZTest.cpp b/tests/unit/capi/GEOSGeomGetXYZMTest.cpp
similarity index 53%
rename from tests/unit/capi/GEOSGeomGetXYZTest.cpp
rename to tests/unit/capi/GEOSGeomGetXYZMTest.cpp
index 5fd07ea81..38c33fc48 100644
--- a/tests/unit/capi/GEOSGeomGetXYZTest.cpp
+++ b/tests/unit/capi/GEOSGeomGetXYZMTest.cpp
@@ -9,12 +9,12 @@ namespace tut {
 // Test Group
-struct test_geosgeomgetxyz_data : public capitest::utility {};
+struct test_geosgeomgetxyzm_data : public capitest::utility {};
-typedef test_group<test_geosgeomgetxyz_data> group;
+typedef test_group<test_geosgeomgetxyzm_data> group;
 typedef group::object object;
-group test_geosgeomgetxyz("capi::GEOSGeomGetXYZ");
+group test_geosgeomgetxyzm("capi::GEOSGeomGetXYZM");
 template<>
 template<>
@@ -24,55 +24,96 @@ void object::test<1>()
     double x = 0;
     double y = 0;
     double z = 0;
+    double m = 0;
     ensure_equals(GEOSGeomGetX(input_, &x), 1);
     ensure_equals(GEOSGeomGetY(input_, &y), 1);
     ensure_equals(GEOSGeomGetZ(input_, &z), 1);
+    ensure_equals(GEOSGeomGetM(input_, &m), 1);
     ensure_equals(x, 1);
     ensure_equals(y, 2);
     ensure(std::isnan(z));
+    ensure(std::isnan(m));
 template<>
 template<>
 void object::test<2>()
-    input_ = GEOSGeomFromWKT("POINT (1 2 3)");
+    input_ = GEOSGeomFromWKT("POINT Z (1 2 3)");
     double z = 0;
+    double m = 0;
     ensure_equals(z, 3);
 template<>
 template<>
 void object::test<3>()
+    input_ = GEOSGeomFromWKT("POINT M (1 2 4)");
+    double z = 0;
+    double m = 0;
+    ensure_equals(GEOSGeomGetZ(input_, &z), 1);
+    ensure(std::isnan(z));
+    ensure_equals(m, 4);
+template<>
+template<>
+void object::test<4>()
+    input_ = GEOSGeomFromWKT("POINT ZM (1 2 3 4)");
+    double z = 0;
+    double m = 0;
+    ensure_equals(z, 3);
+template<>
+template<>
+void object::test<5>()
     input_ = GEOSGeomFromWKT("POINT EMPTY");
     double x = 0;
     double y = 0;
     double z = 0;
+    double m = 0;
     ensure_equals(GEOSGeomGetX(input_, &x), 0);
     ensure_equals(GEOSGeomGetY(input_, &y), 0);
     ensure_equals(GEOSGeomGetZ(input_, &z), 0);
+    ensure_equals(GEOSGeomGetM(input_, &m), 0);
 template<>
 template<>
-void object::test<4>()
+void object::test<6>()
     input_ = GEOSGeomFromWKT("LINESTRING (1 1, 2 2)");
     double x = 0;
     double y = 0;
     double z = 0;
+    double m = 0;
diff --git a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
index 57c7e7ffa..9f3eda5a1 100644
--- a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
@@ -22,11 +22,11 @@ void object::test<1>
     GEOSGeometry* point = GEOSGeomFromWKT("POINT (4 2 7)");
-    GEOSGeometry* line = GEOSGeomFromWKT("LINESTRING (4 2 7, 8 2 9)");
+    GEOSGeometry* line = GEOSGeomFromWKT("LINESTRING (4 2 7 1, 8 2 9 5)");
     GEOSGeometry* poly = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
     ensure_equals(GEOSGeom_getCoordinateDimension(point), 3);
-    ensure_equals(GEOSGeom_getCoordinateDimension(line), 3);
+    ensure_equals(GEOSGeom_getCoordinateDimension(line), 4);
     ensure_equals(GEOSGeom_getCoordinateDimension(poly), 2);
     GEOSGeom_destroy(point);
diff --git a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
index 79686b026..d81d1d2d4 100644
--- a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
@@ -22,7 +22,7 @@ void object::test<1>
     ensure_equals(GEOSGeom_getDimensions(point), 0);
diff --git a/tests/unit/geom/CoordinateSequenceTest.cpp b/tests/unit/geom/CoordinateSequenceTest.cpp
index 3edce6068..7ec843bad 100644
--- a/tests/unit/geom/CoordinateSequenceTest.cpp
+++ b/tests/unit/geom/CoordinateSequenceTest.cpp
@@ -1258,25 +1258,68 @@ void object::test<47>
     ensure_equals(seq.getDimension(), 2u);
-// Test getOrinate
+// Test getOrdinate
 template<>
 template<>
 void object::test<48>
-    CoordinateSequence seq{CoordinateXY(1, 2), CoordinateXY(3, 4)};
+        CoordinateSequence seq_xy{CoordinateXY(1, 2), CoordinateXY(3, 4)};
+        ensure_same(seq_xy.getOrdinate(0, CoordinateSequence::X), 1);
+        ensure_same(seq_xy.getOrdinate(0, CoordinateSequence::Y), 2);
+        ensure_same(seq_xy.getOrdinate(0, CoordinateSequence::Z), DoubleNotANumber);
+        ensure_same(seq_xy.getOrdinate(0, CoordinateSequence::M), DoubleNotANumber);
+        ensure_same(seq_xy.getOrdinate(1, CoordinateSequence::X), 3);
+        ensure_same(seq_xy.getOrdinate(1, CoordinateSequence::Y), 4);
+        ensure_same(seq_xy.getOrdinate(1, CoordinateSequence::Z), DoubleNotANumber);
+        ensure_same(seq_xy.getOrdinate(1, CoordinateSequence::M), DoubleNotANumber);
+        CoordinateSequence seq_xym{CoordinateXYM(1, 2, 3), CoordinateXYM(4, 5, 6)};
+        ensure_same(seq_xym.getOrdinate(0, CoordinateSequence::X), 1);
+        ensure_same(seq_xym.getOrdinate(0, CoordinateSequence::Y), 2);
+        ensure_same(seq_xym.getOrdinate(0, CoordinateSequence::Z), DoubleNotANumber);
+        ensure_same(seq_xym.getOrdinate(0, CoordinateSequence::M), 3);
-    ensure_same(seq.getOrdinate(0, CoordinateSequence::Y), 2);
-    ensure_same(seq.getOrdinate(1, CoordinateSequence::X), 3);
-    ensure_same(seq.getOrdinate(1, CoordinateSequence::Z), DoubleNotANumber);
-    ensure_same(seq.getOrdinate(1, CoordinateSequence::M), DoubleNotANumber);
+        ensure_same(seq_xym.getOrdinate(1, CoordinateSequence::X), 4);
+        ensure_same(seq_xym.getOrdinate(1, CoordinateSequence::Y), 5);
+        ensure_same(seq_xym.getOrdinate(1, CoordinateSequence::Z), DoubleNotANumber);
+        ensure_same(seq_xym.getOrdinate(1, CoordinateSequence::M), 6);
+        CoordinateSequence seq_xyz{Coordinate(1, 2, 3), Coordinate(4, 5, 6)};
-    CoordinateSequence seq2{CoordinateXYZM(1, 2, 3, 4)};
+        ensure_same(seq_xyz.getOrdinate(0, CoordinateSequence::X), 1);
+        ensure_same(seq_xyz.getOrdinate(0, CoordinateSequence::Y), 2);
+        ensure_same(seq_xyz.getOrdinate(0, CoordinateSequence::Z), 3);
+        ensure_same(seq_xyz.getOrdinate(0, CoordinateSequence::M), DoubleNotANumber);
-    ensure_same(seq2.getOrdinate(0, CoordinateSequence::X), 1);
-    ensure_same(seq2.getOrdinate(0, CoordinateSequence::Y), 2);
-    ensure_same(seq2.getOrdinate(0, CoordinateSequence::Z), 3);
-    ensure_same(seq2.getOrdinate(0, CoordinateSequence::M), 4);
+        ensure_same(seq_xyz.getOrdinate(1, CoordinateSequence::X), 4);
+        ensure_same(seq_xyz.getOrdinate(1, CoordinateSequence::Y), 5);
+        ensure_same(seq_xyz.getOrdinate(1, CoordinateSequence::Z), 6);
+        ensure_same(seq_xyz.getOrdinate(1, CoordinateSequence::M), DoubleNotANumber);
+        CoordinateSequence seq_xyzm{CoordinateXYZM(1, 2, 3, 4), CoordinateXYZM(5, 6, 7, 8)};
+        ensure_same(seq_xyzm.getOrdinate(0, CoordinateSequence::X), 1);
+        ensure_same(seq_xyzm.getOrdinate(0, CoordinateSequence::Y), 2);
+        ensure_same(seq_xyzm.getOrdinate(0, CoordinateSequence::Z), 3);
+        ensure_same(seq_xyzm.getOrdinate(0, CoordinateSequence::M), 4);
+        ensure_same(seq_xyzm.getOrdinate(1, CoordinateSequence::X), 5);
+        ensure_same(seq_xyzm.getOrdinate(1, CoordinateSequence::Y), 6);
+        ensure_same(seq_xyzm.getOrdinate(1, CoordinateSequence::Z), 7);
+        ensure_same(seq_xyzm.getOrdinate(1, CoordinateSequence::M), 8);
 // Test setOrdinate
commit 98ab44a8251d6a0eba2d7d419580d3226a4a4a77
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 11 15:07:43 2023 -0700
    Remove unneeded aliases in CAPI
index 8ed5798a0..922eebf23 100644
@@ -155,17 +155,18 @@ using geos::geom::Coordinate;
 using geos::geom::CoordinateXY;
 using geos::geom::CoordinateXYM;
 using geos::geom::CoordinateXYZM;
+using geos::geom::CoordinateSequence;
+using geos::geom::Envelope;
 using geos::geom::Geometry;
+using geos::geom::GeometryCollection;
+using geos::geom::GeometryFactory;
 using geos::geom::LineString;
 using geos::geom::LinearRing;
 using geos::geom::MultiLineString;
 using geos::geom::MultiPolygon;
+using geos::geom::Point;
 using geos::geom::Polygon;
 using geos::geom::PrecisionModel;
-using geos::geom::CoordinateSequence;
-using geos::geom::GeometryCollection;
-using geos::geom::GeometryFactory;
-using geos::geom::Envelope;
 using geos::io::WKTReader;
 using geos::io::WKTWriter;
@@ -195,8 +196,6 @@ using geos::simplify::PolygonHullSimplifier;
 using geos::util::IllegalArgumentException;
-typedef std::unique_ptr<Geometry> GeomPtr;
 typedef struct GEOSContextHandle_HS {
     const GeometryFactory* geomFactory;
     char msgBuffer[1024];
@@ -209,7 +208,7 @@ typedef struct GEOSContextHandle_HS {
     uint8_t WKBOutputDims;
     int WKBByteOrder;
     int initialized;
-    std::unique_ptr<geos::geom::Point> point2d;
+    std::unique_ptr<Point> point2d;
     GEOSContextHandle_HS()
@@ -224,7 +223,7 @@ typedef struct GEOSContextHandle_HS {
         memset(msgBuffer, 0, sizeof(msgBuffer));
         geomFactory = GeometryFactory::getDefaultInstance();
-        point2d = geomFactory->createPoint(geos::geom::CoordinateXY{0, 0});
+        point2d = geomFactory->createPoint(CoordinateXY{0, 0});
         WKBOutputDims = 2;
         WKBByteOrder = getMachineByteOrder();
         setNoticeHandler(nullptr);
@@ -1099,8 +1098,6 @@ extern "C" {
     GEOSIntersectionPrec_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double gridSize)
         return execute(extHandle, [&]() {
-            using geos::geom::PrecisionModel;
             std::unique_ptr<PrecisionModel> pm;
             if(gridSize != 0) {
                 pm.reset(new PrecisionModel(1.0 / gridSize));
@@ -1515,7 +1512,7 @@ extern "C" {
     GEOSUnaryUnion_r(GEOSContextHandle_t extHandle, const Geometry* g)
-            GeomPtr g3(g->Union());
+            std::unique_ptr<Geometry> g3(g->Union());
             g3->setSRID(g->getSRID());
             return g3.release();
@@ -1559,7 +1556,7 @@ extern "C" {
             // CascadedUnion is the same as UnaryUnion, except that
             // CascadedUnion only works on MultiPolygon, so we just delegate
             // now and retain a check on MultiPolygon type.
-            const geos::geom::MultiPolygon *p = dynamic_cast<const geos::geom::MultiPolygon *>(g1);
+            const MultiPolygon *p = dynamic_cast<const MultiPolygon *>(g1);
             if (!p) {
                 throw IllegalArgumentException("Invalid argument (must be a MultiPolygon)");
@@ -1599,7 +1596,7 @@ extern "C" {
                             m_callback(p_callback),
                             m_userdata(p_userdata) {}
-            void filter_rw(geos::geom::CoordinateXY* c) const final {
+            void filter_rw(CoordinateXY* c) const final {
                 if (!m_callback(&(c->x), &(c->y), m_userdata)) {
                     throw std::runtime_error(std::string("Failed to transform coordinates."));
@@ -1717,8 +1714,6 @@ extern "C" {
     Geometry*
     GEOSGeomGetPointN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
-        using geos::geom::LineString;
             const LineString* ls = dynamic_cast<const LineString*>(g1);
             if(!ls) {
@@ -1737,8 +1732,6 @@ extern "C" {
     Geometry*
     GEOSGeomGetStartPoint_r(GEOSContextHandle_t extHandle, const Geometry* g1)
             if(!ls) {
@@ -1755,8 +1748,6 @@ extern "C" {
     Geometry*
     GEOSGeomGetEndPoint_r(GEOSContextHandle_t extHandle, const Geometry* g1)
             if(!ls) {
@@ -1773,9 +1764,6 @@ extern "C" {
     char
     GEOSisClosed_r(GEOSContextHandle_t extHandle, const Geometry* g1)
-        using geos::geom::MultiLineString;
         return execute(extHandle, 2, [&]() {
             if(ls) {
@@ -1798,8 +1786,6 @@ extern "C" {
     int
     GEOSGeomGetLength_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* length)
             if(!ls) {
@@ -1816,8 +1802,6 @@ extern "C" {
     int
     GEOSGeomGetNumPoints_r(GEOSContextHandle_t extHandle, const Geometry* g1)
         return execute(extHandle, -1, [&]() {
             if(!ls) {
@@ -1834,8 +1818,6 @@ extern "C" {
     int
     GEOSGeomGetX_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* x)
-        using geos::geom::Point;
             if(!po) {
@@ -1853,8 +1835,6 @@ extern "C" {
     int
     GEOSGeomGetY_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* y)
             if(!po) {
@@ -1872,8 +1852,6 @@ extern "C" {
     int
     GEOSGeomGetZ_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* z)
             if(!po) {
@@ -1937,7 +1915,7 @@ extern "C" {
         using geos::shape::fractal::HilbertEncoder;
-            geos::geom::Envelope e = *extent->getEnvelopeInternal();
+            Envelope e = *extent->getEnvelopeInternal();
             HilbertEncoder encoder(level, e);
             *code = encoder.encode(geom->getEnvelopeInternal());
             return 1;
@@ -2462,17 +2440,17 @@ extern "C" {
                 if (hasM) {
                     // XYZM
                     assert(coords->getCoordinateType() == geos::geom::CoordinateType::XYZM);
-                    std::memcpy(coords->data(), buf, size * sizeof(geos::geom::CoordinateXYZM));
+                    std::memcpy(coords->data(), buf, size * sizeof(CoordinateXYZM));
                 } else {
                     // XYZ
                     assert(coords->getCoordinateType() == geos::geom::CoordinateType::XYZ);
-                    std::memcpy(coords->data(), buf, size * sizeof(geos::geom::Coordinate));
+                    std::memcpy(coords->data(), buf, size * sizeof(Coordinate));
             } else {
                 if (hasM) {
                     // XYM
                     for (std::size_t i = 0; i < size; i++) {
-                        coords->setAt(geos::geom::CoordinateXYM{ *buf, *(buf + 1), *(buf + 2)}, i);
+                        coords->setAt(CoordinateXYM{ *buf, *(buf + 1), *(buf + 2)}, i);
                         buf += stride;
                 } else {
@@ -2497,7 +2475,7 @@ extern "C" {
             auto coords = geos::detail::make_unique<geos::geom::CoordinateSequence>(size, hasZ, hasM, false);
-            geos::geom::CoordinateXYZM c;
+            CoordinateXYZM c;
                 c.x = x[i];
                 c.y = y[i];
@@ -2520,7 +2498,7 @@ extern "C" {
                                 double* x, double* y, double* z, double* m)
+            CoordinateXYZM c;
             for (std::size_t i = 0; i < cs->size(); i++) {
                 cs->getAt(i, c);
                 x[i] = c.x;
@@ -2750,8 +2728,6 @@ extern "C" {
     const CoordinateSequence*
     GEOSGeom_getCoordSeq_r(GEOSContextHandle_t extHandle, const Geometry* g)
             const LineString* ls = dynamic_cast<const LineString*>(g);
             if(ls) {
@@ -2795,7 +2771,7 @@ extern "C" {
             GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
             const GeometryFactory* gf = handle->geomFactory;
-            geos::geom::CoordinateXY c(x, y);
+            CoordinateXY c(x, y);
             return gf->createPoint(c).release();
@@ -2846,8 +2822,6 @@ extern "C" {
     Geometry*
     GEOSGeom_createPolygon_r(GEOSContextHandle_t extHandle, Geometry* shell, Geometry** holes, unsigned int nholes)
-        using geos::geom::LinearRing;
@@ -2901,7 +2875,7 @@ extern "C" {
-            geos::geom::Envelope env(xmin, xmax, ymin, ymax);
+            Envelope env(xmin, xmax, ymin, ymax);
             return (gf->toGeometry(&env)).release();
@@ -3074,8 +3048,6 @@ extern "C" {
     WKTReader*
     GEOSWKTReader_create_r(GEOSContextHandle_t extHandle)
-        using geos::io::WKTReader;
             GEOSContextHandleInternal_t *handle = reinterpret_cast<GEOSContextHandleInternal_t *>(extHandle);
             return new WKTReader((GeometryFactory *) handle->geomFactory);
@@ -3811,7 +3783,6 @@ extern "C" {
     int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
                                double Ax, double Ay, double Bx, double By, double Px, double Py)
-        using geos::geom::Coordinate;
         using geos::algorithm::Orientation;
commit f8d92f8460dd452292c070c15908ea326a3de559
Date:   Tue Apr 11 11:58:55 2023 -0700
    Fix spelling mistake for "LessThan", inline some STL container support methods
diff --git a/include/geos/geom/Coordinate.h b/include/geos/geom/Coordinate.h
index 220dd7cef..50763083c 100644
--- a/include/geos/geom/Coordinate.h
+++ b/include/geos/geom/Coordinate.h
@@ -32,7 +32,7 @@ namespace geos {
 namespace geom { // geos.geom
 // Forward declarations
-struct CoordinateLessThen;
+struct CoordinateLessThan;
 class CoordinateXYZM;
 class CoordinateXYM;
 class Coordinate;
@@ -128,8 +128,8 @@ public:
         return equals2D(other);
-    /// TODO: deprecate this, move logic to CoordinateLessThen instead
-    int compareTo(const CoordinateXY& other) const
+    /// TODO: deprecate this, move logic to CoordinateLessThan instead
+    inline int compareTo(const CoordinateXY& other) const
         if(x < other.x) {
             return -1;
@@ -175,7 +175,7 @@ public:
     struct GEOS_DLL HashCode
-        std::size_t operator()(const CoordinateXY& c) const
+        inline std::size_t operator()(const CoordinateXY& c) const
             size_t h = std::hash<double>{}(c.x);
             h ^= std::hash<double>{}(c.y) << 1;
@@ -221,7 +221,7 @@ private:
 public:
     /// A set of const Coordinate pointers
-    typedef std::set<const Coordinate*, CoordinateLessThen> ConstSet;
+    typedef std::set<const Coordinate*, CoordinateLessThan> ConstSet;
     /// A vector of const Coordinate pointers
     typedef std::vector<const Coordinate*> ConstVect;
@@ -425,7 +425,7 @@ CoordinateXYM::operator=(const CoordinateXYZM& other) {
 /// Strict weak ordering Functor for Coordinate
-struct GEOS_DLL CoordinateLessThen {
+struct GEOS_DLL CoordinateLessThan {
     bool operator()(const CoordinateXY* a, const CoordinateXY* b) const
@@ -452,7 +452,7 @@ struct GEOS_DLL CoordinateLessThen {
 /// Strict weak ordering operator for Coordinate
 inline bool operator<(const CoordinateXY& a, const CoordinateXY& b)
-    return CoordinateLessThen()(a, b);
+    return CoordinateLessThan()(a, b);
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 025e11ba9..21da3212a 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -517,7 +517,7 @@ public:
-    using UnorderedSet = std::unordered_set<LineSegment, LineSegment::HashCode>;
+    using UnorderedSet = std::unordered_set<LineSegment, HashCode>;
 private:
diff --git a/include/geos/geomgraph/EdgeIntersectionList.h b/include/geos/geomgraph/EdgeIntersectionList.h
index 915bbc84d..428bbd490 100644
--- a/include/geos/geomgraph/EdgeIntersectionList.h
+++ b/include/geos/geomgraph/EdgeIntersectionList.h
@@ -27,7 +27,7 @@
 #include <string>
 #include <geos/geomgraph/EdgeIntersection.h> // for EdgeIntersectionLessThen
-#include <geos/geom/Coordinate.h> // for CoordinateLessThen
+#include <geos/geom/Coordinate.h> // for CoordinateLessThan
 #ifdef _MSC_VER
 #pragma warning(push)
diff --git a/include/geos/geomgraph/NodeMap.h b/include/geos/geomgraph/NodeMap.h
index a35ab52e3..e30969a79 100644
--- a/include/geos/geomgraph/NodeMap.h
+++ b/include/geos/geomgraph/NodeMap.h
@@ -26,7 +26,7 @@
 #include <vector>
 #include <string>
 #include <geos/geomgraph/Node.h> // for testInvariant
@@ -50,7 +50,7 @@ namespace geomgraph { // geos.geomgraph
 class GEOS_DLL NodeMap {
 public:
-    typedef std::map<geom::Coordinate*, std::unique_ptr<Node>, geom::CoordinateLessThen> container;
+    typedef std::map<geom::Coordinate*, std::unique_ptr<Node>, geom::CoordinateLessThan> container;
     typedef container::iterator iterator;
diff --git a/include/geos/operation/relate/RelateNodeGraph.h b/include/geos/operation/relate/RelateNodeGraph.h
index d409d9712..5a13cc744 100644
--- a/include/geos/operation/relate/RelateNodeGraph.h
+++ b/include/geos/operation/relate/RelateNodeGraph.h
@@ -28,7 +28,7 @@
 namespace geos {
 namespace geom {
 class Coordinate;
 //class EdgeEndStar;
diff --git a/include/geos/planargraph/NodeMap.h b/include/geos/planargraph/NodeMap.h
index e6e3de8b0..aa39db07b 100644
--- a/include/geos/planargraph/NodeMap.h
+++ b/include/geos/planargraph/NodeMap.h
@@ -46,7 +46,7 @@ namespace planargraph { // geos.planargraph
 public:
-    typedef std::map<geom::Coordinate, Node*, geom::CoordinateLessThen> container;
+    typedef std::map<geom::Coordinate, Node*, geom::CoordinateLessThan> container;
 private:
     container nodeMap;
 public:
diff --git a/include/geos/util/UniqueCoordinateArrayFilter.h b/include/geos/util/UniqueCoordinateArrayFilter.h
index 89a25a692..17371169a 100644
--- a/include/geos/util/UniqueCoordinateArrayFilter.h
+++ b/include/geos/util/UniqueCoordinateArrayFilter.h
@@ -82,7 +82,7 @@ public:
 private:
     std::vector<const geom::Coordinate*>& pts;	// target set reference
-    std::set<const geom::CoordinateXY*, geom::CoordinateLessThen> uniqPts; 	// unique points set
+    std::set<const geom::CoordinateXY*, geom::CoordinateLessThan> uniqPts; 	// unique points set
     // Declare type as noncopyable
     UniqueCoordinateArrayFilter(const UniqueCoordinateArrayFilter& other) = delete;
diff --git a/src/triangulate/DelaunayTriangulationBuilder.cpp b/src/triangulate/DelaunayTriangulationBuilder.cpp
index 78c38bc58..424de2a13 100644
--- a/src/triangulate/DelaunayTriangulationBuilder.cpp
+++ b/src/triangulate/DelaunayTriangulationBuilder.cpp
@@ -47,7 +47,7 @@ std::unique_ptr<CoordinateSequence>
 DelaunayTriangulationBuilder::unique(const CoordinateSequence* seq)
     auto sortedSeq = detail::make_unique<CoordinateSequence>(*seq);
-    std::sort(sortedSeq->items<Coordinate>().begin(), sortedSeq->items<Coordinate>().end(), geos::geom::CoordinateLessThen());
+    std::sort(sortedSeq->items<Coordinate>().begin(), sortedSeq->items<Coordinate>().end(), geos::geom::CoordinateLessThan());
     operation::valid::RepeatedPointTester rpt;
     if (rpt.hasRepeatedPoint(sortedSeq.get())) {
Summary of changes:
 NEWS.md                                            |  1 +
 capi/geos_c.cpp                                    | 10 +++
 capi/geos_c.h.in                                   | 17 +++++
 capi/geos_ts_c.cpp                                 | 82 ++++++++++------------
 include/geos/geom/Coordinate.h                     | 14 ++--
 include/geos/geom/LineSegment.h                    |  2 +-
 include/geos/geom/Point.h                          |  1 +
 include/geos/geomgraph/EdgeIntersectionList.h      |  2 +-
 include/geos/geomgraph/NodeMap.h                   |  4 +-
 include/geos/operation/relate/RelateNodeGraph.h    |  2 +-
 include/geos/planargraph/NodeMap.h                 |  2 +-
 include/geos/util/UniqueCoordinateArrayFilter.h    |  2 +-
 src/geom/CoordinateSequence.cpp                    |  4 +-
 src/geom/Point.cpp                                 | 11 ++-
 src/triangulate/DelaunayTriangulationBuilder.cpp   |  2 +-
 ...SGeomGetXYZTest.cpp => GEOSGeomGetXYZMTest.cpp} | 51 ++++++++++++--
 .../capi/GEOSGeom_getCoordinateDimensionTest.cpp   |  4 +-
 tests/unit/capi/GEOSGeom_getDimensionsTest.cpp     |  2 +-
 tests/unit/geom/CoordinateSequenceTest.cpp         | 65 ++++++++++++++---
 19 files changed, 196 insertions(+), 82 deletions(-)
 rename tests/unit/capi/{GEOSGeomGetXYZTest.cpp => GEOSGeomGetXYZMTest.cpp} (53%)
hooks/post-receive
More information about the geos-commits mailing list
