[geos-commits] [SCM] GEOS branch 3.9 updated. d5cc75b5881ba13133bd29be823314ef7269d043
git at osgeo.org
git at osgeo.org
Sat Nov 11 17:38:01 PST 2023
the project "GEOS".
The branch, 3.9 has been updated
via d5cc75b5881ba13133bd29be823314ef7269d043 (commit)
from a3e58f156eb93fcfa9e130fe49c2c3847175f30b (commit)
revisions in full, below.
commit d5cc75b5881ba13133bd29be823314ef7269d043
Author: Regina Obe <lr at pcorp.us>
Date: Sat Nov 11 19:42:41 2023 -0500
Prepping for GEOS 3.9.5 release
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
new file mode 100644
index 000000000..21c6571d8
--- /dev/null
+++ b/.github/workflows/release.yml
@@ -0,0 +1,77 @@
+# GitHub Actions for GEOS Web Pages
+# Paul Ramsey <pramsey at cleverelephant.ca>, Regina Obe <lr at pcorp.us>
+# Only run on tag
+# Only release if distcheck succeeds
+# Only release of the tag name is identical to the full version
+# Use the first block of NEWS entries as release notes
+name: 'Release'
+on:
+ push:
+ tags:
+jobs:
+ release:
+ name: 'Release on Tag'
+ runs-on: ubuntu-latest
+ # Only run docbuild on central repo
+ if: github.repository == 'libgeos/geos'
+ steps:
+ - name: 'Install'
+ run: |
+ pwd
+ uname -a
+ sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
+ - name: 'Check Out'
+ uses: actions/checkout at v3
+ - name: Get tag
+ id: tag
+ uses: dawidd6/action-get-tag at v1
+ - name: 'Read Version'
+ id: version
+ run: |
+ pwd
+ source Version.txt
+ GEOS_FULL_VERSION=${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}${GEOS_PATCH_WORD}
+ echo GEOS_FULL_VERSION $GEOS_FULL_VERSION
+ echo "::set-output name=geosversion::${GEOS_FULL_VERSION}"
+ - name: 'Create Release Notes'
+ id: notes
+ run: |
+ pwd
+ perl tools/ci/releasenotes.pl NEWS > release.md
+ echo "::set-output name=geosnotes::./release.md"
+ - name: 'Bundle & Check Package'
+ id: bundle
+ run: |
+ pwd
+ set -e
+ mkdir _build && cd _build
+ cmake -DBUILD_DOCUMENTATION=YES ..
+ cmake --version
+ cmake --build . --target distcheck
+ - name: Create Release
+ if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
+ id: create_release
+ uses: softprops/action-gh-release at v1
+ with:
+ body_path: ${{ steps.notes.outputs.geosnotes }}
+ name: Release ${{ steps.version.outputs.geosversion }}
+ prerelease: false
+ files: |
+ ./_build/geos*.tar.bz2
\ No newline at end of file
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index f50664088..e413bceab 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,45 +1,60 @@
1. Verify that the versions currently set in Version.txt
- make sense for this release.
+ make sense for this release. See file for instructions.
- GEOS_VERSION_PATCH
- GEOS_VERSION_MINOR
- GEOS_VERSION_MAJOR
+ - GEOS_PATCH_WORD
- CAPI_INTERFACE_CURRENT
- CAPI_INTERFACE_REVISION
- CAPI_INTERFACE_AGE
-2. Run 'make distcheck', fix any problem with it.
+2. Prepare the build directory.
-3. Update the NEWS file (extract most important things from the
- repository log). Make sure to update the release date.
+ $ mkdir _build && cd _build && cmake -DBUILD_DOCUMENTATION=YES ..
-4. Commit the changes in the NEWS file.
+3. Run the build, distcheck, docs targets, fix any problems with them.
-5. Run 'make dist-bzip2'.
+ $ cmake --build .
+ $ cmake --build . --target docs
+ $ ctest --output-on-failure .
+ $ cmake --build . --target distcheck
- $ ./autogen.sh && ./configure && make dist-bzip2
+4. Update the NEWS file (extract most important things from the repository log).
+ Make sure to update the release date.
-6. Verify that you can un-pack and build the tarball.
+5. Commit the changes in the NEWS file.
+ Push changes with: git push origin,
+ and confirm all bots are green before moving forward
- - autotools: ./configure && make check
- - cmake: mkdir build && cd build && cmake .. && make && make check
-7. Copy the tarball to upload.osgeo.org:/osgeo/download/geos
-8. Tag the release:
+6. Tag the release:
$ git tag MAJOR.MINOR.PATCH
$ git push origin MAJOR.MINOR.PATCH
-9. Increment all the version numbers for the next release (described in 1 above).
+7. At this point the github/release.yml action should run,
+ wait for it to finish and then verify you can build with it.
-10. Update wiki page https://trac.osgeo.org/geos/ at Download section
+ $ VERSION=MAJOR.MINOR.PATCH
+ $ wget https://github.com/libgeos/geos/releases/download/$VERSION/geos-$VERSION.tar.bz2
+ $ tar xvfz geos-$VERSION.tar.bz2
+ $ cd geos-$VERSION
+ $ mkdir _build && cd _build && cmake ..
+ $ cmake --build .
+8. Copy the tar.bz2 tarball to upload.osgeo.org:/osgeo/download/geos
+9. Create and push a release branch if this was a PATCH=0 release,
+ update the versions for next release in Version.txt (both in
+ main and release branch).
+10. Update download page in main branch: web/content/usage/download.md
- Add latest release
- Remove previous patch level release (if any)
-11. Close current trac milestone and add new one for next release
-12. Announce on geos-devel
+11. Close current GitHub milestone and add a new one for next release.
+12. Announce on geos-devel
diff --git a/NEWS b/NEWS
index 893baf8f2..6e1cb80f7 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
Changes in 3.9.5
-2023-XX-XX
+2023-11-xx
- Bug fixes / improvements:
- GEOSUnaryUnion: Fix crash on collection containing empty point (GH-830, Dan Baston)
diff --git a/Version.txt b/Version.txt
index 2648e6074..9b3cbb0a3 100644
--- a/Version.txt
+++ b/Version.txt
@@ -2,7 +2,7 @@
# GEOS Versions
GEOS_VERSION_MAJOR=3
GEOS_VERSION_MINOR=9
-GEOS_VERSION_PATCH=4
+GEOS_VERSION_PATCH=5
# OPTIONS: "", "dev", "rc1" etc.
GEOS_PATCH_WORD=
@@ -16,7 +16,7 @@ GEOS_PATCH_WORD=
# ( THIS MUST BE CAREFULLY AVOIDED )
CAPI_INTERFACE_CURRENT=15
-CAPI_INTERFACE_REVISION=4
+CAPI_INTERFACE_REVISION=5
CAPI_INTERFACE_AGE=14
# JTS Port
diff --git a/tools/ci/releasenotes.pl b/tools/ci/releasenotes.pl
index 000000000..4c22f3847
--- /dev/null
+++ b/tools/ci/releasenotes.pl
@@ -0,0 +1,11 @@
+my $first = 0;
+while(<>) {
+ if (/^##/ && !$first) {
+ $first = 1;
+ next;
+ if (/^##/ && $first) {
+ exit;
+ print;
Summary of changes:
.github/workflows/release.yml | 77 +++++++++++++++++++++++++++++++++++++++++++
HOWTO_RELEASE | 53 ++++++++++++++++++-----------
NEWS | 2 +-
Version.txt | 4 +--
tools/ci/releasenotes.pl | 11 +++++++
5 files changed, 125 insertions(+), 22 deletions(-)
create mode 100644 .github/workflows/release.yml
create mode 100644 tools/ci/releasenotes.pl
hooks/post-receive
More information about the geos-commits
