[geos-commits] [SCM] GEOS branch main updated. 46c3b99274b0f0dfacf96184bd9a8cf603489267
Mon May 15 04:04:17 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  46c3b99274b0f0dfacf96184bd9a8cf603489267 (commit)
      from  2cac99d49fef48d4054f4d74bfc3cbd7bc8bcdcf (commit)
revisions in full, below.
commit 46c3b99274b0f0dfacf96184bd9a8cf603489267
Author: Mike Taves <mwtoews at gmail.com>
Date:   Mon May 15 13:04:08 2023 +1200
    Fix reading MultiPoint Z/M WKT (#901)
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index efe6d9219..3ed640630 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -338,9 +338,8 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer, OrdinateSet& ordinateF
     int tok = tokenizer->peekNextToken();
     if(tok == StringTokenizer::TT_NUMBER) {
-        // Try to parse deprecated form "MULTIPOINT(0 0, 1 1)"
-        auto coords = detail::make_unique<CoordinateSequence>();
+        // Try to parse "MULTIPOINT (0 0, 1 1)"
+        auto coords = detail::make_unique<CoordinateSequence>(0u, ordinateFlags.hasZ(), ordinateFlags.hasM());
         CoordinateXYZM coord(0, 0, DoubleNotANumber, DoubleNotANumber);
         do {
@@ -353,8 +352,8 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer, OrdinateSet& ordinateF
         return std::unique_ptr<MultiPoint>(geometryFactory->createMultiPoint(*coords));
-    else if(tok == '(' ||  // Try to parse correct form "MULTIPOINT((0 0), (1 1))"
-            tok == StringTokenizer::TT_WORD)  // EMPTY?
+    else if(tok == '(' ||        // Try to parse "MULTIPOINT ((0 0), (1 1))"
+            tok == StringTokenizer::TT_WORD)  // "MULTIPOINT (EMPTY, (1 1))"
         std::vector<std::unique_ptr<Point>> points;
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 067dedabc..3180a6686 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -49,6 +49,12 @@ struct test_wktreader_data {
                       dim);
+    void ensure_dimension(const std::string & wkt, bool has_z, bool has_m) const {
+        auto geom = wktreader.read(wkt);
+        ensure_equals(wkt + " hasZ", geom->hasZ(), has_z);
+        ensure_equals(wkt + " hasM", geom->hasM(), has_m);
     void ensure_parseexception(const std::string & wkt) const {
         try {
@@ -423,4 +429,22 @@ void object::test<21>
+// https://github.com/libgeos/geos/issues/886
+template<>
+template<>
+void object::test<22>
+    ensure_dimension("MULTIPOINT (0 0, 1 2)", false, false);
+    ensure_dimension("MULTIPOINT Z (0 0 4, 1 2 4)", true, false);
+    ensure_dimension("MULTIPOINT M (0 0 3, 1 2 5)", false, true);
+    ensure_dimension("MULTIPOINT ZM (0 0 4 3, 1 2 4 5)", true, true);
+    ensure_dimension("MULTIPOINT ((0 0), (1 2))", false, false);
+    ensure_dimension("MULTIPOINT Z ((0 0 4), (1 2 4))", true, false);
+    ensure_dimension("MULTIPOINT M ((0 0 3), (1 2 5))", false, true);
+    ensure_dimension("MULTIPOINT ZM ((0 0 4 3), (1 2 4 5))", true, true);
 } // namespace tut
Summary of changes:
 src/io/WKTReader.cpp            |  9 ++++-----
 tests/unit/io/WKTReaderTest.cpp | 24 ++++++++++++++++++++++++
 2 files changed, 28 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
