[geos-commits] [SCM] GEOS branch main updated. 3cb53afe7b3b283ec7bbbb60d4a315d43a69ae0f
Sat Dec 9 14:40:25 PST 2023
the project "GEOS".
The branch, main has been updated
       via  3cb53afe7b3b283ec7bbbb60d4a315d43a69ae0f (commit)
      from  c49ac84dd18de4c7313056771c4a1d40b1f483c5 (commit)
revisions in full, below.
commit 3cb53afe7b3b283ec7bbbb60d4a315d43a69ae0f
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sat Dec 9 14:39:52 2023 -0800
    Remove unnecassary precision from XML tests
diff --git a/tests/xmltester/tests/general/TestBoundary.xml b/tests/xmltester/tests/general/TestBoundary.xml
index befea95c3..f3a6dff80 100644
--- a/tests/xmltester/tests/general/TestBoundary.xml
+++ b/tests/xmltester/tests/general/TestBoundary.xml
@@ -1,5 +1,4 @@
 <run>
-  <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
 <case>
   <desc>P - point</desc>
diff --git a/tests/xmltester/tests/general/TestCentroid.xml b/tests/xmltester/tests/general/TestCentroid.xml
index 068b6177f..62791cae3 100644
--- a/tests/xmltester/tests/general/TestCentroid.xml
+++ b/tests/xmltester/tests/general/TestCentroid.xml
@@ -1,5 +1,4 @@
 <run>
-  <!-- <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/> -->
 <case>
   <desc>P - empty</desc>
diff --git a/tests/xmltester/tests/general/TestConvexHull-big.xml b/tests/xmltester/tests/general/TestConvexHull-big.xml
index 7de9aa293..7651a611a 100644
--- a/tests/xmltester/tests/general/TestConvexHull-big.xml
+++ b/tests/xmltester/tests/general/TestConvexHull-big.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
   <desc>Big convex hull</desc>
diff --git a/tests/xmltester/tests/general/TestDistance.xml b/tests/xmltester/tests/general/TestDistance.xml
index 3835c919d..e6444ddac 100644
--- a/tests/xmltester/tests/general/TestDistance.xml
+++ b/tests/xmltester/tests/general/TestDistance.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
   <desc>PeP - point to an empty point</desc>
diff --git a/tests/xmltester/tests/general/TestIntersectsPL.xml b/tests/xmltester/tests/general/TestIntersectsPL.xml
index 3d2634a55..22b5e2151 100644
--- a/tests/xmltester/tests/general/TestIntersectsPL.xml
+++ b/tests/xmltester/tests/general/TestIntersectsPL.xml
@@ -1,8 +1,5 @@
 <run>
   <desc>Test P/L intersects cases that require robust determinant. See discussion http://trac.osgeo.org/geos/ticket/591</desc>
-  <!-- first occurrence is used -->
-  <precisionModel type="FLOATING"/> <!-- passes -->
-  <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/> <!-- passes -->
 <case>
   <desc>Point on segment between 3rd and 4th vertex of line</desc>
diff --git a/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml b/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml
index 55c69a57d..f77162b8a 100644
--- a/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml
+++ b/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml
@@ -1,8 +1,5 @@
 <run>
   <geometryOperation>com.vividsolutions.jtstest.geomop.PreparedGeometryOperation</geometryOperation>
 <case>
diff --git a/tests/xmltester/tests/general/TestRectanglePredicate.xml b/tests/xmltester/tests/general/TestRectanglePredicate.xml
index 254f1e751..38b9d6ca2 100644
--- a/tests/xmltester/tests/general/TestRectanglePredicate.xml
+++ b/tests/xmltester/tests/general/TestRectanglePredicate.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
   <desc>A disjoint</desc>
diff --git a/tests/xmltester/tests/general/TestSimple.xml b/tests/xmltester/tests/general/TestSimple.xml
index a75cdb1f8..c496ab7d9 100644
--- a/tests/xmltester/tests/general/TestSimple.xml
+++ b/tests/xmltester/tests/general/TestSimple.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
diff --git a/tests/xmltester/tests/general/TestUnaryUnion.xml b/tests/xmltester/tests/general/TestUnaryUnion.xml
index 6f4ee78f7..0c736af8c 100644
--- a/tests/xmltester/tests/general/TestUnaryUnion.xml
+++ b/tests/xmltester/tests/general/TestUnaryUnion.xml
@@ -1,6 +1,5 @@
 <run>
   <desc>Tests for Geometry.union() method (unary union)</desc>
 <case>
   <desc>P - point (showing merging of identical points)</desc>
diff --git a/tests/xmltester/tests/general/TestValid.xml b/tests/xmltester/tests/general/TestValid.xml
index 4655b3c8d..b0aef8dc0 100644
--- a/tests/xmltester/tests/general/TestValid.xml
+++ b/tests/xmltester/tests/general/TestValid.xml
@@ -1,5 +1,4 @@
 <run>
    <case>
       <desc>P - point (valid)</desc>
diff --git a/tests/xmltester/tests/general/TestWithinDistance.xml b/tests/xmltester/tests/general/TestWithinDistance.xml
index a4a1e3511..1438bcd27 100644
--- a/tests/xmltester/tests/general/TestWithinDistance.xml
+++ b/tests/xmltester/tests/general/TestWithinDistance.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
   <desc>PP - disjoint points</desc>
diff --git a/tests/xmltester/tests/issue/issue-geos-582.xml b/tests/xmltester/tests/issue/issue-geos-582.xml
index 781c60686..1a3404a83 100644
--- a/tests/xmltester/tests/issue/issue-geos-582.xml
+++ b/tests/xmltester/tests/issue/issue-geos-582.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
   <desc>GC - overlapping polygons </desc>
diff --git a/tests/xmltester/tests/misc/TestIsValid.xml b/tests/xmltester/tests/misc/TestIsValid.xml
index 34575ace2..00849b399 100644
--- a/tests/xmltester/tests/misc/TestIsValid.xml
+++ b/tests/xmltester/tests/misc/TestIsValid.xml
@@ -1,6 +1,4 @@
 <run>
-  <precisionModel type="FLOATING" />
    <case>
       <desc>http://lists.refractions.net/pipermail/jts-devel/2006-March/001447.html (1)</desc>
diff --git a/tests/xmltester/tests/misc/linemerge.xml b/tests/xmltester/tests/misc/linemerge.xml
index 0751d0f24..028ff6e81 100644
--- a/tests/xmltester/tests/misc/linemerge.xml
+++ b/tests/xmltester/tests/misc/linemerge.xml
@@ -1,5 +1,4 @@
 <run>
-<precisionModel scale="1.0" offsetx="0.0" offsety="0.0" />
 <case>
 <desc>Case</desc>
 <a>
diff --git a/tests/xmltester/tests/misc/robustness.xml b/tests/xmltester/tests/misc/robustness.xml
index 027224cf0..d4e147e37 100644
--- a/tests/xmltester/tests/misc/robustness.xml
+++ b/tests/xmltester/tests/misc/robustness.xml
@@ -1,8 +1,4 @@
 <run>
-  <precisionModel type="FLOATING_SINGLE" />
 <case>
 <desc>http://geos.osgeo.org/pipermail/geos-devel/2005-May/001441.html</desc>
diff --git a/tests/xmltester/tests/misc/split.xml b/tests/xmltester/tests/misc/split.xml
index 6836542b4..b884e529e 100644
--- a/tests/xmltester/tests/misc/split.xml
+++ b/tests/xmltester/tests/misc/split.xml
@@ -1,5 +1,4 @@
 <run>
 This test is to verify difference() can be used to split linestrings
 and multilinestring using a "cutter" linesting.
diff --git a/tests/xmltester/tests/robust/TestRobustRelate.xml b/tests/xmltester/tests/robust/TestRobustRelate.xml
index c16c93091..a6c657348 100644
--- a/tests/xmltester/tests/robust/TestRobustRelate.xml
+++ b/tests/xmltester/tests/robust/TestRobustRelate.xml
@@ -1,5 +1,4 @@
 <run>
 <case>
   <desc>PP - Point is not on line. Non-robust algorithms fail by erroneously reporting intersects=true.</desc>
Summary of changes:
 tests/xmltester/tests/general/TestBoundary.xml             | 1 -
 tests/xmltester/tests/general/TestCentroid.xml             | 1 -
 tests/xmltester/tests/general/TestConvexHull-big.xml       | 1 -
 tests/xmltester/tests/general/TestDistance.xml             | 1 -
 tests/xmltester/tests/general/TestIntersectsPL.xml         | 3 ---
 tests/xmltester/tests/general/TestPreparedIntersectsPL.xml | 3 ---
 tests/xmltester/tests/general/TestRectanglePredicate.xml   | 1 -
 tests/xmltester/tests/general/TestSimple.xml               | 1 -
 tests/xmltester/tests/general/TestUnaryUnion.xml           | 1 -
 tests/xmltester/tests/general/TestValid.xml                | 1 -
 tests/xmltester/tests/general/TestWithinDistance.xml       | 1 -
 tests/xmltester/tests/issue/issue-geos-582.xml             | 1 -
 tests/xmltester/tests/misc/TestIsValid.xml                 | 2 --
 tests/xmltester/tests/misc/linemerge.xml                   | 1 -
 tests/xmltester/tests/misc/robustness.xml                  | 4 ----
 tests/xmltester/tests/misc/split.xml                       | 1 -
 tests/xmltester/tests/robust/TestRobustRelate.xml          | 1 -
 17 files changed, 25 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
