[geos-commits] [SCM] GEOS branch main updated. 86e1f00d388c20b5eb948d01bd888ab93134d001
Sat Dec 9 20:23:38 PST 2023
the project "GEOS".
The branch, main has been updated
       via  86e1f00d388c20b5eb948d01bd888ab93134d001 (commit)
      from  e99df070d0831f8d915f738b49dc3c100bf75fc4 (commit)
revisions in full, below.
commit 86e1f00d388c20b5eb948d01bd888ab93134d001
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Sun Dec 10 05:23:05 2023 +0100
    geos_c.cpp: fix declarations to avoid C++ One Definition Rule violations (#1014)
    Currently building with GCC link-time-optimization with -flto -Wodr
    leads to the following type of warnings:
    /home/even/geos/geos/build_cmake/capi/geos_c.h:665:31: warning: ‘GEOSBufferWithParams_r’ violates the C++ One Definition Rule [-Wodr]
      665 | extern GEOSGeometry GEOS_DLL *GEOSBufferWithParams_r(
    /home/even/geos/geos/capi/geos_ts_c.cpp:4034:5: note: type mismatch in parameter 3
     4034 |     GEOSBufferWithParams_r(GEOSContextHandle_t extHandle, const Geometry* g1, const BufferParameters* bp, double width)
    /home/even/geos/geos/capi/geos_ts_c.cpp:4034:5: note: type name ‘geos::operation::buffer::BufferParameters’ should match type name ‘GEOSBufParams_t’
    /home/even/geos/geos/capi/geos_ts_c.cpp:4034:5: note: ‘GEOSBufferWithParams_r’ was previously declared here
    This is due to geos_c.cpp using slightly different definitions of the
    aliases between C API and C++ classes than the ones set in
    geos_ts_c.cpp.
    Use exactly the ones from geos_tc_c.cpp to fix that issue.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index d1f820d19..12cabdfe0 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -23,6 +23,7 @@
 #include <geos/io/WKBWriter.h>
 #include <geos/io/GeoJSONReader.h>
 #include <geos/io/GeoJSONWriter.h>
+#include <geos/operation/buffer/BufferParameters.h>
 #include <geos/util/Interrupt.h>
 #include <stdexcept>
@@ -32,10 +33,15 @@
 #pragma warning(disable : 4099)
 #endif
-// Some extra magic to make type declarations in geos_c.h work - for cross-checking of types in header.
+// Some extra magic to make type declarations in geos_c.h work -
+// for cross-checking of types in header.
+// NOTE: the below defines or struct definition must be kept in exact
+// sync between geos_c.cpp and geos_ts_c.cpp to avoid C++ One Definition Rule
+// violations.
 #define GEOSGeometry geos::geom::Geometry
 #define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
 #define GEOSCoordSequence geos::geom::CoordinateSequence
+#define GEOSBufferParams geos::operation::buffer::BufferParameters
 #define GEOSSTRtree geos::index::strtree::TemplateSTRtree<void*>
 #define GEOSWKTReader geos::io::WKTReader
 #define GEOSWKTWriter geos::io::WKTWriter
@@ -43,8 +49,12 @@
 #define GEOSWKBWriter geos::io::WKBWriter
 #define GEOSGeoJSONReader geos::io::GeoJSONReader
 #define GEOSGeoJSONWriter geos::io::GeoJSONWriter
-typedef struct GEOSBufParams_t GEOSBufferParams;
-typedef struct GEOSMakeValidParams_t GEOSMakeValidParams;
+// Implementation struct for the GEOSMakeValidParams object
+typedef struct {
+    int method;
+    int keepCollapsed;
+} GEOSMakeValidParams;
 #include "geos_c.h"
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 539435ffb..7109e0b72 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -119,6 +119,9 @@
+// violations.
Summary of changes:
 capi/geos_c.cpp    | 16 +++++++++++++---
 capi/geos_ts_c.cpp |  3 +++
 2 files changed, 16 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
