[geos-commits] [SCM] GEOS branch 3.10 updated. 9b5e544da70a58becd7bca4251e6b43942124da2
git at osgeo.org
git at osgeo.org
Thu Nov 9 00:25:40 PST 2023
the project "GEOS".
The branch, 3.10 has been updated
via 9b5e544da70a58becd7bca4251e6b43942124da2 (commit)
via ee20b490155fc96acd4009e4b6700d05f2b696ba (commit)
via 53f477d8f64d7924d7ff7a0a3b7e7e44328468f8 (commit)
from d5838838b456806609cd277925df558e16e5f906 (commit)
revisions in full, below.
commit 9b5e544da70a58becd7bca4251e6b43942124da2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 2 14:49:21 2023 -0700
News entry for #979
diff --git a/NEWS b/NEWS
index bec45650b..82b9dd0fe 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ Changes in 3.10.6
- GEOSClipByRect: Fix case with POINT EMPTY (GH-913, Mike Taves)
- Remove undefined behaviour in use of null PrecisionModel (GH-931, Jeff Walton)
- PreparedLineStringIntersects: Fix incorrect result with mixed-dim collection with points (GH-774, Dan Baston)
+ - Skip over testing empty distances for mixed collections (GH-979, Paul Ramsey)
Changes in 3.10.5
2023-03-16
commit ee20b490155fc96acd4009e4b6700d05f2b696ba
Date: Thu Nov 2 14:45:36 2023 -0700
Skip over testing empty distances for mixed collections. Closes #979
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index 5c9fa3be3..74fa64d5f 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -362,6 +362,10 @@ DistanceOp::computeMinDistanceLines(
for(const LineString* line0 : lines0) {
for(const LineString* line1 : lines1) {
+ if (line0->isEmpty() || line1->isEmpty())
+ continue;
computeMinDistance(line0, line1, locGeom);
if(minDistance <= terminateDistance) {
return;
@@ -378,13 +382,11 @@ DistanceOp::computeMinDistancePoints(
std::array<std::unique_ptr<GeometryLocation>, 2> & locGeom)
for(const Point* pt0 : points0) {
- if (pt0->isEmpty()) {
- continue;
for(const Point* pt1 : points1) {
- if (pt1->isEmpty()) {
+ if (pt1->isEmpty() || pt0->isEmpty())
continue;
double dist = pt0->getCoordinate()->distance(*(pt1->getCoordinate()));
#if GEOS_DEBUG
@@ -418,6 +420,10 @@ DistanceOp::computeMinDistanceLinesPoints(
for(const LineString* line : lines) {
for(const Point* pt : points) {
+ if (line->isEmpty() || pt->isEmpty())
+ continue;
computeMinDistance(line, pt, locGeom);
return;
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index e80a0e143..16414a8bb 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -565,6 +565,11 @@ void object::test<21>()
ensure_equals(g1->distance(g2.get()), 1.9996999774966246);
+// Variations on a theme: testing EMPTY and collections with EMPTY
+// Ignoring empty component
template<>
template<>
void object::test<22>()
@@ -576,6 +581,69 @@ void object::test<22>()
ensure_equals(g2->distance(g1.get()), 1);
+// Empty is same as empty so zero...?
+template<>
+template<>
+void object::test<23>()
+ auto g1 = wktreader.read("POINT EMPTY");
+ auto g2 = wktreader.read("LINESTRING EMPTY");
+ ensure(g1 != nullptr && g2 != nullptr);
+ ensure_equals(g1->distance(g2.get()), 0);
+ ensure_equals(g2->distance(g1.get()), 0);
+template<>
+template<>
+void object::test<24>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT EMPTY, LINESTRING EMPTY)");
+// But ignore empty if there's a real distance?
+template<>
+template<>
+void object::test<25>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(LINESTRING EMPTY, POINT(2 1))");
+ auto g2 = wktreader.read("POINT(1 1)");
+ ensure_equals(g1->distance(g2.get()), 1);
+ ensure_equals(g2->distance(g1.get()), 1);
+template<>
+template<>
+void object::test<26>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT(-2 0), POINT EMPTY)");
+ auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0),LINESTRING(0 0,1 0))");
+ ensure_equals(g1->distance(g2.get()), 2);
+ ensure_equals(g2->distance(g1.get()), 2);
+template<>
+template<>
+void object::test<27>()
+ auto g1 = wktreader.read("GEOMETRYCOLLECTION(POINT EMPTY)");
+ auto g2 = wktreader.read("GEOMETRYCOLLECTION(POINT(1 0))");
// TODO: finish the tests by adding:
// LINESTRING - *all*
// MULTILINESTRING - *all*
diff --git a/tests/xmltester/tests/general/TestDistance.xml b/tests/xmltester/tests/general/TestDistance.xml
index 4ce6d0fed..3835c919d 100644
--- a/tests/xmltester/tests/general/TestDistance.xml
+++ b/tests/xmltester/tests/general/TestDistance.xml
@@ -6,6 +6,7 @@
<a> POINT(10 10) </a>
<b> POINT EMPTY </b>
<test><op name="distance" arg1="A" arg2="B"> 0.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A"> 0.0 </op></test>
</case>
<case>
@@ -13,6 +14,31 @@
<b> POINT (10 0) </b>
<test><op name="distance" arg1="A" arg2="B"> 10.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A"> 10.0 </op></test>
+</case>
+<case>
+ <desc>PP - point to multipoint</desc>
+ <a> POINT(10 10) </a>
+ <b> MULTIPOINT ((10 0), (30 30)) </b>
+<test><op name="distance" arg1="A" arg2="B"> 10.0 </op></test>
+</case>
+<case>
+ <desc>PP - point to multipoint with empty element</desc>
+ <b> MULTIPOINT ((10 0), EMPTY) </b>
+</case>
+<case>
+ <desc>LL - line to empty line</desc>
+ <a> LINESTRING (0 0, 0 10) </a>
+ <b> LINESTRING EMPTY </b>
+<test><op name="distance" arg1="A" arg2="B"> 0.0 </op></test>
</case>
<case>
@@ -20,6 +46,31 @@
<b> LINESTRING (10 0, 10 10) </b>
+</case>
+<case>
+ <desc>LL - line to multiline</desc>
+ <b> MULTILINESTRING ((10 0, 10 10), (50 50, 60 60)) </b>
+</case>
+<case>
+ <desc>LL - line to multiline with empty element</desc>
+ <b> MULTILINESTRING ((10 0, 10 10), EMPTY) </b>
+</case>
+<case>
+ <desc>PA - point to empty polygon</desc>
+ <a> POINT (240 160) </a>
+ <b> POLYGON EMPTY </b>
+<test><op name="distance" arg1="A" arg2="B" > 0.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 0.0 </op></test>
</case>
<case>
@@ -27,6 +78,7 @@
<b> POLYGON ((100 260, 340 180, 100 60, 180 160, 100 260)) </b>
</case>
<case>
@@ -34,6 +86,7 @@
<a> LINESTRING (40 300, 280 220, 60 160, 140 60) </a>
<b> LINESTRING (140 360, 260 280, 240 120, 120 160) </b>
</case>
<case>
@@ -41,6 +94,7 @@
<a> POLYGON ((60 260, 260 180, 100 60, 60 160, 60 260)) </a>
<b> POLYGON ((220 280, 120 160, 300 60, 360 220, 220 280)) </b>
</case>
<case>
@@ -48,6 +102,7 @@
<a> POLYGON ((100 320, 60 120, 240 180, 200 260, 100 320)) </a>
<b> POLYGON ((420 320, 280 260, 400 100, 420 320)) </b>
<test><op name="distance" arg1="A" arg2="B" > 71.55417527999327 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 71.55417527999327 </op></test>
</case>
<case>
@@ -55,13 +110,23 @@
<a> MULTIPOLYGON (((40 240, 160 320, 40 380, 40 240)), ((100 240, 240 60, 40 40, 100 240))) </a>
<b> MULTIPOLYGON (((220 280, 120 160, 300 60, 360 220, 220 280)), ((240 380, 280 300, 420 340, 240 380))) </b>
</case>
<case>
- <desc>mAmA - multipolygon with empty component</desc>
+ <desc>mAmA - multipolygon with empty element</desc>
<a> MULTIPOLYGON (EMPTY, ((98 200, 200 200, 200 99, 98 99, 98 200))) </a>
<b> POLYGON ((300 200, 400 200, 400 100, 300 100, 300 200)) </b>
<test><op name="distance" arg1="A" arg2="B" > 100.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 100.0 </op></test>
+</case>
+<case>
+ <desc>GCGC - geometry collections with mixed dimensions</desc>
+ <a> GEOMETRYCOLLECTION (LINESTRING (10 10, 50 10), POINT (90 10)) </a>
+ <b> GEOMETRYCOLLECTION (POLYGON ((90 20, 60 20, 60 50, 90 50, 90 20)), LINESTRING (10 50, 30 70)) </b>
+<test><op name="distance" arg1="A" arg2="B" > 10.0 </op></test>
+<test><op name="distance" arg1="B" arg2="A" > 10.0 </op></test>
</case>
</run>
commit 53f477d8f64d7924d7ff7a0a3b7e7e44328468f8
Author: Dan Baston <dbaston at gmail.com>
Date: Mon Dec 12 19:00:48 2022 -0500
PreparedLineStringIntersects: Fix incorrect result for mixed-dim GC with points (#774)
index e98915cd7..bec45650b 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Changes in 3.10.6
- GeoJSONReader: Fix 2D empty geometry creation (GH-910, Mike Taves)
+ - PreparedLineStringIntersects: Fix incorrect result with mixed-dim collection with points (GH-774, Dan Baston)
Changes in 3.10.5
2023-03-16
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index f5eaaab3a..6036a1aa8 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -344,6 +344,11 @@ public:
/// Returns the dimension of this Geometry (0=point, 1=line, 2=surface)
virtual Dimension::DimensionType getDimension() const = 0; //Abstract
+ /// Checks whether any component of this geometry has dimension d
+ virtual bool hasDimension(Dimension::DimensionType d) const {
+ return getDimension() == d;
/// Checks whether this Geometry consists only of components having dimension d.
virtual bool isDimensionStrict(Dimension::DimensionType d) const {
return d == getDimension();
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index 6bdf0bf68..ee6e9f9ce 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -106,6 +106,8 @@ public:
Dimension::DimensionType getDimension() const override;
+ bool hasDimension(Dimension::DimensionType d) const override;
bool isDimensionStrict(Dimension::DimensionType d) const override;
/// Returns coordinate dimension.
diff --git a/include/geos/geom/MultiLineString.h b/include/geos/geom/MultiLineString.h
index 2fd892ef5..676d48075 100644
--- a/include/geos/geom/MultiLineString.h
+++ b/include/geos/geom/MultiLineString.h
@@ -59,6 +59,10 @@ public:
/// Returns line dimension (1)
+ bool hasDimension(Dimension::DimensionType d) const override {
+ return d == Dimension::L;
bool isDimensionStrict(Dimension::DimensionType d) const override {
diff --git a/include/geos/geom/MultiPoint.h b/include/geos/geom/MultiPoint.h
index afd5f2881..c523d369c 100644
--- a/include/geos/geom/MultiPoint.h
+++ b/include/geos/geom/MultiPoint.h
@@ -66,6 +66,10 @@ public:
return d == Dimension::P;
+ return d == Dimension::P;
/// Returns Dimension::False (Point has no boundary)
int getBoundaryDimension() const override;
diff --git a/include/geos/geom/MultiPolygon.h b/include/geos/geom/MultiPolygon.h
index 9e197c02d..0ed3e5328 100644
--- a/include/geos/geom/MultiPolygon.h
+++ b/include/geos/geom/MultiPolygon.h
/// Returns surface dimension (2)
+ return d == Dimension::A;
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index f7ef36a2f..b248bc55d 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -142,6 +142,15 @@ GeometryCollection::isDimensionStrict(Dimension::DimensionType d) const {
+bool
+GeometryCollection::hasDimension(Dimension::DimensionType d) const {
+ return std::any_of(geometries.begin(),
+ geometries.end(),
+ [&d](const std::unique_ptr<Geometry>& g) {
+ return g->hasDimension(d);
int
GeometryCollection::getBoundaryDimension() const
diff --git a/src/geom/prep/PreparedLineStringIntersects.cpp b/src/geom/prep/PreparedLineStringIntersects.cpp
index 810bb5f61..8933cf7d5 100644
--- a/src/geom/prep/PreparedLineStringIntersects.cpp
+++ b/src/geom/prep/PreparedLineStringIntersects.cpp
@@ -70,11 +70,6 @@ PreparedLineStringIntersects::intersects(const geom::Geometry* g) const
return true;
- // For L/L case we are done
- if(g->getDimension() == 1) {
- return false;
// For L/A case, need to check for proper inclusion of the target in the test
if(g->getDimension() == 2
&& prepLine.isAnyTargetComponentInTest(g)) {
@@ -82,7 +77,7 @@ PreparedLineStringIntersects::intersects(const geom::Geometry* g) const
// For L/P case, need to check if any points lie on line(s)
- if(g->getDimension() == 0) {
+ if(g->hasDimension(Dimension::P)) {
return isAnyTestPointInTarget(g);
diff --git a/tests/unit/geom/GeometryCollectionTest.cpp b/tests/unit/geom/GeometryCollectionTest.cpp
index 934af2d30..41477bb2f 100644
--- a/tests/unit/geom/GeometryCollectionTest.cpp
+++ b/tests/unit/geom/GeometryCollectionTest.cpp
@@ -154,4 +154,31 @@ void object::test<7>()
ensure_equals(components.size(), 2u);
+// Test of hasDimension()
+template<>
+template<>
+void object::test<8>
+ auto gc = readWKT("GEOMETRYCOLLECTION(POINT (1 1), LINESTRING (1 1, 2 2))");
+ ensure(gc->hasDimension(geos::geom::Dimension::P));
+ ensure(gc->hasDimension(geos::geom::Dimension::L));
+ ensure(!gc->hasDimension(geos::geom::Dimension::A));
+// Test of hasDimension() for nested collection
+template<>
+template<>
+void object::test<9>
+ auto gc = readWKT("GEOMETRYCOLLECTION(POINT (1 1), GEOMETRYCOLLECTION(LINESTRING (1 1, 2 2), POLYGON((0 0, 0 1, 1 1, 0 0))))");
+ ensure(gc->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 992188762..f94c37c03 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -573,6 +573,18 @@ void object::test<31>
+template<>
+template<>
+void object::test<32>
+ auto line = reader_.read<geos::geom::LineString>("LINESTRING (0 0, 10 10)");
+ ensure(!line->hasDimension(geos::geom::Dimension::P));
+ ensure(line->hasDimension(geos::geom::Dimension::L));
+ ensure(!line->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/unit/geom/MultiLineStringTest.cpp b/tests/unit/geom/MultiLineStringTest.cpp
index 9e238be25..7e7433a9d 100644
--- a/tests/unit/geom/MultiLineStringTest.cpp
+++ b/tests/unit/geom/MultiLineStringTest.cpp
@@ -63,5 +63,18 @@ void object::test<3>
ensure(!mls_->isDimensionStrict(geos::geom::Dimension::A));
+template<>
+template<>
+void object::test<4>
+ ensure(!mls_->hasDimension(geos::geom::Dimension::P));
+ ensure(mls_->hasDimension(geos::geom::Dimension::L));
+ ensure(!mls_->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/unit/geom/MultiPointTest.cpp b/tests/unit/geom/MultiPointTest.cpp
index 24fae37f8..3f5c10373 100644
--- a/tests/unit/geom/MultiPointTest.cpp
+++ b/tests/unit/geom/MultiPointTest.cpp
@@ -417,5 +417,16 @@ void object::test<31>
ensure(!empty_mp_->isDimensionStrict(geos::geom::Dimension::L));
+template<>
+template<>
+ ensure(mp_->hasDimension(geos::geom::Dimension::P));
+ ensure(!mp_->hasDimension(geos::geom::Dimension::L));
+ ensure(!mp_->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/unit/geom/MultiPolygonTest.cpp b/tests/unit/geom/MultiPolygonTest.cpp
index 1ff9f8cd3..efe46919c 100644
--- a/tests/unit/geom/MultiPolygonTest.cpp
+++ b/tests/unit/geom/MultiPolygonTest.cpp
@@ -62,4 +62,15 @@ void object::test<3>
+template<>
+template<>
+ ensure(!mp_->hasDimension(geos::geom::Dimension::P));
+ ensure(mp_->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 75ed26259..140cfed57 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -17,6 +17,7 @@
#include <memory>
#include <string>
+constexpr int MAX_TESTS = 100;
namespace tut {
@@ -58,7 +59,7 @@ struct test_point_data {
-typedef test_group<test_point_data> group;
+typedef test_group<test_point_data, MAX_TESTS> group;
typedef group::object object;
group test_point_group("geos::geom::Point");
@@ -600,5 +601,16 @@ void object::test<46>
ensure("point->getCoordinateDimension() == 2", point->getCoordinateDimension() == 2);
+template<>
+template<>
+void object::test<47>
+ ensure(point_->hasDimension(geos::geom::Dimension::P));
+ ensure(!point_->hasDimension(geos::geom::Dimension::L));
+ ensure(!point_->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/unit/geom/PolygonTest.cpp b/tests/unit/geom/PolygonTest.cpp
index f3b4ae20b..ab1fdc501 100644
--- a/tests/unit/geom/PolygonTest.cpp
+++ b/tests/unit/geom/PolygonTest.cpp
@@ -652,4 +652,15 @@ void object::test<44>()
ensure_equals(holes.size(), 1u);
+template<>
+template<>
+void object::test<45>
+ ensure(!poly_->hasDimension(geos::geom::Dimension::P));
+ ensure(!poly_->hasDimension(geos::geom::Dimension::L));
+ ensure(poly_->hasDimension(geos::geom::Dimension::A));
} // namespace tut
diff --git a/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml b/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml
index 9ea382193..a1092a0da 100644
--- a/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml
+++ b/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml
@@ -76,6 +76,17 @@
<test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
</case>
+<case>
+ <desc>LineString against GC, with point at endpoint
+ </desc>
+ <a>
+ LINESTRING (0 0, 1 1)
+ </a>
+ <b>
+ GEOMETRYCOLLECTION (POINT (1 1), LINESTRING (2 2, 3 3))
+ </b>
+<test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
+</case>
</run>
Summary of changes:
NEWS | 2 +
include/geos/geom/Geometry.h | 5 ++
include/geos/geom/GeometryCollection.h | 2 +
include/geos/geom/MultiLineString.h | 4 ++
include/geos/geom/MultiPoint.h | 4 ++
include/geos/geom/MultiPolygon.h | 4 ++
src/geom/GeometryCollection.cpp | 9 +++
src/geom/prep/PreparedLineStringIntersects.cpp | 7 +--
src/operation/distance/DistanceOp.cpp | 16 +++--
tests/unit/geom/GeometryCollectionTest.cpp | 27 +++++++++
tests/unit/geom/LineStringTest.cpp | 12 ++++
tests/unit/geom/MultiLineStringTest.cpp | 13 +++++
tests/unit/geom/MultiPointTest.cpp | 11 ++++
tests/unit/geom/MultiPolygonTest.cpp | 11 ++++
tests/unit/geom/PointTest.cpp | 14 ++++-
tests/unit/geom/PolygonTest.cpp | 11 ++++
tests/unit/operation/distance/DistanceOpTest.cpp | 68 ++++++++++++++++++++++
tests/xmltester/tests/general/TestDistance.xml | 67 ++++++++++++++++++++-
...estPreparedPredicatesWithGeometryCollection.xml | 11 ++++
19 files changed, 285 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits
