[geos-commits] [SCM] GEOS branch 3.12 updated. 5fa6a8825a419691a5f467a20fd44ef8c2f0f3f3
git at osgeo.org
git at osgeo.org
Fri Nov 17 11:57:29 PST 2023
the project "GEOS".
The branch, 3.12 has been updated
via 5fa6a8825a419691a5f467a20fd44ef8c2f0f3f3 (commit)
via 43e40629eba0023232d19327446090faf2b5f0d6 (commit)
from 60e3e2d820f746dd2173c40f780fb2deacf797cc (commit)
revisions in full, below.
commit 5fa6a8825a419691a5f467a20fd44ef8c2f0f3f3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 17 11:57:07 2023 -0800
News entry for GH-995
diff --git a/NEWS.md b/NEWS.md
index a22aff3d7..383e82c53 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -3,6 +3,7 @@ xxxx-xx-xx
- Fixes:
- Fix build on Illumus (GH-971)
+ - Buffer mitre join error (GH-995, Paul Ramsey)
## Changes in 3.12.1
2023-11-11
commit 43e40629eba0023232d19327446090faf2b5f0d6
Date: Fri Nov 17 10:23:45 2023 -0800
Port JTS-819, Add IntersectionLineSegment function,
Closes GH-995, Buffer with mitre join produces error: orientationIndex encountered NaN/Inf numbers
diff --git a/include/geos/algorithm/Intersection.h b/include/geos/algorithm/Intersection.h
index c4a38fb4f..de413d4a1 100644
--- a/include/geos/algorithm/Intersection.h
+++ b/include/geos/algorithm/Intersection.h
@@ -19,19 +19,28 @@
#include <geos/geom/CoordinateSequence.h>
namespace geos {
-namespace algorithm { // geos::algorithm
+namespace algorithm {
+/** \brief
+ * Functions to compute intersection points between lines and line segments.
+ * In general it is not possible to compute
+ * the intersection point of two lines exactly, due to numerical roundoff.
+ * This is particularly true when the lines are nearly parallel.
+ * These routines uses numerical conditioning on the input values
+ * to ensure that the computed value is very close to the correct value.
+ * The Z-ordinate is ignored, and not populated.
+class GEOS_DLL Intersection {
+public:
/** \brief
* Computes the intersection point of two lines.
* If the lines are parallel or collinear this case is detected
* and <code>null</code> is returned.
- * <p>
- * In general it is not possible to accurately compute
- * the intersection point of two lines, due to
- * numerical roundoff.
- * This is particularly true when the input lines are nearly parallel.
- * This routine uses numerical conditioning on the input values
- * to ensure that the computed value should be very close to the correct value.
* @param p1 an endpoint of line 1
* @param p2 an endpoint of line 1
@@ -42,13 +51,31 @@ namespace algorithm { // geos::algorithm
* @see CGAlgorithmsDD#intersection(Coordinate, Coordinate, Coordinate, Coordinate)
-class GEOS_DLL Intersection {
-public:
static geom::CoordinateXY intersection(const geom::CoordinateXY& p1, const geom::CoordinateXY& p2,
const geom::CoordinateXY& q1, const geom::CoordinateXY& q2);
+* Computes the intersection point of a line and a line segment (if any).
+* There will be no intersection point if:
+* * the segment does not intersect the line
+* * the line or the segment are degenerate (have zero length)
+* If the segment is collinear with the line the first segment endpoint is returned.
+* @param line1 a point on the line
+* @param line2 a point on the line
+* @param seg1 an endpoint of the line segment
+* @param seg2 an endpoint of the line segment
+* @return the intersection point, or null if it is not possible to find an intersection
+static geom::CoordinateXY intersectionLineSegment(
+ const geom::CoordinateXY& line1,
+ const geom::CoordinateXY& line2,
+ const geom::CoordinateXY& seg1,
+ const geom::CoordinateXY& seg2);
diff --git a/src/algorithm/Intersection.cpp b/src/algorithm/Intersection.cpp
index 6a69596de..e0430f500 100644
--- a/src/algorithm/Intersection.cpp
+++ b/src/algorithm/Intersection.cpp
@@ -15,7 +15,10 @@
#include <cmath>
#include <vector>
+#include <geos/algorithm/CGAlgorithmsDD.h>
+#include <geos/algorithm/Distance.h>
#include <geos/algorithm/Intersection.h>
+#include <geos/algorithm/Orientation.h>
namespace geos {
namespace algorithm { // geos.algorithm
@@ -82,6 +85,65 @@ Intersection::intersection(const geom::CoordinateXY& p1, const geom::CoordinateX
+/* public static */
+geom::CoordinateXY
+Intersection::intersectionLineSegment(
+ int orientS1 = Orientation::index(line1, line2, seg1);
+ if (orientS1 == 0)
+ return seg1;
+ int orientS2 = Orientation::index(line1, line2, seg2);
+ if (orientS2 == 0)
+ return seg2;
+ * If segment lies completely on one side of the line, it does not intersect
+ if ((orientS1 > 0 && orientS2 > 0) || (orientS1 < 0 && orientS2 < 0)) {
+ return geom::CoordinateXY::getNull();
+ * The segment intersects the line.
+ * The full line-line intersection is used to compute the intersection point.
+ geom::CoordinateXY intPt = intersection(line1, line2, seg1, seg2);
+ if (!intPt.isNull())
+ return intPt;
+ * Due to robustness failure it is possible the intersection computation will return null.
+ * In this case choose the closest point
+ double dist1 = Distance::pointToLinePerpendicular(seg1, line1, line2);
+ double dist2 = Distance::pointToLinePerpendicular(seg2, line1, line2);
+ if (dist1 < dist2)
+ return seg1;
+ else
+ return seg2;
} // namespace geos.algorithm
} // namespace geos
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 32ab310f0..ae3c6b8b9 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -35,10 +35,6 @@
#include <geos/util.h>
-#ifndef GEOS_DEBUG
-#define GEOS_DEBUG 0
-#endif
using namespace geos::algorithm;
using namespace geos::geom;
@@ -536,15 +532,9 @@ OffsetSegmentGenerator::addLimitedMitreJoin(
// compute the candidate bevel segment by projecting both sides of the midpoint
Coordinate bevel0 = project(bevelMidPt, p_distance, dirBevel);
Coordinate bevel1 = project(bevelMidPt, p_distance, dirBevel + MATH_PI);
- LineSegment bevel(bevel0, bevel1);
- //-- compute intersections with extended offset segments
- double extendLen = p_mitreLimitDistance < p_distance ? p_distance : p_mitreLimitDistance;
- LineSegment extend0 = extend(p_offset0, 2 * extendLen);
- LineSegment extend1 = extend(p_offset1, -2 * extendLen);
- Coordinate bevelInt0 = bevel.intersection(extend0);
- Coordinate bevelInt1 = bevel.intersection(extend1);
+ Coordinate bevelInt0(Intersection::intersectionLineSegment(p_offset0.p0, p_offset0.p1, bevel0, bevel1));
+ Coordinate bevelInt1(Intersection::intersectionLineSegment(p_offset1.p0, p_offset1.p1, bevel0, bevel1));
//-- add the limited bevel, if it intersects the offsets
if (!bevelInt0.isNull() && !bevelInt1.isNull()) {
@@ -561,21 +551,6 @@ OffsetSegmentGenerator::addLimitedMitreJoin(
-/* private static */
-LineSegment
-OffsetSegmentGenerator::extend(const LineSegment& seg, double dist)
- double distFrac = std::abs(dist) / seg.getLength();
- double segFrac = dist >= 0 ? 1 + distFrac : 0 - distFrac;
- Coordinate extendPt;
- seg.pointAlong(segFrac, extendPt);
- if (dist > 0)
- return LineSegment(seg.p0, extendPt);
- else
- return LineSegment(extendPt, seg.p1);
Coordinate
OffsetSegmentGenerator::project(const Coordinate& pt, double d, double dir)
diff --git a/tests/unit/algorithm/IntersectionTest.cpp b/tests/unit/algorithm/IntersectionTest.cpp
index 75adfce94..b2b6576e2 100644
--- a/tests/unit/algorithm/IntersectionTest.cpp
+++ b/tests/unit/algorithm/IntersectionTest.cpp
@@ -43,8 +43,10 @@ struct test_intersection_data {
double MAX_ABS_ERROR = 1e-5;
- void checkIntersectionNull(double p1x, double p1y, double p2x, double p2y,
- double q1x, double q1y, double q2x, double q2y) {
+ void checkIntersectionNull(
+ double p1x, double p1y, double p2x, double p2y,
+ double q1x, double q1y, double q2x, double q2y)
Coordinate p1(p1x, p1y);
Coordinate p2(p2x, p2y);
Coordinate q1(q1x, q1y);
@@ -53,9 +55,11 @@ struct test_intersection_data {
ensure("checkIntersectionNull", actual.isNull());
- void checkIntersection(double p1x, double p1y, double p2x, double p2y,
- double q1x, double q1y, double q2x, double q2y,
- double expectedx, double expectedy) {
+ void checkIntersection(
+ double q1x, double q1y, double q2x, double q2y,
+ double expectedx, double expectedy)
@@ -67,6 +71,33 @@ struct test_intersection_data {
ensure("checkIntersection", dist <= MAX_ABS_ERROR);
+ void checkIntersectionLineSegment(
+ Coordinate p1(p1x, p1y);
+ Coordinate p2(p2x, p2y);
+ Coordinate q1(q1x, q1y);
+ Coordinate q2(q2x, q2y);
+ Coordinate actual(Intersection::intersectionLineSegment(p1, p2, q1, q2));
+ Coordinate expected(expectedx, expectedy);
+ double dist = actual.distance(expected);
+ ensure("checkIntersectionLineSegment", dist <= MAX_ABS_ERROR);
+ void checkIntersectionLineSegmentNull(
+ ensure("checkIntersectionLineSegmentNull", actual.isNull());
test_intersection_data()
@@ -77,41 +108,90 @@ typedef group::object object;
group test_intersection_data("geos::algorithm::Intersection");
+// testSimple
template<>
template<>
-void object::test<1>
+void object::test<1>()
- // testSimple
- checkIntersection(
- 0,0, 10,10,
- 0,10, 10,0,
- 5,5);
+ checkIntersection(0,0, 10,10, 0,10, 10,0, 5,5);
- // testCollinear
- checkIntersectionNull(
- 0,0, 10,10,
- 20,20, 30, 30 );
+// testCollinear
+template<>
+template<>
+void object::test<2>()
+ checkIntersectionNull(0,0, 10,10, 20,20, 30, 30 );
- // testParallel
+// testParallel
+template<>
+template<>
+void object::test<3>()
0,0, 10,10,
10,0, 20,10 );
- // testAlmostCollinear
+// testAlmostCollinear
+template<>
+template<>
+void object::test<4>()
checkIntersection(
35613471.6165017, 4257145.306132293, 35613477.7705378, 4257160.528222711,
35613477.77505724, 4257160.539653536, 35613479.85607389, 4257165.92369170,
35613477.772841461, 4257160.5339209242 );
- // testAlmostCollinearCond
+// testAlmostCollinearCond
+template<>
+template<>
+void object::test<5>()
checkIntersection(
1.6165017, 45.306132293, 7.7705378, 60.528222711,
7.77505724, 60.539653536, 9.85607389, 65.92369170,
7.772841461, 60.5339209242 );
+// testLineSegCross
+template<>
+template<>
+void object::test<6>()
+ checkIntersectionLineSegment( 0, 0, 0, 1, -1, 9, 1, 9, 0, 9 );
+ checkIntersectionLineSegment( 0, 0, 0, 1, -1, 2, 1, 4, 0, 3 );
+// testLineSegTouch
+template<>
+template<>
+void object::test<7>()
+ checkIntersectionLineSegment( 0, 0, 0, 1, -1, 9, 0, 9, 0, 9 );
+ checkIntersectionLineSegment( 0, 0, 0, 1, 0, 2, 1, 4, 0, 2 );
+// testLineSegCollinear
+template<>
+template<>
+void object::test<8>()
+ checkIntersectionLineSegment( 0, 0, 0, 1, 0, 9, 0, 8, 0, 9 );
+// testLineSegNone
+template<>
+template<>
+void object::test<9>()
+ checkIntersectionLineSegmentNull( 0, 0, 0, 1, 2, 9, 1, 9 );
+ checkIntersectionLineSegmentNull( 0, 0, 0, 1, -2, 9, -1, 9 );
} // namespace tut
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index 0c7cab962..3ed11b933 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -615,4 +615,19 @@ void object::test<24>
ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<25>
+ geom1_ = GEOSGeomFromWKT("POLYGON ((4.6664239253667485 4.9470840685113275, 4.666423925366749 4.947084068511328, 3.569508914897422 -10.739531408188364, -9.082056557097435 19.893317266250286, 5.639581102785941 18.86388007810711, 4.6664239253667485 4.9470840685113275))");
+ geom2_ = GEOSBufferWithStyle(geom1_, -1, 8,
+ GEOSBUF_CAP_ROUND,
+ GEOSBUF_JOIN_MITRE,
+ 5);
+ geom3_ = GEOSGeomFromWKT("POLYGON ((3.3225774291798533 0.0647708524944821, 3.3225774291798555 0.0647708524944812, 2.8688758567150883 -6.4234639154696263, -7.5416226086581215 18.7831577331451953, 4.5722605787819921 17.9360725015914078, 3.3225774291798533 0.0647708524944821))");
+ ensure_geometry_equals_exact(geom3_, geom2_, 0.001);
} // namespace tut
Summary of changes:
NEWS.md | 1 +
include/geos/algorithm/Intersection.h | 51 +++++++---
src/algorithm/Intersection.cpp | 62 ++++++++++++
src/operation/buffer/OffsetSegmentGenerator.cpp | 29 +-----
tests/unit/algorithm/IntersectionTest.cpp | 120 ++++++++++++++++++++----
tests/unit/capi/GEOSBufferTest.cpp | 15 +++
6 files changed, 219 insertions(+), 59 deletions(-)
hooks/post-receive
More information about the geos-commits
