[geos-commits] [SCM] GEOS branch 3.10 updated. 9527bc226211379cc53f57823a87472764965bd9
Sat Nov 11 18:54:11 PST 2023
the project "GEOS".
The branch, 3.10 has been updated
       via  9527bc226211379cc53f57823a87472764965bd9 (commit)
       via  7cb33c988bb0115f4fe107785570ae5786ed2401 (commit)
      from  9b5e544da70a58becd7bca4251e6b43942124da2 (commit)
revisions in full, below.
commit 9527bc226211379cc53f57823a87472764965bd9
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Nov 11 21:53:53 2023 -0500
    Push to 3.10.7dev release cycle
diff --git a/NEWS b/NEWS
index 22fe0f2ab..3042a8703 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,9 @@
+## Changes in 3.10.7
+20xx-xx-xx
+- Fixes/Improvements:
 ## Changes in 3.10.6
 2023-11-11
diff --git a/Version.txt b/Version.txt
index 4fb995175..1d4018441 100644
--- a/Version.txt
+++ b/Version.txt
@@ -2,10 +2,10 @@
 # GEOS Versions
 GEOS_VERSION_MAJOR=3
 GEOS_VERSION_MINOR=10
-GEOS_VERSION_PATCH=6
+GEOS_VERSION_PATCH=7
 # OPTIONS: "", "dev", "rc1" etc.
-GEOS_PATCH_WORD=
+GEOS_PATCH_WORD=dev
 # GEOS CAPI Versions
@@ -16,7 +16,7 @@ GEOS_PATCH_WORD=
 #   ( THIS MUST BE CAREFULLY AVOIDED )
 CAPI_INTERFACE_CURRENT=17
-CAPI_INTERFACE_REVISION=6
+CAPI_INTERFACE_REVISION=7
 CAPI_INTERFACE_AGE=16
 # JTS Port
commit 7cb33c988bb0115f4fe107785570ae5786ed2401
Date:   Sat Nov 11 21:28:13 2023 -0500
    Update to use GHA CI for releasing
    Prep for 3.10.6 release
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
new file mode 100644
index 000000000..21c6571d8
--- /dev/null
+++ b/.github/workflows/release.yml
@@ -0,0 +1,77 @@
+# GitHub Actions for GEOS Web Pages
+# Paul Ramsey <pramsey at cleverelephant.ca>, Regina Obe <lr at pcorp.us>
+# Only run on tag
+# Only release if distcheck succeeds
+# Only release of the tag name is identical to the full version
+# Use the first block of NEWS entries as release notes
+name: 'Release'
+on:
+  push:
+    tags:
+jobs:
+  release:
+    name: 'Release on Tag'
+    runs-on: ubuntu-latest
+    # Only run docbuild on central repo
+    if: github.repository == 'libgeos/geos'
+    steps:
+    - name: 'Install'
+      run: |
+        pwd
+        uname -a
+        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
+    - name: 'Check Out'
+      uses: actions/checkout at v3
+    - name: Get tag
+      id: tag
+      uses: dawidd6/action-get-tag at v1
+    - name: 'Read Version'
+      id: version
+      run: |
+        pwd
+        source Version.txt
+        GEOS_FULL_VERSION=${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}${GEOS_PATCH_WORD}
+        echo GEOS_FULL_VERSION $GEOS_FULL_VERSION
+        echo "::set-output name=geosversion::${GEOS_FULL_VERSION}"
+    - name: 'Create Release Notes'
+      id: notes
+      run: |
+        pwd
+        perl tools/ci/releasenotes.pl NEWS > release.md
+        echo "::set-output name=geosnotes::./release.md"
+    - name: 'Bundle & Check Package'
+      id: bundle
+      run: |
+        pwd
+        set -e
+        mkdir _build && cd _build
+        cmake -DBUILD_DOCUMENTATION=YES ..
+        cmake --version
+        cmake --build . --target distcheck
+    - name: Create Release
+      if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
+      id: create_release
+      uses: softprops/action-gh-release at v1
+      with:
+        body_path: ${{ steps.notes.outputs.geosnotes }}
+        name: Release ${{ steps.version.outputs.geosversion }}
+        prerelease: false
+        files: |
+          ./_build/geos*.tar.bz2
\ No newline at end of file
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 9c7e83a07..e413bceab 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -4,6 +4,7 @@
     - GEOS_VERSION_PATCH
     - GEOS_VERSION_MINOR
     - GEOS_VERSION_MAJOR
+    - GEOS_PATCH_WORD
     - CAPI_INTERFACE_CURRENT
     - CAPI_INTERFACE_REVISION
@@ -20,46 +21,40 @@
    $ ctest --output-on-failure .
    $ cmake --build . --target distcheck
-4. Update the NEWS file (extract most important things from the
-   repository log). Make sure to update the release date.
+4. Update the NEWS file (extract most important things from the repository log).
+   Make sure to update the release date.
 5. Commit the changes in the NEWS file.
+   Push changes with:  git push origin,
+   and confirm all bots are green before moving forward
-6. Build the distribution package.
-   $ BRANCH_NAME=3.10
-   $ git clone --depth 1 --branch $BRANCH_NAME \
-         https://github.com/libgeos/geos.git geos-$BRANCH_NAME
-   $ cd geos-$BRANCH_NAME
-   $ mkdir _build && cd _build
-   $ cmake ..
-   $ cmake --build . --target dist
-7. Verify that you can un-pack and build the tarball.
-   $ tar xvfz geos-VERSION.tar.bz2
-   $ cd geos-VERSION
-   $ mkdir _build && cd _build && cmake ..
-   $ cmake --build .
-   $ ctest --output-on-failure .
-8. Copy the tarball to upload.osgeo.org:/osgeo/download/geos
-9. Tag the release:
+6. Tag the release:
    $ git tag MAJOR.MINOR.PATCH
    $ git push origin MAJOR.MINOR.PATCH
-10. Create and push a release branch if this was a PATCH=0 release,
-    update the versions for next release in Version.txt (both in
-    main and release branch if this was a PATCH=0 release).
+7. At this point the github/release.yml action should run,
+   wait for it to finish and then verify you can build with it.
-11. Update web page Download section
+   $ VERSION=MAJOR.MINOR.PATCH
+   $ wget https://github.com/libgeos/geos/releases/download/$VERSION/geos-$VERSION.tar.bz2
+   $ tar xvfz geos-$VERSION.tar.bz2
+   $ cd geos-$VERSION
+   $ mkdir _build && cd _build && cmake ..
+   $ cmake --build .
+   $ ctest --output-on-failure .
+8. Copy the tar.bz2 tarball to upload.osgeo.org:/osgeo/download/geos
+9. Create and push a release branch if this was a PATCH=0 release,
+    update the versions for next release in Version.txt (both in
+    main and release branch).
+10. Update download page in main branch: web/content/usage/download.md
     - Add latest release
     - Remove previous patch level release (if any)
-12. Close current github milestone and add new one for next release
-12. Announce on geos-devel
+11. Close current GitHub milestone and add a new one for next release.
+12. Announce on geos-devel
index 82b9dd0fe..22fe0f2ab 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-Changes in 3.10.6
-2023-xx-xx
+## Changes in 3.10.6
+2023-11-11
   - LargestEmptyCircle: enhance boundary to allow any polygonal geometry (GH-859, Martin Davis)
@@ -9,8 +9,9 @@ Changes in 3.10.6
   - Remove undefined behaviour in use of null PrecisionModel (GH-931, Jeff Walton)
   - PreparedLineStringIntersects: Fix incorrect result with mixed-dim collection with points (GH-774, Dan Baston)
   - Skip over testing empty distances for mixed collections (GH-979, Paul Ramsey)
+  - Do not hide illegal argument exception in HeuristicOverlay (GH-925, Sandro Santilli)
-Changes in 3.10.5
+## Changes in 3.10.5
 2023-03-16
index 8c70ce72e..4fb995175 100644
--- a/Version.txt
+++ b/Version.txt
@@ -5,7 +5,7 @@ GEOS_VERSION_MINOR=10
-GEOS_PATCH_WORD=dev
+GEOS_PATCH_WORD=
@@ -16,7 +16,7 @@ GEOS_PATCH_WORD=dev
-CAPI_INTERFACE_REVISION=3
+CAPI_INTERFACE_REVISION=6
 # JTS Port
diff --git a/tools/ci/releasenotes.pl b/tools/ci/releasenotes.pl
index 000000000..4c22f3847
--- /dev/null
+++ b/tools/ci/releasenotes.pl
@@ -0,0 +1,11 @@
+my $first = 0;
+while(<>) {
+	if (/^##/ && !$first) {
+		$first = 1;
+		next;
+	if (/^##/ && $first) {
+		exit;
+	print;
Summary of changes:
 .github/workflows/release.yml | 77 +++++++++++++++++++++++++++++++++++++++++++
 HOWTO_RELEASE                 | 45 +++++++++++--------------
 NEWS                          | 13 ++++++--
 Version.txt                   |  4 +--
 tools/ci/releasenotes.pl      | 11 +++++++
 5 files changed, 120 insertions(+), 30 deletions(-)
 create mode 100644 .github/workflows/release.yml
 create mode 100644 tools/ci/releasenotes.pl
hooks/post-receive
More information about the geos-commits mailing list
