[geos-commits] [SCM] GEOS branch main updated. fb8c78acbf351ac1e124d2a872f997c9d4851a0c
Mon Apr 24 11:53:54 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  fb8c78acbf351ac1e124d2a872f997c9d4851a0c (commit)
      from  5211fea4b9abec25a9b61437e8dee74dfdc49012 (commit)
revisions in full, below.
commit fb8c78acbf351ac1e124d2a872f997c9d4851a0c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 24 11:53:11 2023 -0700
    Add some CAPI tests for the Coverage functionality.
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 2179a4f2a..c68b2ff5e 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3771,7 +3771,7 @@ extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion(const GEOSGeometry *g);
 * \since 3.12
-extern int GEOSCoverageIsValid(
+extern int GEOS_DLL GEOSCoverageIsValid(
     const GEOSGeometry* input,
     double gapWidth,
     GEOSGeometry** invalidEdges);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index fdf987f2f..e166e112a 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2456,7 +2456,6 @@ extern "C" {
         return execute(extHandle, [&]() {
             std::ptrdiff_t stride = 2 + hasZ + hasM;
             auto coords = geos::detail::make_unique<CoordinateSequence>(size, hasZ, hasM, false);
             if (hasZ) {
                 if (hasM) {
                     // XYZM
@@ -4091,12 +4090,12 @@ extern "C" {
             std::vector<std::unique_ptr<Geometry>> invalid = cov.validate();
             bool hasInvalid = CoverageValidator::hasInvalidResult(invalid);
-            if (invalidEdges && hasInvalid) {
+            if (invalidEdges) {
                 const GeometryFactory* gf = input->getFactory();
                 for (auto& g : invalid) {
                     // Replace nullptr with 'MULTILINESTRING EMPTY'
                     if (g == nullptr) {
-                        auto empty = gf->createEmpty(GEOS_MULTILINESTRING);
+                        auto empty = gf->createEmpty(1);
                         g.reset(empty.release());
diff --git a/tests/unit/capi/GEOSCoverageIsValidTest.cpp b/tests/unit/capi/GEOSCoverageIsValidTest.cpp
new file mode 100644
index 000000000..79d54d88a
--- /dev/null
+++ b/tests/unit/capi/GEOSCoverageIsValidTest.cpp
@@ -0,0 +1,93 @@
+// Test Suite for C-API GEOSCoverageIsValid
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capicoverageisvalid_data : public capitest::utility {
+    test_capicoverageisvalid_data() {
+    ~test_capicoverageisvalid_data() {
+typedef test_group<test_capicoverageisvalid_data> group;
+typedef group::object object;
+group test_capicoverageisvalid_group("capi::GEOSCoverageIsValid");
+// Test Cases
+// GEOSCoverageIsValid - all
+template<>
+template<> void object::test<1>
+    const char* inputWKT = "GEOMETRYCOLLECTION(POLYGON ((100 100, 200 200, 300 100, 200 101, 100 100)), POLYGON ((150 0, 100 100, 200 101, 300 100, 250 0, 150 0)))";
+    int allValid;
+    input_ = fromWKT(inputWKT);
+    allValid = GEOSCoverageIsValid(input_, 0.1, &result_);
+    ensure( "valid check is true", allValid > 0 );
+    ensure( "result is not null", result_ != nullptr );
+    ensure( "type is geometrycollection", GEOSGeomTypeId(result_) == GEOS_GEOMETRYCOLLECTION );
+    const char* expectedWKT = "GEOMETRYCOLLECTION(LINESTRING EMPTY, LINESTRING EMPTY)";
+    expected_ = fromWKT(expectedWKT);
+    // std::cout << toWKT(result_) << std::endl;
+    // std::cout << toWKT(expected_) << std::endl;
+    ensure_geometry_equals(result_, expected_, 0.01);
+// GEOSCoverageIsValid - invalid
+template<>
+template<> void object::test<2>
+    const char* inputWKT = "GEOMETRYCOLLECTION(POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0)), POLYGON ((1 0, 2 0, 2 1, 1 0.9, 1 0)))";
+    int allValid;
+    ensure( "valid check is false", allValid == 0 );
+    const char* expectedWKT = "GEOMETRYCOLLECTION (LINESTRING (1 0, 1 1), LINESTRING (2 1, 1 0.9, 1 0))";
+} // namespace tut
diff --git a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
index 18c65bd9b..830a58c47 100644
--- a/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSCoverageSimplifyTest.cpp
@@ -81,5 +81,25 @@ template<> void object::test<2>
+// GEOSCoverageSimplifyVW
+template<>
+template<> void object::test<3>
+    const char* inputWKT = "GEOMETRYCOLLECTION(POLYGON(( 0 0,10 0,10.1 5,10 10,0 10,0 0)),POLYGON((10 0,20 0,20 10,10 10,10.1 5,10 0)))";
+    result_ = GEOSCoverageSimplifyVW(input_, 1.0, 0);
+    ensure( result_ != nullptr );
+    ensure( GEOSGeomTypeId(result_) == GEOS_GEOMETRYCOLLECTION );
+    const char* expectedWKT = "GEOMETRYCOLLECTION(POLYGON((0 0,10 0,10 10,0 10,0 0)),POLYGON((10 0,20 0,20 10,10 10,10 0)))";
+    ensure_geometry_equals(result_, expected_, 0.1);
 } // namespace tut
diff --git a/tests/unit/coverage/CoverageSimplifierTest.cpp b/tests/unit/coverage/CoverageSimplifierTest.cpp
index 3d4c6f92f..64e4a1a01 100644
--- a/tests/unit/coverage/CoverageSimplifierTest.cpp
+++ b/tests/unit/coverage/CoverageSimplifierTest.cpp
@@ -367,7 +367,21 @@ void object::test<19> ()
+// all inputs empty
+// template<>
+// template<>
+// void object::test<20> ()
+//     checkResult(readArray({
+//             "POLYGON EMPTY",
+//             "POLYGON EMPTY" }),
+//         1.5,
+//         readArray({
 } // namespace tut
diff --git a/tests/unit/coverage/CoverageValidatorTest.cpp b/tests/unit/coverage/CoverageValidatorTest.cpp
index 519942b9a..fd8bc6cd6 100644
--- a/tests/unit/coverage/CoverageValidatorTest.cpp
+++ b/tests/unit/coverage/CoverageValidatorTest.cpp
@@ -23,13 +23,13 @@ struct test_coveragevalidator_data {
     WKTWriter w;
     void
-    printResult(std::unique_ptr<Geometry>& actual, std::unique_ptr<Geometry>& expected)
+    printResult(const Geometry& actual, const Geometry& expected)
         std::cout << std::endl;
         std::cout << "--actual--" << std::endl;
-        std::cout << w.write(actual.get()) << std::endl;
+        std::cout << w.write(actual) << std::endl;
         std::cout << "--expect--" << std::endl;
-        std::cout << w.write(expected.get()) << std::endl;
+        std::cout << w.write(expected) << std::endl;
     void
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index bb00b7708..30b01ae11 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -113,6 +113,7 @@ void object::test<2>
     auto geo = gf->createEmptyGeometry();
     ensure("createEmptyGeometry() returned null pointer.", geo != nullptr);
     ensure_equals(geo->getSRID(), gf->getSRID());
+    ensure_equals(geo->getSRID(), srid_);
     ensure_equals(geo->getPrecisionModel()->getType(), PrecisionModel::FIXED);
 } // test<2>
@@ -238,6 +239,7 @@ void object::test<8>
     ensure_equals(pt->getNumPoints(), 0u);
     ensure_equals(pt->getLength(), 0.0);
     ensure_equals(pt->getArea(), 0.0);
+    ensure_equals(pt->getSRID(), srid_);
 // Test of createPoint(const Coordinate &coordinate) const
Summary of changes:
 capi/geos_c.h.in                               |  2 +-
 capi/geos_ts_c.cpp                             |  5 +-
 tests/unit/capi/GEOSCoverageIsValidTest.cpp    | 93 ++++++++++++++++++++++++++
 tests/unit/capi/GEOSCoverageSimplifyTest.cpp   | 20 ++++++
 tests/unit/coverage/CoverageSimplifierTest.cpp | 16 ++++-
 tests/unit/coverage/CoverageValidatorTest.cpp  |  6 +-
 tests/unit/geom/GeometryFactoryTest.cpp        |  2 +
 7 files changed, 136 insertions(+), 8 deletions(-)
 create mode 100644 tests/unit/capi/GEOSCoverageIsValidTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
