[geos-commits] [SCM] GEOS branch main updated. c49ac84dd18de4c7313056771c4a1d40b1f483c5
Fri Dec 8 11:16:33 PST 2023
the project "GEOS".
The branch, main has been updated
       via  c49ac84dd18de4c7313056771c4a1d40b1f483c5 (commit)
      from  725f2979173cc5a089bb21b0d8a8cf8e6bbb83c9 (commit)
revisions in full, below.
commit c49ac84dd18de4c7313056771c4a1d40b1f483c5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Dec 8 10:05:22 2023 -0800
    Add simplifyDP and simplifyTP to XML tester. Closes GH-1010
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 4bd67edef..5013e8bf9 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -45,6 +45,8 @@
 #include <geos/operation/polygonize/BuildArea.h>
 #include <geos/operation/valid/MakeValid.h>
 #include <geos/precision/MinimumClearance.h>
+#include <geos/simplify/TopologyPreservingSimplifier.h>
+#include <geos/simplify/DouglasPeuckerSimplifier.h>
 #include <geos/util.h>
 #include <geos/util/Interrupt.h>
 #include <geos/io/WKBReader.h>
@@ -2193,6 +2195,41 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
+        else if(opName == "simplifydp" || opName == "simplifytp")
+            geom::Geometry* p_gT = gA;
+            if((opArg1 == "B" || opArg1 == "b") && gB) {
+                p_gT = gB;
+            GeomPtr gRes(parseGeometry(opRes, "expected"));
+            gRes->normalize();
+            profile.start();
+            GeomPtr gRealRes;
+            double tolerance = std::atof(opArg2.c_str());
+            if (opName == "simplifydp") {
+                gRealRes = geos::simplify::DouglasPeuckerSimplifier::simplify(p_gT, tolerance);
+            else {
+                gRealRes = geos::simplify::TopologyPreservingSimplifier::simplify(p_gT, tolerance);
+            profile.stop();
+            gRealRes->normalize();
+            actual_result = printGeom(gRealRes.get());
+            expected_result = printGeom(gRes.get());
+            success = gRealRes.get()->equalsExact(gRes.get(), 0.000001) ? 1 : 0;
+            if(testValidOutput) {
+                success &= int(testValid(gRealRes.get(), "result"));
         else {
             std::cerr << *curr_file << ":";
             std::cerr << " case" << caseCount << ":";
diff --git a/tests/xmltester/tests/general/TestSimplify.xml b/tests/xmltester/tests/general/TestSimplify.xml
new file mode 100644
index 000000000..5b4dd0a6a
--- /dev/null
+++ b/tests/xmltester/tests/general/TestSimplify.xml
@@ -0,0 +1,231 @@
+<run>
+  <desc>Test cases for DouglasPeuckerSimplifier and TopologyPreservingSimplifier</desc>
+  <precisionModel type="FLOATING"/>
+<case>
+  <desc>P - point</desc>
+  <a> POINT(10 10)
+    </a>
+  <test> <op name="simplifyDP" arg1="A" arg2="1">
+      POINT(10 10)
+    </op> </test>
+  <test> <op name="simplifyTP" arg1="A" arg2="1">
+      POINT(10 10)
+    </op> </test>
+</case>
+<case>
+  <desc>mP - point with EMPTY</desc>
+  <a> MULTIPOINT(EMPTY, (10 10), (20 20))
+    </a>
+      MULTIPOINT((10 10), (20 20))
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>L - empty line</desc>
+  <a> LINESTRING EMPTY
+    </a>
+  <test> <op name="simplifyDP" arg1="A" arg2="10">
+      LINESTRING EMPTY
+    </op> </test>
+  <test> <op name="simplifyTP" arg1="A" arg2="10">
+      LINESTRING EMPTY
+    </op> </test>
+</case>
+<case>
+  <desc>L - line</desc>
+  <a> LINESTRING (10 10, 20 21, 30 30)
+    </a>
+      LINESTRING (10 10, 30 30)
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>L - short line</desc>
+  <a> LINESTRING (0 5, 1 5, 2 5, 5 5)
+    </a>
+      LINESTRING (0 5, 5 5)
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>mL - lines with constrained topology</desc>
+  <a> MULTILINESTRING ((10 60, 39 50, 70 60, 90 50), (35 55, 46 55), (65 55, 75 55), (10 40, 40 30, 70 40, 90 30))
+    </a>
+      MULTILINESTRING ((10 60, 90 50), (35 55, 46 55), (65 55, 75 55), (10 40, 90 30))
+    </op> </test>
+      MULTILINESTRING ((10 60, 39 50, 70 60, 90 50), (35 55, 46 55), (65 55, 75 55), (10 40, 90 30))
+    </op> </test>
+</case>
+<case>
+  <desc>mL - lines with EMPTY</desc>
+  <a> MULTILINESTRING(EMPTY, (10 10, 20 21, 30 30), (10 10, 10 30, 30 30))
+    </a>
+      MULTILINESTRING ((10 10, 30 30), (10 10, 10 30, 30 30))
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon with flat endpoint</desc>
+  <a> POLYGON ((5 1, 1 1, 1 9, 9 9, 9 1, 5 1))
+    </a>
+      POLYGON ((1 1, 1 9, 9 9, 9 1, 1 1))
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon with multiple flat segments around endpoint</desc>
+  <a> POLYGON ((5 5, 7 5, 9 5, 9 1, 1 1, 1 5, 3 5, 5 5))
+    </a>
+      POLYGON ((9 5, 9 1, 1 1, 1 5, 9 5))
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon simplification</desc>
+  <a> POLYGON ((10 10, 10 90, 60.5 87, 90 90, 90 10, 12 12, 10 10))
+    </a>
+      POLYGON ((10 10, 10 90, 90 90, 90 10, 10 10))
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon with edge collapse.
+    DP: polygon is split
+    TP: unchanged
+    </desc>
+  <a> POLYGON ((40 240, 160 241, 280 240, 280 160, 160 240, 40 140, 40 240))
+    </a>
+      MULTIPOLYGON (((40 240, 160 240, 40 140, 40 240)), ((160 240, 280 240, 280 160, 160 240)))
+    </op> </test>
+      POLYGON ((40 240, 160 241, 280 240, 280 160, 160 240, 40 140, 40 240))
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon collapse for DP</desc>
+  <a> POLYGON ((5 2, 9 1, 1 1, 5 2))
+    </a>
+      POLYGON EMPTY
+    </op> </test>
+      POLYGON ((5 2, 9 1, 1 1, 5 2))
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon with touching hole</desc>
+  <a> POLYGON ((10 10, 10 90, 90 90, 90 10, 10 10), (80 20, 20 20, 20 80, 50 90, 80 80, 80 20))
+    </a>
+      POLYGON ((10 10, 10 90, 90 90, 90 10, 10 10), (80 20, 20 20, 20 80, 80 80, 80 20))
+    </op> </test>
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon with large hole near edge.
+    DP: simplified and fixed
+    TP: unchanged
+  </desc>
+  <a> POLYGON ((10 10, 10 80, 50 90, 90 80, 90 10, 10 10), (80 20, 20 20, 50 90, 80 20))
+    </a>
+      POLYGON ((10 10, 10 80, 45.714285714285715 80, 20 20, 80 20, 54.285714285714285 80, 90 80, 90 10, 10 10))
+    </op> </test>
+      POLYGON ((10 10, 10 80, 50 90, 90 80, 90 10, 10 10), (80 20, 20 20, 50 90, 80 20))
+    </op> </test>
+</case>
+<case>
+  <desc>A - polygon with small hole near simplified edge
+    DP: hole is remmoved
+    TP: hole is preserved
+  </desc>
+  <a> POLYGON ((10 10, 10 80, 50 90, 90 80, 90 10, 10 10), (70 81, 30 81, 50 90, 70 81))
+    </a>
+      POLYGON ((10 10, 10 80, 90 80, 90 10, 10 10))
+    </op> </test>
+      POLYGON ((10 10, 10 80, 50 90, 90 80, 90 10, 10 10), (70 81, 30 81, 50 90, 70 81))
+    </op> </test>
+</case>
+<case>
+  <desc>mA - multipolygon with EMPTY</desc>
+  <a> MULTIPOLYGON (EMPTY, ((10 90, 10 10, 90 10, 50 60, 10 90)), ((70 90, 90 90, 90 70, 70 70, 70 90)))
+    </a>
+      MULTIPOLYGON (((10 90, 10 10, 90 10, 10 90)), ((70 90, 90 90, 90 70, 70 70, 70 90)))
+    </op> </test>
+      MULTIPOLYGON (((10 90, 10 10, 90 10, 50 60, 10 90)), ((70 90, 90 90, 90 70, 70 70, 70 90)))
+    </op> </test>
+</case>
+<case>
+  <desc>mA - multipolygon with small element removed</desc>
+  <a> MULTIPOLYGON (((10 90, 10 10, 40 40, 90 10, 47 57, 10 90)), ((90 90, 90 85, 85 85, 85 90, 90 90)))
+    </a>
+      POLYGON ((10 90, 10 10, 40 40, 90 10, 10 90))
+    </op> </test>
+      MULTIPOLYGON (((10 90, 10 10, 40 40, 90 10, 10 90)), ((85 90, 90 85, 85 85, 85 90)))
+    </op> </test>
+</case>
+<case>
+  <desc>GC - geometry collection</desc>
+  <a> GEOMETRYCOLLECTION (POLYGON ((10 90, 10 10, 40 40, 90 10, 47 57, 10 90)), LINESTRING (30 90, 65 65, 90 30), MULTIPOINT ((80 90), (90 90)))
+    </a>
+      GEOMETRYCOLLECTION (POLYGON ((10 90, 10 10, 40 40, 90 10, 10 90)), LINESTRING (30 90, 90 30), MULTIPOINT ((80 90), (90 90)))
+    </op> </test>
+    </op> </test>
+</case>
+</run>
Summary of changes:
 tests/xmltester/XMLTester.cpp                  |  37 ++++
 tests/xmltester/tests/general/TestSimplify.xml | 231 +++++++++++++++++++++++++
 2 files changed, 268 insertions(+)
 create mode 100644 tests/xmltester/tests/general/TestSimplify.xml
hooks/post-receive
More information about the geos-commits mailing list
