[geos-commits] [SCM] GEOS branch 3.12 updated. f6c5515b754acf2e491de05bc6774a1b5f88e2fb
Tue Dec 5 12:58:58 PST 2023
the project "GEOS".
The branch, 3.12 has been updated
       via  f6c5515b754acf2e491de05bc6774a1b5f88e2fb (commit)
      from  5b60b76fc0dbab04ed2488f78c4239a8b82657b8 (commit)
revisions in full, below.
commit f6c5515b754acf2e491de05bc6774a1b5f88e2fb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Dec 5 12:58:39 2023 -0800
    Fix PreparedPolygonContains for GC with MultiPoint (#1008)
diff --git a/src/geom/prep/AbstractPreparedPolygonContains.cpp b/src/geom/prep/AbstractPreparedPolygonContains.cpp
index cfc87436c..86a0ad343 100644
--- a/src/geom/prep/AbstractPreparedPolygonContains.cpp
+++ b/src/geom/prep/AbstractPreparedPolygonContains.cpp
@@ -201,13 +201,12 @@ bool AbstractPreparedPolygonContains::evalPointTestGeom(const Geometry *geom, Lo
         return true;
-    if (geom->getNumGeometries() > 1) {
-        // for MultiPoint, try to find at least one point
-        // in interior
-        return isAnyTestComponentInTargetInterior(geom);
+    // a single point must not be in interior
+    if (geom->getNumPoints() <= 1) {
+        return false;
-    return false;
+    // for multiple points have to check all
+    return isAnyTestComponentInTargetInterior(geom);
diff --git a/tests/unit/geom/prep/PreparedGeometryTest.cpp b/tests/unit/geom/prep/PreparedGeometryTest.cpp
index efc5c4b82..f651f2a96 100644
--- a/tests/unit/geom/prep/PreparedGeometryTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometryTest.cpp
@@ -68,4 +68,34 @@ void object::test<1>
     ensure( pg1->covers(g2.get()));
+// See https://trac.osgeo.org/postgis/ticket/5601
+template<>
+template<>
+void object::test<2>
+    g1 = reader.read( "LINESTRING(-1 0,0 0)" );
+    g2 = reader.read( "GEOMETRYCOLLECTION(MULTIPOINT(-1 0),LINESTRING(0 -1,1 0))" );
+    pg1 = prep::PreparedGeometryFactory::prepare(g1.get());
+    ensure(  g1->intersects(g2.get()) );
+    ensure( pg1->intersects(g2.get()) );
+// See https://github.com/libgeos/geos/issues/1007
+template<>
+template<>
+void object::test<3>
+    g1 = reader.read( "MULTIPOLYGON(((-60 -50,-70 -50,-60 -40,-60 -50)))" );
+    g2 = reader.read( "GEOMETRYCOLLECTION(MULTIPOINT((-60 -50),(-63 -49)))" );
+    ensure(  g1->contains(g2.get()) );
+    ensure( pg1->contains(g2.get()) );
 } // namespace tut
Summary of changes:
 src/geom/prep/AbstractPreparedPolygonContains.cpp | 11 ++++-----
 tests/unit/geom/prep/PreparedGeometryTest.cpp     | 30 +++++++++++++++++++++++
 2 files changed, 35 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
