[geos-commits] [SCM] GEOS branch main updated. 8fac1b5daeb3d95c9d526d915ff4d8ddcd147a2d
Thu Dec 7 13:46:34 PST 2023
the project "GEOS".
The branch, main has been updated
       via  8fac1b5daeb3d95c9d526d915ff4d8ddcd147a2d (commit)
      from  1d1ad6b21ff6696337189054b3a323b878a4430f (commit)
revisions in full, below.
commit 8fac1b5daeb3d95c9d526d915ff4d8ddcd147a2d
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Dec 7 13:46:09 2023 -0800
    Add XML unit test for GeometryCollections
diff --git a/tests/xmltester/tests/general/TestRelateGC.xml b/tests/xmltester/tests/general/TestRelateGC.xml
new file mode 100644
index 000000000..5f7869909
--- /dev/null
+++ b/tests/xmltester/tests/general/TestRelateGC.xml
@@ -0,0 +1,24 @@
+<run>
+<case>
+  <desc>A/GC-mP</desc>
+  <a>
+    POLYGON((-60 -50,-70 -50,-60 -40,-60 -50))
+  </a>
+  <b>
+    GEOMETRYCOLLECTION(MULTIPOINT((-60 -50),(-63 -49)))
+  </b>
+  <test><op name="relate" arg3="0F20F1FF2" arg1="A" arg2="B"> true </op></test>
+  <test><op name="contains"   arg1="A" arg2="B"> true </op></test>
+  <test><op name="coveredBy"  arg1="A" arg2="B"> false </op></test>
+  <test><op name="covers"     arg1="A" arg2="B"> true </op></test>
+  <test><op name="crosses"    arg1="A" arg2="B"> false </op></test>
+  <test><op name="disjoint"   arg1="A" arg2="B"> false </op></test>
+  <test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+  <test><op name="intersects" arg1="A" arg2="B"> true </op></test>
+  <test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
+  <test><op name="touches"    arg1="A" arg2="B"> false </op></test>
+  <test><op name="within"     arg1="A" arg2="B"> false </op></test>
+</case>
+</run>
Summary of changes:
 tests/xmltester/tests/general/TestRelateGC.xml | 24 ++++++++++++++++++++++++
 1 file changed, 24 insertions(+)
 create mode 100644 tests/xmltester/tests/general/TestRelateGC.xml
hooks/post-receive
More information about the geos-commits mailing list
