[geos-commits] [SCM] GEOS branch main updated. c37391cf135ebe358a80a91d56c0daac4115214b
    git at osgeo.org
    git at osgeo.org
    Wed Jun 14 12:34:59 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  c37391cf135ebe358a80a91d56c0daac4115214b (commit)
      from  5611d6be4396678c777827cab71be49852b62cd4 (commit)
revisions in full, below.
commit c37391cf135ebe358a80a91d56c0daac4115214b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jun 14 11:55:57 2023 -0700
    Overlay with mixed dimension (#923)
    For overlay operations (union/difference/intersection/symdifference) support for GeometryCollection has been missing, at least for those cases of GeometryCollection that contain a mixture of types (point/line/polygon).
    This fix tests inputs to HeuristicOverlay (formerly a wide-ranging set of shims to work around issues with the old overlay code) and for those that are mixed-type collections, processes the component dimensions separately, with appropriate logic for the overlay operation being run. Fixes GH-797.
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 8ba3587c1..38343cee2 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -364,6 +364,9 @@ public:
         return isDimensionStrict(Dimension::A);
+    bool isMixedDimension() const;
+    bool isMixedDimension(Dimension::DimensionType* baseDim) const;
     bool isCollection() const {
         int t = getGeometryTypeId();
         return t == GEOS_GEOMETRYCOLLECTION ||
diff --git a/include/geos/geom/HeuristicOverlay.h b/include/geos/geom/HeuristicOverlay.h
index b6146bbfd..bc1217a78 100644
--- a/include/geos/geom/HeuristicOverlay.h
+++ b/include/geos/geom/HeuristicOverlay.h
@@ -20,16 +20,80 @@
 #pragma once
 #include <geos/export.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Dimension.h>
 #include <memory> // for unique_ptr
+#include <vector>
-namespace geos {
-namespace geom { // geos::geom
+namespace geos {
+namespace geom {
 class Geometry;
+class GeometryFactory;
+namespace geos {
+namespace geom { // geos::geom
 std::unique_ptr<Geometry> GEOS_DLL
 HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode);
+class StructuredCollection {
+public:
+    StructuredCollection(const Geometry* g)
+        : factory(g->getFactory())
+        , pt_union(nullptr)
+        , line_union(nullptr)
+        , poly_union(nullptr)
+        readCollection(g);
+        unionByDimension();
+    StructuredCollection()
+        : factory(nullptr)
+    void readCollection(const Geometry* g);
+    const Geometry* getPolyUnion()  const { return poly_union.get(); }
+    const Geometry* getLineUnion()  const { return line_union.get(); }
+    const Geometry* getPointUnion() const { return pt_union.get(); }
+    std::unique_ptr<Geometry> doUnion(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doIntersection(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doSymDifference(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doDifference(const StructuredCollection& a) const;
+    std::unique_ptr<Geometry> doUnaryUnion() const;
+    static void toVector(const Geometry* g, std::vector<const Geometry*>& v);
+    void unionByDimension(void);
+private:
+    const GeometryFactory* factory;
+    std::vector<const Geometry*> pts;
+    std::vector<const Geometry*> lines;
+    std::vector<const Geometry*> polys;
+    std::unique_ptr<Geometry> pt_union;
+    std::unique_ptr<Geometry> line_union;
+    std::unique_ptr<Geometry> poly_union;
 } // namespace geos::geom
 } // namespace geos
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index d514e4d36..dfd37113e 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -160,6 +160,34 @@ Geometry::getCentroid() const
     return std::unique_ptr<Point>(getFactory()->createPoint(centPt));
+/* public */
+bool
+Geometry::isMixedDimension() const
+    Dimension::DimensionType baseDim = Dimension::DONTCARE;
+    return isMixedDimension(&baseDim);
+/* public */
+bool
+Geometry::isMixedDimension(Dimension::DimensionType* baseDim) const
+    if (isCollection()) {
+        for (std::size_t i = 0; i < getNumGeometries(); i++) {
+            if (getGeometryN(i)->isMixedDimension(baseDim))
+                return true;
+        return false;
+    else {
+        if (*baseDim == Dimension::DONTCARE) {
+            *baseDim = getDimension();
+            return false;
+        return *baseDim != getDimension();
 /*public*/
 bool
 Geometry::getCentroid(CoordinateXY& ret) const
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index 05aa2b607..2d3d51304 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -25,6 +25,14 @@
 #include <geos/geom/HeuristicOverlay.h>
 #include <geos/operation/overlayng/OverlayNGRobust.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <geos/geom/MultiPoint.h>
+#include <geos/geom/MultiLineString.h>
+#include <geos/geom/MultiPolygon.h>
+#include <geos/geom/GeometryCollection.h>
+#include <geos/io/WKTWriter.h>
 namespace geos {
@@ -37,48 +45,355 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
     std::unique_ptr<Geometry> ret;
-* overlayng::OverlayNGRobust carries out the following steps
-* 1. Perform overlay operation using PrecisionModel(float).
-*    If no exception return result.
-* 2. Perform overlay operation using SnappingNoder(tolerance), starting
-*    with a very very small tolerance and increasing it for 5 iterations.
-*    The SnappingNoder moves only nodes that are within tolerance of
-*    other nodes and lines, leaving all the rest undisturbed, for a very
-*    clean result, if it manages to create one.
-*    If a result is found with no exception, return.
-* 3. Perform overlay operation using a PrecisionModel(scale), which
-*    uses a SnapRoundingNoder. Every vertex will be noded to the snapping
-*    grid, resulting in a modified geometry. The SnapRoundingNoder approach
-*    reliably produces results, assuming valid inputs.
-* Running overlayng::OverlayNGRobust at this stage should guarantee
-* that none of the other heuristics are ever needed.
-        if (g0 == nullptr && g1 == nullptr) {
-            return std::unique_ptr<Geometry>(nullptr);
+    * overlayng::OverlayNGRobust does not currently handle
+    * GeometryCollection (collections of mixed dimension)
+    * so we handle that case here.
+    if ((g0->isMixedDimension() && !g0->isEmpty()) ||
+        (g1->isMixedDimension() && !g1->isEmpty()))
+        StructuredCollection s0(g0);
+        StructuredCollection s1(g1);
+        switch (opCode) {
+        case OverlayNG::UNION:
+            return s0.doUnion(s1);
+        case OverlayNG::DIFFERENCE:
+            return s0.doDifference(s1);
+        case OverlayNG::SYMDIFFERENCE:
+            return s0.doSymDifference(s1);
+        case OverlayNG::INTERSECTION:
+            return s0.doIntersection(s1);
-        else if (g0 == nullptr) {
-            // Use a unary union for the one-parameter case, as the pairwise
-            // union with one parameter is very intolerant to invalid
-            // collections and multi-polygons.
-            ret = OverlayNGRobust::Union(g1);
+    * overlayng::OverlayNGRobust carries out the following steps
+    * 1. Perform overlay operation using PrecisionModel(float).
+    *    If no exception return result.
+    * 2. Perform overlay operation using SnappingNoder(tolerance), starting
+    *    with a very very small tolerance and increasing it for 5 iterations.
+    *    The SnappingNoder moves only nodes that are within tolerance of
+    *    other nodes and lines, leaving all the rest undisturbed, for a very
+    *    clean result, if it manages to create one.
+    *    If a result is found with no exception, return.
+    * 3. Perform overlay operation using a PrecisionModel(scale), which
+    *    uses a SnapRoundingNoder. Every vertex will be noded to the snapping
+    *    grid, resulting in a modified geometry. The SnapRoundingNoder approach
+    *    reliably produces results, assuming valid inputs.
+    * Running overlayng::OverlayNGRobust at this stage should guarantee
+    * that none of the other heuristics are ever needed.
+    if (g0 == nullptr && g1 == nullptr) {
+        return std::unique_ptr<Geometry>(nullptr);
+    else if (g0 == nullptr) {
+        // Use a unary union for the one-parameter case, as the pairwise
+        // union with one parameter is very intolerant to invalid
+        // collections and multi-polygons.
+        ret = OverlayNGRobust::Union(g1);
+    else if (g1 == nullptr) {
+        ret = OverlayNGRobust::Union(g0);
+    else {
+        ret = OverlayNGRobust::Overlay(g0, g1, opCode);
+    return ret;
+/* public */
+void
+StructuredCollection::readCollection(const Geometry* g)
+    if (!factory) factory = g->getFactory();
+    if (g->isCollection()) {
+        for (std::size_t i = 0; i < g->getNumGeometries(); i++) {
+            readCollection(g->getGeometryN(i));
-        else if (g1 == nullptr) {
-            ret = OverlayNGRobust::Union(g0);
+    else {
+        if (g->isEmpty()) return;
+        switch (g->getGeometryTypeId()) {
+            case GEOS_POINT:
+                pts.push_back(g);
+                break;
+            case GEOS_LINESTRING:
+                lines.push_back(g);
+                break;
+            case GEOS_POLYGON:
+                polys.push_back(g);
+                break;
+            default:
+                throw util::IllegalArgumentException("cannot process unexpected collection");
+/* public static */
+void
+StructuredCollection::toVector(const Geometry* g, std::vector<const Geometry*>& v)
+    if (!g || g->isEmpty()) return;
+            toVector(g->getGeometryN(i), v);
-        else {
-            ret = OverlayNGRobust::Overlay(g0, g1, opCode);
+    else {
+            case GEOS_POINT:
+                v.push_back(g);
+                break;
+            default:
+                return;
+/* public */
+void
+StructuredCollection::unionByDimension(void)
+    * Remove duplication within each dimension, so that there
+    * is only one object covering any particular space within
+    * that dimension.
+    * This makes reasoning about the collection-on-collection
+    * operations a little easier later on.
+    std::unique_ptr<MultiPoint> pt_col = factory->createMultiPoint(pts);
+    std::unique_ptr<MultiLineString> line_col = factory->createMultiLineString(lines);
+    std::unique_ptr<MultiPolygon> poly_col = factory->createMultiPolygon(polys);
+    pt_union = OverlayNGRobust::Union(static_cast<const Geometry*>(pt_col.get()));
+    line_union = OverlayNGRobust::Union(static_cast<const Geometry*>(line_col.get()));
+    poly_union = OverlayNGRobust::Union(static_cast<const Geometry*>(poly_col.get()));
+    // io::WKTWriter w;
+    // std::cout << "line_col " << w.write(*line_col) << std::endl;
+    // std::cout << "line_union " << w.write(*line_union) << std::endl;
+    if (! pt_union->isPuntal())
+        throw util::IllegalArgumentException("union of points not puntal");
+    if (! line_union->isLineal())
+        throw util::IllegalArgumentException("union of lines not lineal");
+    if (! poly_union->isPolygonal())
+        throw util::IllegalArgumentException("union of polygons not polygonal");
+/* public */
+std::unique_ptr<Geometry>
+StructuredCollection::doUnaryUnion() const
+    * Before output, we clean up the components to remove spatial
+    * duplication. Points that lines pass through. Lines that are covered
+    * by polygonal areas already. Provides a "neater" output that still
+    * covers all the area it should.
+    std::unique_ptr<Geometry> pts_less_lines = OverlayNGRobust::Overlay(
+        pt_union.get(),
+        line_union.get(),
+        OverlayNG::DIFFERENCE);
+    std::unique_ptr<Geometry> pts_less_polys_lines = OverlayNGRobust::Overlay(
+        pts_less_lines.get(),
+        poly_union.get(),
+    std::unique_ptr<Geometry> lines_less_polys = OverlayNGRobust::Overlay(
+        line_union.get(),
+        poly_union.get(),
+    std::vector<const Geometry*> geoms;
+    toVector(pts_less_polys_lines.get(), geoms);
+    toVector(lines_less_polys.get(), geoms);
+    toVector(poly_union.get(), geoms);
+    return factory->buildGeometry(geoms.begin(), geoms.end());
+/* public */
+StructuredCollection::doUnion(const StructuredCollection& a) const
+    auto poly_union_poly = OverlayNGRobust::Overlay(
+        a.getPolyUnion(),
+        poly_union.get(),
+        OverlayNG::UNION);
+    auto line_union_line = OverlayNGRobust::Overlay(
+        a.getLineUnion(),
+        line_union.get(),
+    auto pt_union_pt = OverlayNGRobust::Overlay(
+        a.getPointUnion(),
+        pt_union.get(),
+    StructuredCollection c;
+    c.readCollection(poly_union_poly.get());
+    c.readCollection(line_union_line.get());
+    c.readCollection(pt_union_pt.get());
+    c.unionByDimension();
+    return c.doUnaryUnion();
+StructuredCollection::doIntersection(const StructuredCollection& a) const
+    std::unique_ptr<Geometry> poly_inter_poly = OverlayNGRobust::Overlay(
+        poly_union.get(),
+        a.getPolyUnion(),
+        OverlayNG::INTERSECTION);
+    std::unique_ptr<Geometry> poly_inter_line = OverlayNGRobust::Overlay(
+        poly_union.get(),
+        a.getLineUnion(),
+    std::unique_ptr<Geometry> poly_inter_pt = OverlayNGRobust::Overlay(
+        poly_union.get(),
+    std::unique_ptr<Geometry> line_inter_poly = OverlayNGRobust::Overlay(
+        line_union.get(),
+        a.getPolyUnion(),
+    std::unique_ptr<Geometry> line_inter_line = OverlayNGRobust::Overlay(
+        line_union.get(),
+        a.getLineUnion(),
-        return ret;
+    std::unique_ptr<Geometry> line_inter_pt = OverlayNGRobust::Overlay(
+        line_union.get(),
+    std::unique_ptr<Geometry> pt_inter_pt = OverlayNGRobust::Overlay(
+        pt_union.get(),
+    std::unique_ptr<Geometry> pt_inter_line = OverlayNGRobust::Overlay(
+        pt_union.get(),
+        a.getLineUnion(),
+    std::unique_ptr<Geometry> pt_inter_poly = OverlayNGRobust::Overlay(
+        pt_union.get(),
+        a.getPolyUnion(),
+    // std::cout << "poly_inter_poly " << w.write(*poly_inter_poly) << std::endl;
+    // std::cout << "poly_union.get() " << w.write(poly_union.get()) << std::endl;
+    // std::cout << "a.getLineUnion() " << w.write(a.getLineUnion()) << std::endl;
+    // std::cout << "poly_inter_line " << w.write(*poly_inter_line) << std::endl;
+    // std::cout << "poly_inter_pt " << w.write(*poly_inter_pt) << std::endl;
+    // std::cout << "line_inter_line " << w.write(*line_inter_line) << std::endl;
+    // std::cout << "line_inter_pt " << w.write(*line_inter_pt) << std::endl;
+    // std::cout << "pt_inter_pt " << w.write(*pt_inter_pt) << std::endl;
+    c.readCollection(poly_inter_poly.get());
+    c.readCollection(poly_inter_line.get());
+    c.readCollection(poly_inter_pt.get());
+    c.readCollection(line_inter_poly.get());
+    c.readCollection(line_inter_line.get());
+    c.readCollection(line_inter_pt.get());
+    c.readCollection(pt_inter_poly.get());
+    c.readCollection(pt_inter_line.get());
+    c.readCollection(pt_inter_pt.get());
+StructuredCollection::doDifference(const StructuredCollection& a) const
+    std::unique_ptr<Geometry> poly_diff_poly = OverlayNGRobust::Overlay(
+        poly_union.get(),
+        a.getPolyUnion(),
+    std::unique_ptr<Geometry> line_diff_poly = OverlayNGRobust::Overlay(
+        line_union.get(),
+        a.getPolyUnion(),
+    std::unique_ptr<Geometry> pt_diff_poly = OverlayNGRobust::Overlay(
+        pt_union.get(),
+        a.getPolyUnion(),
+    std::unique_ptr<Geometry> line_diff_poly_line = OverlayNGRobust::Overlay(
+        line_diff_poly.get(),
+        a.getLineUnion(),
+    std::unique_ptr<Geometry> pt_diff_poly_line = OverlayNGRobust::Overlay(
+        pt_diff_poly.get(),
+        line_diff_poly_line.get(),
+    std::unique_ptr<Geometry> pt_diff_poly_line_pt = OverlayNGRobust::Overlay(
+        pt_diff_poly_line.get(),
+    c.readCollection(poly_diff_poly.get());
+    c.readCollection(line_diff_poly_line.get());
+    c.readCollection(pt_diff_poly_line_pt.get());
+StructuredCollection::doSymDifference(const StructuredCollection& a) const
+    std::unique_ptr<Geometry> poly_symdiff_poly = OverlayNGRobust::Overlay(
+        poly_union.get(),
+        a.getPolyUnion(),
+        OverlayNG::SYMDIFFERENCE);
+    std::unique_ptr<Geometry> line_symdiff_line = OverlayNGRobust::Overlay(
+        line_union.get(),
+        a.getLineUnion(),
+    std::unique_ptr<Geometry> pt_symdiff_pt = OverlayNGRobust::Overlay(
+        pt_union.get(),
+    c.readCollection(poly_symdiff_poly.get());
+    c.readCollection(line_symdiff_line.get());
+    c.readCollection(pt_symdiff_pt.get());
 } // namespace geos
diff --git a/tests/unit/geom/DimensionTest.cpp b/tests/unit/geom/DimensionTest.cpp
index c37d54ff9..5ac000d16 100644
--- a/tests/unit/geom/DimensionTest.cpp
+++ b/tests/unit/geom/DimensionTest.cpp
@@ -5,6 +5,7 @@
 #include <tut/tut.hpp>
 // geos
+#include <geos/io/WKTReader.h>
 #include <geos/util.h>
@@ -137,5 +138,21 @@ void object::test<5>
+template<>
+template<>
+void object::test<6>
+    using geos::geom::Dimension;
+    geos::io::WKTReader reader;
+    auto geom = reader.read("GEOMETRYCOLLECTION(POINT(1 1), LINESTRING(2 2, 3 3))");
+    Dimension::DimensionType d = geom->getDimension();
+    // std::cout << d << std::endl;
+    // getDimension() finds the highest dimension in the collection
+    ensure(d == Dimension::L);
 } // namespace tut
diff --git a/tests/unit/geom/HeuristicOverlayTest.cpp b/tests/unit/geom/HeuristicOverlayTest.cpp
new file mode 100644
index 000000000..c687e8a69
--- /dev/null
+++ b/tests/unit/geom/HeuristicOverlayTest.cpp
@@ -0,0 +1,207 @@
+// Test Suite for geos::geom::HeuristicOverlay
+#include <tut/tut.hpp>
+// geos
+#include <geos/algorithm/hull/ConcaveHull.h>
+#include <geos/constants.h>
+#include <geos/geom/HeuristicOverlay.h>
+#include <geos/operation/overlayng/OverlayNG.h>
+#include <utility.h>
+// std
+#include <string>
+#include <memory>
+namespace tut {
+// Test Group
+using geos::operation::overlayng::OverlayNG;
+struct test_heuristic_data {
+    WKTReader reader_;
+    WKTWriter writer_;
+    test_heuristic_data() {}
+    void checkOverlay(
+        const std::string& wkt1,
+        const std::string& wkt2,
+        int opCode,
+        const std::string& wkt_expected)
+        std::unique_ptr<Geometry> g1 = reader_.read(wkt1);
+        std::unique_ptr<Geometry> g2 = reader_.read(wkt2);
+        std::unique_ptr<Geometry> expected = reader_.read(wkt_expected);
+        std::unique_ptr<Geometry> actual = HeuristicOverlay(g1.get(), g2.get(), opCode);
+        // std::cout << "expected:" << std::endl << writer_.write(*expected) << std::endl;
+        // std::cout << "actual:" << std::endl << writer_.write(*actual) << std::endl;
+        ensure_equals_geometry(expected.get(), actual.get());
+typedef test_group<test_heuristic_data> group;
+typedef group::object object;
+group test_heuristic_data("geos::geom::HeuristicOverlay");
+// Test Cases
+// These tests exercise the special cast code in HeuristicOverlay
+// for GeometryCollection in which the contents are "mixed dimension",
+// such as points and lines or lines and polygons in the same collection.
+// For those cases the result of the overlay might be a matter of
+// interpretation, depending on the inputs and the opinions of the
+// end user. The implementation just tries to generate a visually
+// defensible, simplified answer.
+template<>
+template<>
+void object::test<1> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION(POINT(0 0), LINESTRING(1 1, 2 2))",
+        "GEOMETRYCOLLECTION(POINT(10 10), LINESTRING(11 11, 12 12))",
+        OverlayNG::UNION,
+        "GEOMETRYCOLLECTION(POINT(0 0), LINESTRING(1 1, 2 2), POINT(10 10), LINESTRING(11 11, 12 12))"
+template<>
+template<>
+void object::test<2> ()
+    checkOverlay(
+        "POLYGON((-10 -10, -10 10, 10 10, 10 -10, -10 -10))",
+        OverlayNG::UNION,
+template<>
+template<>
+void object::test<3> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION(POINT(0.5 0.5), LINESTRING(0 0, 2 2), POLYGON((0 0, 1 0, 1 1, 0 1, 0 0)))",
+        "GEOMETRYCOLLECTION(LINESTRING(0.5 0.5, 0.5 4), POINT(2 0))",
+        OverlayNG::UNION,
+        "GEOMETRYCOLLECTION (POINT (2 0), LINESTRING (0.5 1, 0.5 4), LINESTRING (1 1, 2 2), POLYGON ((0 1, 1 1, 1 0, 0 0, 0 1)))"
+template<>
+template<>
+void object::test<4> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), LINESTRING(20 20, 30 30))",
+        "GEOMETRYCOLLECTION(POLYGON((9 9, 21 9, 21 21, 9 21, 9 9)), POINT(5 5))",
+        OverlayNG::DIFFERENCE,
+        "GEOMETRYCOLLECTION (LINESTRING (21 21, 30 30), POLYGON ((10 0, 0 0, 0 10, 9 10, 9 9, 10 9, 10 0)))"
+template<>
+template<>
+void object::test<5> ()
+    checkOverlay(
+        OverlayNG::INTERSECTION,
+        "GEOMETRYCOLLECTION (POINT (5 5), LINESTRING(20 20, 21 21), POLYGON ((10 10, 10 9, 9 9, 9 10, 10 10)))"
+template<>
+template<>
+void object::test<6> ()
+    checkOverlay(
+        OverlayNG::SYMDIFFERENCE,
+        "GEOMETRYCOLLECTION (LINESTRING (21 21, 30 30), POLYGON ((0 0, 0 10, 9 10, 9 9, 10 9, 10 0, 0 0)), POLYGON ((9 10, 9 21, 21 21, 21 9, 10 9, 10 10, 9 10)))"
+template<>
+template<>
+void object::test<7> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)))",
+        OverlayNG::UNION,
+        "POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))"
+template<>
+template<>
+void object::test<8> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), POINT(20 20))",
+        "GEOMETRYCOLLECTION EMPTY"
+template<>
+template<>
+void object::test<9> ()
+    checkOverlay(
+template<>
+template<>
+void object::test<10> ()
+    checkOverlay(
+        "GEOMETRYCOLLECTION(POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)), POINT EMPTY, MULTIPOINT(4 4, 11 11), LINESTRING(5 5, 6 6))",
+        "GEOMETRYCOLLECTION(POLYGON((2 2, 12 2, 12 12, 2 12, 2 2)), LINESTRING EMPTY, MULTIPOINT(4 4, 11 11), LINESTRING(5 6, 6 5))",
+        "GEOMETRYCOLLECTION (POINT (11 11), POLYGON ((10 10, 10 2, 2 2, 2 10, 10 10)))"
+template<>
+template<>
+void object::test<11> ()
+    checkOverlay(
+        OverlayNG::UNION,
+        "POLYGON ((2 12, 12 12, 12 2, 10 2, 10 0, 0 0, 0 10, 2 10, 2 12))"
+} // namespace tut
Summary of changes:
 include/geos/geom/Geometry.h             |   3 +
 include/geos/geom/HeuristicOverlay.h     |  68 +++++-
 src/geom/Geometry.cpp                    |  28 +++
 src/geom/HeuristicOverlay.cpp            | 387 ++++++++++++++++++++++++++++---
 tests/unit/geom/DimensionTest.cpp        |  17 ++
 tests/unit/geom/HeuristicOverlayTest.cpp | 207 +++++++++++++++++
 6 files changed, 672 insertions(+), 38 deletions(-)
 create mode 100644 tests/unit/geom/HeuristicOverlayTest.cpp
hooks/post-receive
More information about the geos-commits
