[geos-commits] [SCM] GEOS branch main updated. c11ff90e18cc14395977640154168623fa75c55a
git at osgeo.org
git at osgeo.org
Fri Apr 28 14:37:40 PDT 2023
the project "GEOS".
The branch, main has been updated
via c11ff90e18cc14395977640154168623fa75c55a (commit)
from 23ae165cf1e6a6fc0f98a1360f986fafa0932923 (commit)
revisions in full, below.
commit c11ff90e18cc14395977640154168623fa75c55a
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Apr 28 14:36:36 2023 -0700
Fix and improve MIC and LEC (#883)
diff --git a/include/geos/algorithm/construct/MaximumInscribedCircle.h b/include/geos/algorithm/construct/MaximumInscribedCircle.h
index fa1119151..1da12c038 100644
--- a/include/geos/algorithm/construct/MaximumInscribedCircle.h
+++ b/include/geos/algorithm/construct/MaximumInscribedCircle.h
@@ -107,6 +107,22 @@ public:
static std::unique_ptr<geom::LineString> getRadiusLine(const geom::Geometry* polygonal, double tolerance);
+ * Computes the maximum number of iterations allowed.
+ * Uses a heuristic based on the area of the input geometry
+ * and the tolerance distance.
+ * The number of tolerance-sized cells that cover the input geometry area
+ * is computed, times a safety factor.
+ * This prevents massive numbers of iterations and created cells
+ * for casees where the input geometry has extremely small area
+ * (e.g. is very thin).
+ * @param geom the input geometry
+ * @param toleranceDist the tolerance distance
+ * @return the maximum number of iterations allowed
+ static std::size_t computeMaximumIterations(const geom::Geometry* geom, double toleranceDist);
private:
/* private members */
@@ -170,22 +186,32 @@ private:
return y;
bool operator< (const Cell& rhs) const
return maxDist < rhs.maxDist;
bool operator> (const Cell& rhs) const
return maxDist > rhs.maxDist;
bool operator==(const Cell& rhs) const
return maxDist == rhs.maxDist;
+ * The Cell priority queue is sorted by the natural order of maxDistance.
+ * std::priority_queue sorts with largest first,
+ * which is what is needed for this algorithm.
+ using CellQueue = std::priority_queue<Cell>;
- void createInitialGrid(const geom::Envelope* env, std::priority_queue<Cell>& cellQueue);
- Cell createCentroidCell(const geom::Geometry* geom);
+ void createInitialGrid(const geom::Envelope* env, Cell::CellQueue& cellQueue);
+ Cell createInteriorPointCell(const geom::Geometry* geom);
@@ -193,4 +219,3 @@ private:
} // geos::algorithm::construct
} // geos
diff --git a/src/algorithm/construct/LargestEmptyCircle.cpp b/src/algorithm/construct/LargestEmptyCircle.cpp
index e1c2fe5ab..68f50223a 100644
--- a/src/algorithm/construct/LargestEmptyCircle.cpp
+++ b/src/algorithm/construct/LargestEmptyCircle.cpp
@@ -18,6 +18,7 @@
#include <geos/algorithm/construct/LargestEmptyCircle.h>
+#include <geos/algorithm/construct/MaximumInscribedCircle.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/Envelope.h>
@@ -28,6 +29,7 @@
#include <geos/geom/MultiPolygon.h>
#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
#include <geos/operation/distance/IndexedFacetDistance.h>
+#include <geos/util/Interrupt.h>
#include <typeinfo> // for dynamic_cast
#include <cassert>
@@ -110,21 +112,20 @@ LargestEmptyCircle::getRadiusLine()
void
LargestEmptyCircle::createInitialGrid(const Envelope* env, std::priority_queue<Cell>& cellQueue)
- double minX = env->getMinX();
- double maxX = env->getMaxX();
- double minY = env->getMinY();
- double maxY = env->getMaxY();
- double width = env->getWidth();
- double height = env->getHeight();
- double cellSize = std::min(width, height);
- double hSize = cellSize / 2.0;
- // compute initial grid of cells to cover area
- for (double x = minX; x < maxX; x += cellSize) {
- for (double y = minY; y < maxY; y += cellSize) {
- cellQueue.emplace(x+hSize, y+hSize, hSize, distanceToConstraints(x+hSize, y+hSize));
+ if (!env->isFinite()) {
+ throw util::GEOSException("Non-finite envelope encountered.");
+ double cellSize = std::max(env->getWidth(), env->getHeight());
+ double hSide = cellSize / 2.0;
+ // Collapsed geometries just end up using the centroid
+ // as the answer and skip all the other machinery
+ if (cellSize == 0) return;
+ CoordinateXY c;
+ env->centre(c);
+ cellQueue.emplace(c.x, c.y, hSide, distanceToConstraints(c.x, c.y));
/* private */
@@ -231,12 +232,18 @@ LargestEmptyCircle::compute()
* Carry out the branch-and-bound search
* of the cell space
- while (!cellQueue.empty()) {
+ std::size_t maxIter = MaximumInscribedCircle::computeMaximumIterations(boundary.get(), tolerance);
+ std::size_t iterationCount = 0;
+ while (!cellQueue.empty() && iterationCount < maxIter) {
// pick the most promising cell from the queue
Cell cell = cellQueue.top();
cellQueue.pop();
+ if ((iterationCount++ % 1000) == 0) {
+ GEOS_CHECK_FOR_INTERRUPTS();
// update the center cell if the candidate is further from the constraints
if (cell.getDistance() > farthestCell.getDistance()) {
farthestCell = cell;
diff --git a/src/algorithm/construct/MaximumInscribedCircle.cpp b/src/algorithm/construct/MaximumInscribedCircle.cpp
index 0175788d9..b20d14a08 100644
--- a/src/algorithm/construct/MaximumInscribedCircle.cpp
+++ b/src/algorithm/construct/MaximumInscribedCircle.cpp
@@ -78,6 +78,18 @@ MaximumInscribedCircle::getRadiusLine(const Geometry* polygonal, double toleranc
return mic.getRadiusLine();
+/* public static */
+std::size_t
+MaximumInscribedCircle::computeMaximumIterations(const Geometry* geom, double toleranceDist)
+ double diam = geom->getEnvelopeInternal()->getDiameter();
+ double ncells = diam / toleranceDist;
+ //-- Using log of ncells allows control over number of iterations
+ std::size_t factor = (std::size_t) std::log(ncells);
+ if (factor < 1) factor = 1;
+ return 2000 + 2000 * factor;
/* public */
std::unique_ptr<Point>
MaximumInscribedCircle::getCenter()
@@ -106,33 +118,26 @@ MaximumInscribedCircle::getRadiusLine()
return factory->createLineString(std::move(cl));
+int INITIAL_GRID_SIDE = 25;
/* private */
void
-MaximumInscribedCircle::createInitialGrid(const Envelope* env, std::priority_queue<Cell>& cellQueue)
+MaximumInscribedCircle::createInitialGrid(const Envelope* env, Cell::CellQueue& cellQueue)
- cellQueue.emplace(x+hSize, y+hSize, hSize, distanceToBoundary(x+hSize, y+hSize));
+ CoordinateXY c;
+ env->centre(c);
+ cellQueue.emplace(c.x, c.y, hSide, distanceToBoundary(c.x, c.y));
/* private */
@@ -157,11 +162,11 @@ MaximumInscribedCircle::distanceToBoundary(double x, double y)
/* private */
MaximumInscribedCircle::Cell
-MaximumInscribedCircle::createCentroidCell(const Geometry* geom)
+MaximumInscribedCircle::createInteriorPointCell(const Geometry* geom)
Coordinate c;
- geom->getCentroid(c);
- Cell cell(c.x, c.y, 0, distanceToBoundary(c));
+ std::unique_ptr<Point> p = geom->getInteriorPoint();
+ Cell cell(p->getX(), p->getY(), 0, distanceToBoundary(c));
return cell;
@@ -174,27 +179,33 @@ MaximumInscribedCircle::compute()
if (done) return;
// Priority queue of cells, ordered by maximum distance from boundary
- std::priority_queue<Cell> cellQueue;
+ Cell::CellQueue cellQueue;
createInitialGrid(inputGeom->getEnvelopeInternal(), cellQueue);
// use the area centroid as the initial candidate center point
- Cell farthestCell = createCentroidCell(inputGeom);
+ Cell farthestCell = createInteriorPointCell(inputGeom);
* of the cell space
+ std::size_t maxIter = computeMaximumIterations(inputGeom, tolerance);
cellQueue.pop();
+// std::cout << iterationCount << "] Dist: " << cell.getDistance() << " size: " << cell.getHSize() << std::endl;
+ //-- if cell must be closer than furthest, terminate since all remaining cells in queue are even closer.
+ if (cell.getMaxDistance() < farthestCell.getDistance())
+ break;
// update the center cell if the candidate is further from the boundary
@@ -237,4 +248,3 @@ MaximumInscribedCircle::compute()
} // namespace geos.algorithm.construct
} // namespace geos
diff --git a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
index 8711f0c61..959beb4a0 100644
--- a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
+++ b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
@@ -61,6 +61,24 @@ struct test_lec_data {
ensure_equals("y coordinate does not match", lhs.y, rhs.y, tolerance);
+ * A coarse distance check, mainly testing
+ * that there is not a huge number of iterations.
+ * (This will be revealed by CI taking a very long time!)
+ void
+ checkCircle(std::string wktObstacles, double tolerance)
+ std::unique_ptr<Geometry> geom(reader_.read(wktObstacles));
+ LargestEmptyCircle lec(geom.get(), tolerance);
+ std::unique_ptr<Point> centerPoint = lec.getCenter();
+ double dist = geom->distance(centerPoint.get());
+ //std::cout << dist << std::endl;
+ std::unique_ptr<LineString> radiusLine = lec.getRadiusLine();
+ double actualRadius = radiusLine->getLength();
+ ensure(std::abs(actualRadius - dist) < 2 * tolerance);
void
checkCircle(const Geometry *obstacles, const Geometry *boundary, double build_tolerance, double x, double y, double expectedRadius)
@@ -202,8 +220,8 @@ void object::test<6>
- checkCircle("MULTILINESTRING ((100 100, 200 150, 100 200, 250 250, 100 300, 300 350, 100 400), (50 400, 0 350, 50 300, 0 250, 50 200, 0 150, 50 100))",
- 0.01, 77.52, 349.99, 54.81 );
+ checkCircle("MULTILINESTRING ((100 100, 200 150, 100 200, 250 250, 100 300, 300 350, 100 400), (70 380, 0 350, 50 300, 0 250, 50 200, 0 150, 50 120))",
+ 0.01, 77.52, 249.99, 54.81 );
@@ -243,11 +261,21 @@ void object::test<9>
0.01 );
-// testBoundaryEmpty
+// testThinExtent
template<>
template<>
void object::test<10>
+ checkCircle("MULTIPOINT ((100 100), (300 100), (200 100.1))",
+ 0.01 );
+// testBoundaryEmpty
+template<>
+template<>
+void object::test<11>
checkCircle("MULTIPOINT ((2 2), (8 8), (7 5))",
"POLYGON EMPTY",
@@ -257,7 +285,7 @@ void object::test<10>
// testBoundarySquare
template<>
template<>
-void object::test<11>
+void object::test<12>
checkCircle("MULTIPOINT ((2 2), (6 4), (8 8))",
@@ -268,7 +296,7 @@ void object::test<11>
//testBoundarySquareObstaclesOutside
template<>
template<>
-void object::test<12>
+void object::test<13>
checkCircle("MULTIPOINT ((10 10), (10 0))",
@@ -279,7 +307,7 @@ void object::test<12>
// testBoundaryMultiSquares
template<>
template<>
-void object::test<13>
+void object::test<14>
checkCircle("MULTIPOINT ((10 10), (10 0), (5 5))",
@@ -290,7 +318,7 @@ void object::test<13>
// testBoundaryAsObstacle
template<>
template<>
-void object::test<14>
+void object::test<15>
checkCircle("GEOMETRYCOLLECTION (POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9)), POINT (4 3), POINT (7 6))",
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index a64e4def8..7a7add925 100644
--- a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -59,10 +59,26 @@ struct test_mic_data {
void
- checkCircle(const Geometry *geom, double build_tolerance, double x, double y, double expectedRadius)
+ checkCircle(std::string wkt, double tolerance)
+ std::unique_ptr<Geometry> geom(reader_.read(wkt));
+ MaximumInscribedCircle mic(geom.get(), tolerance);
+ std::unique_ptr<Point> centerPoint = mic.getCenter();
+ std::unique_ptr<Geometry> bdy = geom->getBoundary();
+ double dist = bdy->distance(centerPoint.get());
+ ensure(dist < 2 * tolerance);
+ void
+ checkCircle(const Geometry *geom, double tolerance, double x, double y, double expectedRadius)
- double tolerance = 2*build_tolerance;
MaximumInscribedCircle mic(geom, tolerance);
Coordinate centerPt(*centerPoint->getCoordinate());
@@ -203,7 +219,30 @@ void object::test<8>
} catch (const util::GEOSException & e) {}
+ * Tests that a nearly flat geometry doesn't make the initial cell grid huge.
+ * See https://github.com/libgeos/geos/issues/875
+// testNearlyFlat
+template<>
+template<>
+void object::test<9>
+ checkCircle("POLYGON ((59.3 100.00000000000001, 99.7 100.00000000000001, 99.7 100, 59.3 100, 59.3 100.00000000000001))",
+ 0.01 );
+// testVeryThin
+template<>
+template<>
+void object::test<10>
+ checkCircle("POLYGON ((100 100, 200 300, 300 100, 450 250, 300 99.999999, 200 299.99999, 100 100))",
+ 0.01 );
} // namespace tut
Summary of changes:
.../algorithm/construct/MaximumInscribedCircle.h | 31 +++++++++++--
src/algorithm/construct/LargestEmptyCircle.cpp | 37 +++++++++------
src/algorithm/construct/MaximumInscribedCircle.cpp | 54 +++++++++++++---------
.../algorithm/construct/LargestEmptyCircleTest.cpp | 42 ++++++++++++++---
.../construct/MaximumInscribedCircleTest.cpp | 45 ++++++++++++++++--
5 files changed, 159 insertions(+), 50 deletions(-)
hooks/post-receive
More information about the geos-commits
