[geos-commits] [SCM] GEOS branch main updated. cb0550a181a2beb4c44ff0f6eabb2b91ae15da1c
Thu Nov 9 13:25:18 PST 2023
the project "GEOS".
The branch, main has been updated
       via  cb0550a181a2beb4c44ff0f6eabb2b91ae15da1c (commit)
      from  f883f95f5eb14fab1c9c7936ea45de38afd1b111 (commit)
revisions in full, below.
commit cb0550a181a2beb4c44ff0f6eabb2b91ae15da1c
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Nov 9 13:24:59 2023 -0800
    Add TestRelatePA predicate tests
diff --git a/tests/xmltester/tests/general/TestRelatePA.xml b/tests/xmltester/tests/general/TestRelatePA.xml
index b186de01b..642d682b7 100644
--- a/tests/xmltester/tests/general/TestRelatePA.xml
+++ b/tests/xmltester/tests/general/TestRelatePA.xml
@@ -15,6 +15,16 @@
     true
   </op>
 </test>
+<test><op name="contains"   arg1="A" arg2="B"> false </op></test>
+<test><op name="coveredBy"  arg1="A" arg2="B"> false </op></test>
+<test><op name="covers"     arg1="A" arg2="B"> false </op></test>
+<test><op name="crosses"    arg1="A" arg2="B"> false </op></test>
+<test><op name="disjoint"   arg1="A" arg2="B"> true  </op></test>
+<test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+<test><op name="intersects" arg1="A" arg2="B"> false </op></test>
+<test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
+<test><op name="touches"    arg1="A" arg2="B"> false </op></test>
+<test><op name="within"     arg1="A" arg2="B"> false </op></test>
 </case>
 <case>
@@ -31,6 +41,16 @@
     true
   </op>
 </test>
+<test><op name="crosses"    arg1="A" arg2="B"> true  </op></test>
+<test><op name="disjoint"   arg1="A" arg2="B"> false </op></test>
+<test><op name="intersects" arg1="A" arg2="B"> true  </op></test>
 </case>
 <case>
@@ -39,14 +59,23 @@
     MULTIPOINT((0 20), (20 20))
   </a>
   <b>
-    POLYGON(
-      (20 40, 20 0, 60 0, 60 40, 20 40))
+    POLYGON((20 40, 20 0, 60 0, 60 40, 20 40))
   </b>
 <test>
   <op name="relate" arg3="F00FFF212" arg1="A" arg2="B">
     true
   </op>
 </test>
+<test><op name="touches"    arg1="A" arg2="B"> true  </op></test>
 </case>
 <case>
@@ -55,14 +84,23 @@
     MULTIPOINT((20 20), (40 20))
   </a>
   <b>
-    POLYGON(
   </b>
 <test>
   <op name="relate" arg3="00FFFF212" arg1="A" arg2="B">
     true
   </op>
 </test>
+<test><op name="coveredBy"  arg1="A" arg2="B"> true  </op></test>
+<test><op name="within"     arg1="A" arg2="B"> true  </op></test>
 </case>
 <case>
@@ -71,14 +109,23 @@
     MULTIPOINT((80 260), (140 260), (180 260))
   </a>
   <b>
-    POLYGON(
-      (40 320, 140 320, 140 200, 40 200, 40 320))
+    POLYGON((40 320, 140 320, 140 200, 40 200, 40 320))
   </b>
 <test>
   <op name="relate" arg3="000FFF212" arg1="A" arg2="B">
     true
   </op>
 </test>
 </case>
 <case>
@@ -98,10 +145,20 @@
     true
   </op>
 </test>
 </case>
 <case>
-  <desc>mPA - empty Point element</desc>
+  <desc>mPA - empty MultiPoint element</desc>
   <a>
     MULTIPOINT(EMPTY,(0 0))
   </a>
Summary of changes:
 tests/xmltester/tests/general/TestRelatePA.xml | 71 +++++++++++++++++++++++---
 1 file changed, 64 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
