[geos-commits] [SCM] GEOS branch main updated. 59d9f5073e49db96ab93ddddbcfb4de67c151e48
Thu May 11 08:47:15 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  59d9f5073e49db96ab93ddddbcfb4de67c151e48 (commit)
       via  091f6d99fd2d6485c8f1be1106f914c4bb4c2b84 (commit)
      from  12321f7276512ec722bc95ad51e2a8e01acc9ea1 (commit)
revisions in full, below.
commit 59d9f5073e49db96ab93ddddbcfb4de67c151e48
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 11 08:46:46 2023 -0700
    remove EOLed versions from download list
diff --git a/web/content/usage/download.md b/web/content/usage/download.md
index 29f35a7f3..83d264711 100644
--- a/web/content/usage/download.md
+++ b/web/content/usage/download.md
@@ -14,16 +14,9 @@ draft: false
 |  **3.9.4**  | 2022/11/14 | 2020/12/09 | *2024/12/09* | [geos-3.9.4.tar.bz2](https://download.osgeo.org/geos/geos-3.9.4.tar.bz2) | [Changes](https://github.com/libgeos/geos/blob/3.9.4/NEWS) |
 |  **3.8.3** | 2022/06/02 |  2019/10/10 | *2023/10/10* | [geos-3.8.3.tar.bz2](https://download.osgeo.org/geos/geos-3.8.3.tar.bz2) | [Changes](https://github.com/libgeos/geos/blob/3.8.3/NEWS) |
 | **3.7.5**  | 2022/06/08  | 2018/09/10 | *2023/03/31*  | [geos-3.7.5.tar.bz2](https://download.osgeo.org/geos/geos-3.7.5.tar.bz2) | [Changes](https://github.com/libgeos/geos/blob/3.7.5/NEWS) |
-| **3.6.6** EOL | 2023/01/27 | 2016/10/25 | 2023/01/27 | [geos-3.6.6.tar.bz2](https://download.osgeo.org/geos/geos-3.6.6.tar.bz2) | [Changes](https://github.com/libgeos/geos/blob/3.6.6/NEWS) |
-| **3.5.2** EOL | 2019/10/04 | 2015/08/16 | 2019/10/04|  [geos-3.5.2.tar.bz2](https://download.osgeo.org/geos/geos-3.5.2.tar.bz2) | [Changes](https://github.com/libgeos/geos/blob/3.5.2/NEWS) |
-If you see **EOL** next to a released version, it means no security or patch updates will be added to that minor and you should upgrade to a higher release.
-Refer to our [End-Of-Life (EOL) Policy](/project/rfcs/rfc11/) for details.
-Older releases prior to the ones listed above, are all EOL'd.
+Old releases can be downloaded from https://download.osgeo.org/geos/.  Any releases not in this list are end-of-life (EOL). Refer to our [EOL policy](/project/rfcs/rfc11/) for details. All *Final Release* dates are subject to change.
-Old releases can be downloaded from https://download.osgeo.org/geos/.
-All *future* **Final Release** dates are subject to change.
 ## Build From Source
commit 091f6d99fd2d6485c8f1be1106f914c4bb4c2b84
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 8 11:50:04 2023 +0200
    Only keep biggest polygon from single-sided buffer
    Closes GH-665
    Closes #810
    Closes #712
    Includes unit test
diff --git a/NEWS.md b/NEWS.md
index 14714aee3..82ac7c79d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -65,6 +65,7 @@ xxxx-xx-xx
   - Fix MaximumInscribedCircle and LargestEmptyCircle performance and memory issues (GH-883, Martin Davis)
   - GEOSHasZ: Fix handling with empty geometries (GH-887, Mike Taves)
   - OffsetCurve: fix EndCap parameter handling (GH-899, Martin Davis)
+  - Reduce artifacts in single-sided Buffers: (GH-665 #810 and #712, Sandro Santilli)
 - Changes:
   - Remove Orientation.isCCW exception to simplify logic and align with JTS (GH-878, Martin Davis)
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 500d729e2..8ebe484ff 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -35,6 +35,7 @@
 #include <geos/operation/overlay/snap/SnapOverlayOp.h>
 #include <geos/operation/overlay/PolygonBuilder.h>
 #include <geos/operation/overlay/OverlayNodeFactory.h>
+#include <geos/operation/polygonize/Polygonizer.h>
 #include <geos/operation/valid/RepeatedPointRemover.h>
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/algorithm/LineIntersector.h>
@@ -478,6 +479,73 @@ BufferBuilder::buffer(const Geometry* g, double distance)
         throw;
+    // Cleanup single-sided buffer artifacts, if needed
+    if ( bufParams.isSingleSided() )
+        // Get linework of input geom
+        const Geometry *inputLineString = g;
+        std::unique_ptr<Geometry> inputPolygonBoundary;
+        if ( g->getDimension() > 1 )
+            inputPolygonBoundary = g->getBoundary();
+            inputLineString = inputPolygonBoundary.get();
+#if GEOS_DEBUG
+        std::cerr << "Input linework: " << *inputLineString << std::endl;
+#endif
+        // Get linework of buffer geom
+        std::unique_ptr<Geometry> bufferBoundary = resultGeom->getBoundary();
+#if GEOS_DEBUG
+        std::cerr << "Buffer boundary: " << *bufferBoundary << std::endl;
+#endif
+        // Node all linework
+        using operation::overlayng::OverlayNG;
+        std::unique_ptr<Geometry> nodedLinework = OverlayNG::overlay(inputLineString, bufferBoundary.get(), OverlayNG::UNION);
+#if GEOS_DEBUG
+        std::cerr << "Noded linework: " << *nodedLinework << std::endl;
+#endif
+        using operation::polygonize::Polygonizer;
+        Polygonizer plgnzr;
+        plgnzr.add(nodedLinework.get());
+        std::vector<std::unique_ptr<geom::Polygon>> polys = plgnzr.getPolygons();
+#if GEOS_DEBUG
+        std::cerr << "Polygonization of noded linework returend: " << polys.size() << " polygons" << std::endl;
+#endif
+        if ( polys.size() > 1 )
+            // Only keep larger polygon
+            std::vector<std::unique_ptr<geom::Polygon>>::iterator
+                it,
+                itEnd = polys.end(),
+                biggestPolygonIterator = itEnd;
+            double maxArea = 0;
+            for ( it = polys.begin(); it != itEnd; ++it )
+                double area = (*it)->getArea();
+                if ( area > maxArea )
+                    biggestPolygonIterator = it;
+                    maxArea = area;
+            if ( biggestPolygonIterator != itEnd ) {
+                Geometry *gg = (*biggestPolygonIterator).release();
+                return std::unique_ptr<Geometry>( gg );
+            } // else there were no polygons formed...
     return resultGeom;
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index a40e85a31..a1ff2e557 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -549,4 +549,25 @@ void object::test<20>
     ensure( 0 == dynamic_cast<const geos::geom::Polygon*>(result1.get())->getNumInteriorRing() );
+// Test for single-sided buffer
+// See https://github.com/libgeos/geos/issues/665
+template<>
+template<>
+void object::test<21>
+    using geos::operation::buffer::BufferOp;
+    using geos::operation::buffer::BufferParameters;
+    std::string wkt("LINESTRING (50 50, 150 150, 150 100, 150 0)");
+    GeomPtr geom(wktreader.read(wkt));
+    geos::operation::buffer::BufferParameters bp;
+    bp.setSingleSided(true);
+    geos::operation::buffer::BufferOp op(geom.get(), bp);
+    std::unique_ptr<Geometry> result = op.getResultGeometry(-21);
+    ensure_equals(int(result->getArea()), 5055);
 } // namespace tut
Summary of changes:
 NEWS.md                                      |  1 +
 src/operation/buffer/BufferBuilder.cpp       | 68 ++++++++++++++++++++++++++++
 tests/unit/operation/buffer/BufferOpTest.cpp | 21 +++++++++
 web/content/usage/download.md                |  9 +---
 4 files changed, 91 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
