[geos-commits] [SCM] GEOS branch main updated. fcc74fd2e38e76ce292281a33f068b66c4f8c845
Thu Nov 9 13:06:12 PST 2023
the project "GEOS".
The branch, main has been updated
       via  fcc74fd2e38e76ce292281a33f068b66c4f8c845 (commit)
      from  4118b3bb4d47169a11c1228933ba3e8510e588c4 (commit)
revisions in full, below.
commit fcc74fd2e38e76ce292281a33f068b66c4f8c845
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Nov 9 13:05:41 2023 -0800
    Fix relate computer for empty point elements (#989)
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index 04fbe31ea..7208a82a5 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -74,7 +74,12 @@ PointLocator::locate(const CoordinateXY& p, const Geometry* geom)
 void
 PointLocator::computeLocation(const CoordinateXY& p, const Geometry* geom)
+    //-- handle empty elements
+    if (geom->isEmpty()) {
+        return;
     GeometryTypeId geomTypeId = geom->getGeometryTypeId();
     switch (geomTypeId)
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index a18b65b72..c00205b81 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -209,7 +209,10 @@ GeometryGraph::addCollection(const GeometryCollection* gc)
     for(std::size_t i = 0, n = gc->getNumGeometries(); i < n; ++i) {
         const Geometry* g = gc->getGeometryN(i);
-        add(g);
+        //if (! g->isEmpty()) {
+            add(g);
diff --git a/tests/xmltester/tests/general/TestRelatePA.xml b/tests/xmltester/tests/general/TestRelatePA.xml
index 7d9e4c537..b186de01b 100644
--- a/tests/xmltester/tests/general/TestRelatePA.xml
+++ b/tests/xmltester/tests/general/TestRelatePA.xml
@@ -100,4 +100,54 @@
 </test>
 </case>
+<case>
+  <desc>mPA - empty Point element</desc>
+  <a>
+    MULTIPOINT(EMPTY,(0 0))
+  </a>
+  <b>
+    POLYGON ((1 0,0 1,-1 0,0 -1, 1 0))
+  </b>
+<test>
+  <op name="relate" arg3="0FFFFF212" arg1="A" arg2="B">
+    true
+  </op>
+</test>
+<test><op name="contains"   arg1="A" arg2="B"> false </op></test>
+<test><op name="coveredBy"  arg1="A" arg2="B"> true  </op></test>
+<test><op name="covers"     arg1="A" arg2="B"> false </op></test>
+<test><op name="crosses"    arg1="A" arg2="B"> false </op></test>
+<test><op name="disjoint"   arg1="A" arg2="B"> false </op></test>
+<test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+<test><op name="intersects" arg1="A" arg2="B"> true  </op></test>
+<test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
+<test><op name="touches"    arg1="A" arg2="B"> false </op></test>
+<test><op name="within"     arg1="A" arg2="B"> true  </op></test>
+</case>
+<case>
+  <desc>PmA - empty MultiPolygon element</desc>
+  <a>
+    POINT(0 0)
+  </a>
+  <b>
+    MULTIPOLYGON (EMPTY, ((1 0,0 1,-1 0,0 -1, 1 0)))
+  </b>
+<test>
+    true
+  </op>
+</test>
+</case>
 </run>
Summary of changes:
 src/algorithm/PointLocator.cpp                 |  7 +++-
 src/geomgraph/GeometryGraph.cpp                |  5 ++-
 tests/xmltester/tests/general/TestRelatePA.xml | 50 ++++++++++++++++++++++++++
 3 files changed, 60 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
