[geos-commits] [SCM] GEOS branch main updated. 93540f4c27b6eff81e51203f52b585a7872f884b
Wed Apr 12 16:54:36 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  93540f4c27b6eff81e51203f52b585a7872f884b (commit)
       via  d3d9df75e81ec3b5612936023b53bb0285942f97 (commit)
      from  03ef7e3cc1fa06017c9eb5fb35dbfc39c4844ca3 (commit)
revisions in full, below.
commit 93540f4c27b6eff81e51203f52b585a7872f884b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Apr 12 16:54:08 2023 -0700
    Add geosop coverageSimplify
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index 1eb8398eb..228e6b116 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -41,6 +41,7 @@
 #include <geos/operation/buffer/OffsetCurve.h>
 #include <geos/operation/cluster/GeometryDistanceClusterFinder.h>
 #include <geos/operation/cluster/GeometryIntersectsClusterFinder.h>
+#include <geos/coverage/CoverageSimplifier.h>
 #include <geos/coverage/CoverageValidator.h>
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/operation/distance/DistanceOp.h>
@@ -106,6 +107,14 @@ struct GeometryOpCreator {
     std::function<GeometryOp *( std::string name )> create;
+std::vector<const Geometry*> toList(const std::unique_ptr<Geometry>& geom) {
+    std::vector<const Geometry*> geomList;
+    for (std::size_t i = 0; i < geom->getNumGeometries(); i++) {
+        geomList.emplace_back( geom->getGeometryN(i));
+    return geomList;
 * Static array of operation definitions.
 * All metadata for an operation is defined here.
@@ -838,6 +847,20 @@ std::vector<GeometryOpCreator> opRegistry {
 //=============  category: Polygonal Coverage  ==================
+{"coverageSimplify", [](std::string name) { return GeometryOp::createAgg(name,
+    catCoverage, "simplify a polygonal coverage by a distance tolerance",
+    [](const std::unique_ptr<Geometry>& geom, double d) {
+        std::vector<const Geometry*> coverage = toList(geom);
+        std::vector<std::unique_ptr<Geometry>> result
+            = geos::coverage::CoverageSimplifier::simplify(coverage, d);
+        //-- convert list type (be nice to avoid this)
+        std::vector<std::unique_ptr<const Geometry>> resultList;
+        for (std::size_t i = 0; i < result.size(); i++) {
+            resultList.emplace_back( std::move(result[i]) );
+        return new Result( std::move(resultList) );
 {"coverageUnionNG", [](std::string name) { return GeometryOp::createAgg(name,
     catCoverage, "union a polygonal coverage",
     [](const std::unique_ptr<Geometry>& geom) {
@@ -853,16 +876,11 @@ std::vector<GeometryOpCreator> opRegistry {
 {"coverageValidate", [](std::string name) { return GeometryOp::createAgg(name,
     catCoverage, "validate a polygonal coverage",
-        //-- create list of input polygons
-        std::vector<const Geometry*> coverage;
-        for (std::size_t i = 0; i < geom->getNumGeometries(); i++) {
-            coverage.emplace_back( geom->getGeometryN(i));
         std::vector<std::unique_ptr<Geometry>> invalidList
             = geos::coverage::CoverageValidator::validate(coverage);
-        //-- create GeometryCollection from result list
+        // result may contain nulls, so remove them
         for (std::size_t i = 0; i < invalidList.size(); i++) {
             if (invalidList[i] != nullptr) {
@@ -1041,7 +1059,7 @@ Result::toString() {
     case typeGeomList:
        return metadata();
-    return "Value for Unknonwn type";
+    return "Value for Unknown type";
 std::string
commit d3d9df75e81ec3b5612936023b53bb0285942f97
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Apr 12 16:03:50 2023 -0700
    Finish up marking since on CAPI, closes #854
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index a1cb103a0..bc583020e 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -310,17 +310,20 @@ typedef void (GEOSInterruptCallback)(void);
 * \param cb Callback function to invoke
 * \return the previously configured callback
 * \see GEOSInterruptCallback
+* \since 3.4
 extern GEOSInterruptCallback GEOS_DLL *GEOS_interruptRegisterCallback(
     GEOSInterruptCallback* cb);
 * Request safe interruption of operations
+* \since 3.4
 extern void GEOS_DLL GEOS_interruptRequest(void);
 * Cancel a pending interruption request
+* \since 3.4
 extern void GEOS_DLL GEOS_interruptCancel(void);
@@ -2005,6 +2008,7 @@ extern void GEOS_DLL GEOSFree_r(
 * This function does not have a reentrant variant and is
 * available if `GEOS_USE_ONLY_R_API` is defined.
 * \return version string
+* \since 2.2
 extern const char GEOS_DLL *GEOSversion(void);
@@ -2032,6 +2036,7 @@ extern const char GEOS_DLL *GEOSversion(void);
 * \param notice_function Handle notice messages
 * \param error_function Handle error messages
+* \since 2.2
 extern void GEOS_DLL initGEOS(
     GEOSMessageHandler notice_function,
@@ -2040,6 +2045,7 @@ extern void GEOS_DLL initGEOS(
 * For non-reentrant code, call when all GEOS operations are complete,
 * cleans up global resources.
+* \since 3.1
 extern void GEOS_DLL finishGEOS(void);
@@ -2048,6 +2054,7 @@ extern void GEOS_DLL finishGEOS(void);
 * as GEOSWKBWriter_write(),
 * GEOSWKBWriter_writeHEX() and GEOSWKTWriter_write(), etc.
 * \param buffer The memory to free
+* \since 3.1
 extern void GEOS_DLL GEOSFree(void *buffer);
@@ -2065,6 +2072,7 @@ extern void GEOS_DLL GEOSFree(void *buffer);
 * \param size number of coordinates in the sequence
 * \param dims dimensionality of the coordinates (2, 3 or 4)
 * \return the sequence or NULL on exception
+* \since 2.2
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create(unsigned int size, unsigned int dims);
@@ -2122,12 +2130,14 @@ extern int GEOS_DLL GEOSCoordSeq_copyToArrays(const GEOSCoordSequence* s, double
 * Clone a coordinate sequence.
 * \param s the coordinate sequence to clone
 * \return a copy of the coordinate sequence or NULL on exception
+* \since 2.2
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_clone(const GEOSCoordSequence* s);
 * Destroy a coordinate sequence, freeing all memory.
 * \param s the coordinate sequence to destroy
+* \since 2.2
 extern void GEOS_DLL GEOSCoordSeq_destroy(GEOSCoordSequence* s);
@@ -2137,6 +2147,7 @@ extern void GEOS_DLL GEOSCoordSeq_destroy(GEOSCoordSequence* s);
 * \param idx the index of the coordinate to alter, zero based
 * \param val the value to set the ordinate to
 * \return 0 on exception
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_setX(GEOSCoordSequence* s,
     unsigned int idx, double val);
@@ -2146,6 +2157,7 @@ extern int GEOS_DLL GEOSCoordSeq_setX(GEOSCoordSequence* s,
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_setY(GEOSCoordSequence* s,
@@ -2155,6 +2167,7 @@ extern int GEOS_DLL GEOSCoordSeq_setY(GEOSCoordSequence* s,
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_setZ(GEOSCoordSequence* s,
@@ -2190,6 +2203,7 @@ extern int GEOS_DLL GEOSCoordSeq_setXYZ(GEOSCoordSequence* s,
 * \param dim the dimension number of the ordinate to alter, zero based
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_setOrdinate(GEOSCoordSequence* s,
     unsigned int idx, unsigned int dim, double val);
@@ -2200,6 +2214,7 @@ extern int GEOS_DLL GEOSCoordSeq_setOrdinate(GEOSCoordSequence* s,
 * \param val pointer where ordinate value will be placed
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_getX(const GEOSCoordSequence* s,
     unsigned int idx, double *val);
@@ -2210,6 +2225,7 @@ extern int GEOS_DLL GEOSCoordSeq_getX(const GEOSCoordSequence* s,
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_getY(const GEOSCoordSequence* s,
@@ -2219,6 +2235,7 @@ extern int GEOS_DLL GEOSCoordSeq_getY(const GEOSCoordSequence* s,
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_getZ(const GEOSCoordSequence* s,
@@ -2254,6 +2271,7 @@ extern int GEOS_DLL GEOSCoordSeq_getXYZ(const GEOSCoordSequence* s,
 * \param[in] dim the dimension number of the ordinate to read, zero based
 * \param[out] val pointer where ordinate value will be placed
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_getOrdinate(const GEOSCoordSequence* s,
     unsigned int idx, unsigned int dim, double *val);
@@ -2263,6 +2281,7 @@ extern int GEOS_DLL GEOSCoordSeq_getOrdinate(const GEOSCoordSequence* s,
 * \param[in] s the coordinate sequence
 * \param[out] size pointer where size value will be placed
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_getSize(
@@ -2273,6 +2292,7 @@ extern int GEOS_DLL GEOSCoordSeq_getSize(
 * \param[out] dims pointer where dimension value will be placed
+* \since 2.2
 extern int GEOS_DLL GEOSCoordSeq_getDimensions(
@@ -2306,6 +2326,7 @@ extern int GEOS_DLL GEOSCoordSeq_isCCW(
 * \param s Input coordinate sequence, ownership passes to the geometry
 * \return A newly allocated point geometry. NULL on exception.
 * Caller is responsible for freeing with GEOSGeom_destroy().
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint(GEOSCoordSequence* s);
@@ -2334,6 +2355,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint(void);
 * \return A newly allocated linear ring geometry. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
@@ -2342,6 +2364,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
 * \return A newly allocated linestring geometry. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString(GEOSCoordSequence* s);
@@ -2374,6 +2397,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon(void);
 *       The caller **retains ownership** of the containing array,
 *       but the ownership of the pointed-to objects is transferred
 *       to the returned \ref GEOSGeometry.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(
     GEOSGeometry* shell,
@@ -2391,6 +2415,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(
     int type,
@@ -2426,12 +2451,14 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createRectangle(
 * \param g The geometry to copy
 * \return A newly allocated geometry. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGeom_clone(const GEOSGeometry* g);
 * Release the memory associated with a geometry.
 * \param g The geometry to be destroyed.
+* \since 2.2
 extern void GEOS_DLL GEOSGeom_destroy(GEOSGeometry* g);
@@ -2450,6 +2477,7 @@ extern void GEOS_DLL GEOSGeom_destroy(GEOSGeometry* g);
 * \return A string with the geometry type.
 * Caller must free with GEOSFree().
 * NULL on exception.
+* \since 2.2
 extern char GEOS_DLL *GEOSGeomType(const GEOSGeometry* g);
@@ -2457,6 +2485,7 @@ extern char GEOS_DLL *GEOSGeomType(const GEOSGeometry* g);
 * Returns the \ref GEOSGeomTypeId number for this geometry.
 * \param g Input geometry
 * \return The geometry type number, or -1 on exception.
+* \since 2.2
 extern int GEOS_DLL GEOSGeomTypeId(const GEOSGeometry* g);
@@ -2464,6 +2493,7 @@ extern int GEOS_DLL GEOSGeomTypeId(const GEOSGeometry* g);
 * Returns the "spatial reference id" (SRID) for this geometry.
 * \return SRID number or 0 if unknown / not set.
+* \since 2.2
 extern int GEOS_DLL GEOSGetSRID(const GEOSGeometry* g);
@@ -2487,6 +2517,7 @@ extern void GEOS_DLL *GEOSGeom_getUserData(const GEOSGeometry* g);
 * \return Number of direct children in this collection
 * \warning For GEOS < 3.2 this function may crash when fed simple geometries
+* \since 2.2
 extern int GEOS_DLL GEOSGetNumGeometries(const GEOSGeometry* g);
@@ -2503,6 +2534,7 @@ extern int GEOS_DLL GEOSGetNumGeometries(const GEOSGeometry* g);
 * \note Up to GEOS 3.2.0 the input geometry must be a Collection, in
 *       later versions it doesn't matter (getGeometryN(0) for a single will
 *       return the input).
+* \since 2.2
 extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN(
     const GEOSGeometry* g,
@@ -2524,6 +2556,7 @@ extern double GEOS_DLL GEOSGeom_getPrecision(const GEOSGeometry *g);
 * an exception otherwise.
 * \param g Input Polygon geometry
 * \return Number of interior rings, -1 on exception
+* \since 2.2
 extern int GEOS_DLL GEOSGetNumInteriorRings(const GEOSGeometry* g);
@@ -2532,6 +2565,7 @@ extern int GEOS_DLL GEOSGetNumInteriorRings(const GEOSGeometry* g);
 * \param g Input LineString geometry
 * \return Number of points, -1 on exception
+* \since 2.2
 extern int GEOS_DLL GEOSGeomGetNumPoints(const GEOSGeometry* g);
@@ -2541,6 +2575,7 @@ extern int GEOS_DLL GEOSGeomGetNumPoints(const GEOSGeometry* g);
 * \param[in] g Input Point geometry
 * \param[out] x Pointer to hold return value
 * \returns 1 on success, 0 on exception
+* \since 2.2
 extern int GEOS_DLL GEOSGeomGetX(const GEOSGeometry *g, double *x);
@@ -2550,6 +2585,7 @@ extern int GEOS_DLL GEOSGeomGetX(const GEOSGeometry *g, double *x);
 * \param[out] y Pointer to hold return value
+* \since 2.2
 extern int GEOS_DLL GEOSGeomGetY(const GEOSGeometry *g, double *y);
@@ -2582,6 +2618,7 @@ extern int GEOS_DLL GEOSGeomGetM(const GEOSGeometry *g, double *m);
 * \param n Index of the desired ring
 * \return LinearRing geometry. Owned by parent geometry, do not free. NULL on exception.
+* \since 2.2
 extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN(
@@ -2593,6 +2630,7 @@ extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN(
 *       it must NOT be destroyed directly.
+* \since 2.2
 extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing(
@@ -2602,6 +2640,7 @@ extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing(
 * of any type.
 * \return Number of points in the geometry. -1 on exception.
+* \since 2.2
 extern int GEOS_DLL GEOSGetNumCoordinates(
@@ -2613,6 +2652,7 @@ extern int GEOS_DLL GEOSGetNumCoordinates(
 * the parent geometry.
 * \return Coordinate sequence or NULL on exception.
+* \since 2.2
 extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq(
@@ -2627,6 +2667,7 @@ extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq(
 * \see geos::geom::Dimension::DimensionType
 * \return The dimensionality
+* \since 2.2
 extern int GEOS_DLL GEOSGeom_getDimensions(
@@ -2712,6 +2753,7 @@ extern int GEOS_DLL GEOSGeom_getExtent(
 * \return A Point geometry.
 *         Caller must free with GEOSGeom_destroy()
+* \since 3.3
 extern GEOSGeometry GEOS_DLL *GEOSGeomGetPointN(const GEOSGeometry *g, int n);
@@ -2721,6 +2763,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeomGetPointN(const GEOSGeometry *g, int n);
+* \since 3.3
 extern GEOSGeometry GEOS_DLL *GEOSGeomGetStartPoint(const GEOSGeometry *g);
@@ -2730,6 +2773,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeomGetStartPoint(const GEOSGeometry *g);
+* \since 3.3
 extern GEOSGeometry GEOS_DLL *GEOSGeomGetEndPoint(const GEOSGeometry *g);
@@ -2740,6 +2784,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeomGetEndPoint(const GEOSGeometry *g);
 * has no boundary or interior.
 * \param g The geometry to test
 * \return 1 on true, 0 on false, 2 on exception
+* \since 2.2
 extern char GEOS_DLL GEOSisEmpty(const GEOSGeometry* g);
@@ -2749,6 +2794,7 @@ extern char GEOS_DLL GEOSisEmpty(const GEOSGeometry* g);
 * with start and end point being identical.
+* \since 2.2
 extern char GEOS_DLL GEOSisRing(const GEOSGeometry* g);
@@ -2756,6 +2802,7 @@ extern char GEOS_DLL GEOSisRing(const GEOSGeometry* g);
 * Tests whether the input geometry has Z coordinates.
+* \since 2.2
 extern char GEOS_DLL GEOSHasZ(const GEOSGeometry* g);
@@ -2774,6 +2821,7 @@ extern char GEOS_DLL GEOSHasM(const GEOSGeometry* g);
 * with the start and end points being the same.
+* \since 3.3
 extern char GEOS_DLL GEOSisClosed(const GEOSGeometry *g);
@@ -2789,6 +2837,7 @@ extern char GEOS_DLL GEOSisClosed(const GEOSGeometry *g);
 * Set the "spatial reference id" (SRID) for this geometry.
 * \param SRID SRID number or 0 for unknown SRID.
+* \since 2.2
 extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
@@ -2818,6 +2867,7 @@ extern void GEOS_DLL GEOSGeom_setUserData(GEOSGeometry* g, void* userData);
 * Use before calling \ref GEOSEqualsExact to avoid false "not equal" results.
 * \return 0 on success or -1 on exception
+* \since 3.0
 extern int GEOS_DLL GEOSNormalize(GEOSGeometry* g);
@@ -2835,6 +2885,7 @@ and geometric quality.
 * linestrings. A "simple" linestring has no self-intersections.
+* \since 2.2
 extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g);
@@ -2849,6 +2900,7 @@ extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g);
 * \see geos::operation::valid::isValidOp
+* \since 2.2
 extern char GEOS_DLL GEOSisValid(const GEOSGeometry* g);
@@ -2857,7 +2909,7 @@ extern char GEOS_DLL GEOSisValid(const GEOSGeometry* g);
 * "Valid Geometry" string otherwise, or NULL on exception.
 * \return A string with the reason, NULL on exception.
-          Caller must GEOSFree() their result.
+*         Caller must GEOSFree() their result.
 * \since 3.1
@@ -3023,6 +3075,7 @@ extern GEOSGeometry GEOS_DLL *GEOSRemoveRepeatedPoints(
 * \param[in] g Input geometry
 * \param[out] area Pointer to be filled in with area result
 * \return 1 on success, 0 on exception.
+* \since 2.2
 extern int GEOS_DLL GEOSArea(
@@ -3033,6 +3086,7 @@ extern int GEOS_DLL GEOSArea(
 * \param[out] length Pointer to be filled in with length result
+* \since 2.2
 extern int GEOS_DLL GEOSLength(
@@ -3045,6 +3099,7 @@ extern int GEOS_DLL GEOSLength(
+* \since 3.3
 extern int GEOS_DLL GEOSGeomGetLength(
@@ -3065,6 +3120,7 @@ extern int GEOS_DLL GEOSGeomGetLength(
 * \param[in] g2 Input geometry
 * \param[out] dist Pointer to be filled in with distance result
+* \since 2.2
 extern int GEOS_DLL GEOSDistance(
     const GEOSGeometry* g1,
@@ -3128,6 +3184,7 @@ extern GEOSCoordSequence GEOS_DLL *GEOSNearestPoints(
 * \see geos::algorithm::distance::DiscreteHausdorffDistance
+* \since 3.2
 extern int GEOS_DLL GEOSHausdorffDistance(
     const GEOSGeometry *g1,
@@ -3146,6 +3203,7 @@ extern int GEOS_DLL GEOSHausdorffDistance(
+* \since 3.2
 extern int GEOS_DLL GEOSHausdorffDistanceDensify(
@@ -3209,6 +3267,7 @@ extern int GEOS_DLL GEOSFrechetDistanceDensify(
 * \return distance along line that point projects to, -1 on exception
 * \note Line parameter must be a LineString.
+* \since 3.2
 extern double GEOS_DLL GEOSProject(const GEOSGeometry* line,
                                    const GEOSGeometry* point);
@@ -3222,6 +3281,7 @@ extern double GEOS_DLL GEOSProject(const GEOSGeometry* line,
 * \param d distance from start of line to created point
 * \return The point \ref GEOSGeometry that is distance from the start of line.
 * Caller takes ownership of returned geometry.
+* \since 3.2
 extern GEOSGeometry GEOS_DLL *GEOSInterpolate(const GEOSGeometry* line,
                                               double d);
@@ -3234,6 +3294,7 @@ extern GEOSGeometry GEOS_DLL *GEOSInterpolate(const GEOSGeometry* line,
 * \param point the point to project
 * \return The proportion of the overall line length that the projected
 * point falls at.
+* \since 3.2
 extern double GEOS_DLL GEOSProjectNormalized(const GEOSGeometry* line,
@@ -3245,6 +3306,7 @@ extern double GEOS_DLL GEOSProjectNormalized(const GEOSGeometry* line,
 * \param proportion The proportion from the start of line to created point
+* \since 3.2
 extern GEOSGeometry GEOS_DLL *GEOSInterpolateNormalized(
     const GEOSGeometry *line,
@@ -3267,6 +3329,7 @@ extern GEOSGeometry GEOS_DLL *GEOSInterpolateNormalized(
 * \return A newly allocated geometry of the intersection. NULL on exception.
 * \see geos::operation::overlayng::OverlayNG
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSIntersection(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -3294,6 +3357,7 @@ extern GEOSGeometry GEOS_DLL *GEOSIntersectionPrec(const GEOSGeometry* g1, const
 * \return A newly allocated geometry of the difference. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSDifference(
     const GEOSGeometry* ga,
@@ -3328,6 +3392,7 @@ extern GEOSGeometry GEOS_DLL *GEOSDifferencePrec(
 * \return A newly allocated geometry of the symmetric difference. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSSymDifference(
@@ -3362,6 +3427,7 @@ extern GEOSGeometry GEOS_DLL *GEOSSymDifferencePrec(
 * \return A newly allocated geometry of the union. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSUnion(
@@ -3502,6 +3568,7 @@ extern GEOSGeometry GEOS_DLL *GEOSSharedPaths(
 *        segments provides a more "precise" buffer at the expense of size.
 * \return A \ref GEOSGeometry of the buffered result.
 * NULL on exception. Caller is responsible for freeing with GEOSGeom_destroy().
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSBuffer(const GEOSGeometry* g,
     double width, int quadsegs);
@@ -3664,6 +3731,7 @@ extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
 * \param g The geometry to calculate an envelope for
 * \return A newly allocated polygonal envelope or point. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSEnvelope(const GEOSGeometry* g);
@@ -3678,6 +3746,7 @@ extern GEOSGeometry GEOS_DLL *GEOSEnvelope(const GEOSGeometry* g);
 * \param g The input geometry
 * \return A newly allocated geometry of the boundary. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSBoundary(const GEOSGeometry* g);
@@ -3688,6 +3757,7 @@ extern GEOSGeometry GEOS_DLL *GEOSBoundary(const GEOSGeometry* g);
 * \return A newly allocated geometry of the convex hull. NULL on exception.
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSConvexHull(const GEOSGeometry* g);
@@ -3795,6 +3865,8 @@ extern GEOSGeometry GEOS_DLL *GEOSConcaveHullByLength(
 * \see geos::algorithm::hull::ConcaveHullOfPolygons
 * \see GEOSConcaveHull
 * \see GEOSConvexHull
+* \since 3.11
 extern GEOSGeometry GEOS_DLL *GEOSConcaveHullOfPolygons(
@@ -3962,6 +4034,8 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth(const GEOSGeometry* g);
 * \return A point that is inside the input
 * \see geos::algorithm::InteriorPointArea
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
@@ -3971,6 +4045,8 @@ extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
 * \return A point at the center of mass of the input
 * \see geos::algorithm::Centroid
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSGetCentroid(const GEOSGeometry* g);
@@ -4119,6 +4195,8 @@ extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
 * \return The polygonal output geometry.
 * \see geos::operation::polygonize::Polygonizer
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSPolygonize(
     const GEOSGeometry * const geoms[],
@@ -4222,6 +4300,7 @@ extern GEOSGeometry GEOS_DLL *GEOSDensify(
 * \return The merged linework
 * \see geos::operation::linemerge::LineMerger
+* \since 2.2
 extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
@@ -4432,6 +4511,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision(
 * \param g2 Input geometry
 * \returns 1 on true, 0 on false, 2 on exception
 * \see geos::geom::Geometry::disjoint
+* \since 2.2
 extern char GEOS_DLL GEOSDisjoint(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4442,6 +4522,7 @@ extern char GEOS_DLL GEOSDisjoint(const GEOSGeometry* g1, const GEOSGeometry* g2
 * \see geos::geom::Geometry::touches
+* \since 2.2
 extern char GEOS_DLL GEOSTouches(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4451,6 +4532,7 @@ extern char GEOS_DLL GEOSTouches(const GEOSGeometry* g1, const GEOSGeometry* g2)
 * \see geos::geom::Geometry::intersects
+* \since 2.2
 extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4461,6 +4543,7 @@ extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry*
 * \see geos::geom::Geometry::crosses
+* \since 2.2
 extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4471,6 +4554,7 @@ extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2)
 * \see geos::geom::Geometry::within
+* \since 2.2
 extern char GEOS_DLL GEOSWithin(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4480,6 +4564,7 @@ extern char GEOS_DLL GEOSWithin(const GEOSGeometry* g1, const GEOSGeometry* g2);
 * \see geos::geom::Geometry::contains
+* \since 2.2
 extern char GEOS_DLL GEOSContains(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4490,6 +4575,7 @@ extern char GEOS_DLL GEOSContains(const GEOSGeometry* g1, const GEOSGeometry* g2
 * \see geos::geom::Geometry::overlaps
+* \since 2.2
 extern char GEOS_DLL GEOSOverlaps(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4499,6 +4585,7 @@ extern char GEOS_DLL GEOSOverlaps(const GEOSGeometry* g1, const GEOSGeometry* g2
 * \see geos::geom::Geometry::equals
+* \since 2.2
 extern char GEOS_DLL GEOSEquals(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -4541,6 +4628,7 @@ extern char GEOS_DLL GEOSCoveredBy(const GEOSGeometry* g1, const GEOSGeometry* g
 * \param tolerance Tolerance to determine vertex equality
 * \see GEOSNormalize()
+* \since 3.0
 extern char GEOS_DLL GEOSEqualsExact(
@@ -4574,6 +4662,7 @@ extern char GEOS_DLL GEOSEqualsIdentical(
 * \param g2 Second geometry in pair
 * \param pat DE9IM pattern to check
+* \since 2.2
 extern char GEOS_DLL GEOSRelatePattern(
@@ -4587,6 +4676,7 @@ extern char GEOS_DLL GEOSRelatePattern(
 * \return DE9IM string. Caller is responsible for freeing with GEOSFree().
 *         NULL on exception
+* \since 2.2
 extern char GEOS_DLL *GEOSRelate(
@@ -5033,8 +5123,8 @@ extern void GEOS_DLL GEOSSTRtree_iterate(
  * \return 0 if the item was not removed;
  *         1 if the item was removed;
  *         2 if an exception occurred
-* \since 3.2
+ * \since 3.2
 extern char GEOS_DLL GEOSSTRtree_remove(
     GEOSSTRtree *tree,
@@ -5117,12 +5207,14 @@ extern int GEOS_DLL GEOSOrientationIndex(
 * Allocate a new \ref GEOSWKTReader.
 * \returns a new reader. Caller must free with GEOSWKTReader_destroy()
+* \since 3.0
 extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create(void);
 * Free the memory associated with a \ref GEOSWKTReader.
 * \param reader The reader to destroy.
+* \since 3.0
 extern void GEOS_DLL GEOSWKTReader_destroy(GEOSWKTReader* reader);
@@ -5132,6 +5224,7 @@ extern void GEOS_DLL GEOSWKTReader_destroy(GEOSWKTReader* reader);
 * \param reader A WKT reader object, caller retains ownership
 * \param wkt The WKT string to parse, caller retains ownership
 * \return A \ref GEOSGeometry, caller to free with GEOSGeom_destroy())
+* \since 3.0
 extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read(
     GEOSWKTReader* reader,
@@ -5154,12 +5247,14 @@ extern void GEOS_DLL GEOSWKTReader_setFixStructure(
 * Allocate a new \ref GEOSWKTWriter.
 * \returns a new writer. Caller must free with GEOSWKTWriter_destroy()
+* \since 3.0
 extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create(void);
 * Free the memory associated with a \ref GEOSWKTWriter.
 * \param writer The writer to destroy.
+* \since 3.0
 extern void GEOS_DLL GEOSWKTWriter_destroy(
     GEOSWKTWriter* writer);
@@ -5171,6 +5266,7 @@ extern void GEOS_DLL GEOSWKTWriter_destroy(
 * \return A newly allocated string containing the WKT output or NULL on exception.
+* \since 3.0
 extern char GEOS_DLL *GEOSWKTWriter_write(
     GEOSWKTWriter* writer,
@@ -5247,12 +5343,14 @@ extern void GEOS_DLL GEOSWKTWriter_setOld3D(
 * Allocate a new \ref GEOSWKBReader.
 * \returns a new reader. Caller must free with GEOSWKBReader_destroy()
+* \since 3.0
 extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create(void);
 * Free the memory associated with a \ref GEOSWKBReader.
+* \since 3.0
 extern void GEOS_DLL GEOSWKBReader_destroy(
     GEOSWKBReader* reader);
@@ -5275,6 +5373,7 @@ extern void GEOS_DLL GEOSWKBReader_setFixStructure(
 * \param wkb A pointer to the buffer to read from
 * \param size The number of bytes of data in the buffer
 * \return A \ref GEOSGeometry built from the WKB, or NULL on exception.
+* \since 3.0
 extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(
     GEOSWKBReader* reader,
@@ -5287,6 +5386,7 @@ extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(
 * \param hex A pointer to the buffer to read from
 * \return A \ref GEOSGeometry built from the HEX WKB, or NULL on exception.
+* \since 3.0
 extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(
@@ -5298,12 +5398,14 @@ extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(
 * Allocate a new \ref GEOSWKBWriter.
 * \returns a new writer. Caller must free with GEOSWKBWriter_destroy()
+* \since 3.0
 extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create(void);
 * Free the memory associated with a \ref GEOSWKBWriter.
+* \since 3.0
 extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
@@ -5314,6 +5416,7 @@ extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
 * \param g Geometry to convert to WKB
 * \param size Pointer to write the size of the final output WKB to
 * \return The WKB representation. Caller must free with GEOSFree()
+* \since 3.0
 extern unsigned char GEOS_DLL *GEOSWKBWriter_write(
     GEOSWKBWriter* writer,
@@ -5327,6 +5430,7 @@ extern unsigned char GEOS_DLL *GEOSWKBWriter_write(
 * \return The HEX WKB representation. Caller must free with GEOSFree()
+* \since 3.0
 extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX(
@@ -5339,6 +5443,7 @@ extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX(
 * Return current number of dimensions.
 * \param writer The writer to read from.
 * \return Number of dimensions (2, 3, or 4)
+* \since 3.0
 extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(
     const GEOSWKBWriter* writer);
@@ -5348,6 +5453,7 @@ extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(
 * 2, 3, or 4 dimensions.
 * \param newDimension The dimensionality desired
+* \since 3.0
 extern void GEOS_DLL GEOSWKBWriter_setOutputDimension(
@@ -5360,6 +5466,7 @@ extern void GEOS_DLL GEOSWKBWriter_setOutputDimension(
 * The return value is a member of \ref GEOSWKBByteOrders.
 * \param writer The writer to read byte order from
 * \return The current byte order
+* \since 3.0
 extern int GEOS_DLL GEOSWKBWriter_getByteOrder(
@@ -5369,6 +5476,7 @@ extern int GEOS_DLL GEOSWKBWriter_getByteOrder(
 * a value from \ref GEOSWKBByteOrders enum.
 * \param writer The writer to set byte order on
 * \param byteOrder Desired byte order
+* \since 3.0
 extern void GEOS_DLL GEOSWKBWriter_setByteOrder(
@@ -5406,6 +5514,7 @@ extern void GEOS_DLL GEOSWKBWriter_setFlavor(
 * Read the current SRID embedding value from the writer.
 * \param writer The writer to check SRID value on
+* \since 3.0
 extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID(
@@ -5415,6 +5524,7 @@ extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID(
 * Many WKB readers do not support SRID values, use with caution.
 * \param writer The writer to set SRID output on
 * \param writeSRID Set to 1 to include SRID, 0 otherwise
+* \since 3.0
 extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID(
Summary of changes:
 capi/geos_c.h.in           | 116 +++++++++++++++++++++++++++++++++++++++++++--
 util/geosop/GeometryOp.cpp |  34 +++++++++----
 2 files changed, 139 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
