[geos-commits] [SCM] GEOS branch main updated. 54ed380c031c9bec3b2eac02119c518e7eeb643e
Tue Nov 21 05:36:33 PST 2023
the project "GEOS".
The branch, main has been updated
       via  54ed380c031c9bec3b2eac02119c518e7eeb643e (commit)
      from  4767afd144f86a7a2be0f796639eac34ea5760eb (commit)
revisions in full, below.
commit 54ed380c031c9bec3b2eac02119c518e7eeb643e
Author: Dan Baston <dbaston at gmail.com>
Date:   Tue Nov 21 08:36:00 2023 -0500
    CoordinateSequence: Fix logic error when adding XYM seq to XYZ seq (#999)
    Logic error only causes an incorrect result when GEOS_COORDSEQ_PADZ is
    not defined.
    Fixes https://github.com/libgeos/geos/issues/997
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index fc36b4bb3..0ba723fb1 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -151,7 +151,7 @@ CoordinateSequence::initialize()
 void
 CoordinateSequence::add(const CoordinateSequence& cs, std::size_t from, std::size_t to)
-    if (cs.stride() == stride() && cs.hasM() == cs.hasM()) {
+    if (cs.stride() == stride() && cs.hasM() == hasM()) {
         m_vect.insert(m_vect.end(),
                       std::next(cs.m_vect.cbegin(), static_cast<std::ptrdiff_t>(from * stride())),
                       std::next(cs.m_vect.cbegin(), static_cast<std::ptrdiff_t>((to + 1u)*stride())));
diff --git a/tests/unit/geom/CoordinateSequenceTest.cpp b/tests/unit/geom/CoordinateSequenceTest.cpp
index 1d9c08782..579bba868 100644
--- a/tests/unit/geom/CoordinateSequenceTest.cpp
+++ b/tests/unit/geom/CoordinateSequenceTest.cpp
@@ -1344,7 +1344,7 @@ void object::test<49>
     ensure_same(c1.z, 2);
-// Test move contructor
+// Test move constructor
 template<>
 template<>
 void object::test<50>
@@ -1510,4 +1510,30 @@ void object::test<55>
     ensure_equals(seq1, expected);
+// add XYM seq to XYZ seq
+template<>
+template<>
+void object::test<56>
+    CoordinateSequence seq1 = CoordinateSequence::XYZ(0);
+    CoordinateSequence seq2 = CoordinateSequence::XYM(0);
+    seq1.add(Coordinate(1, 2, 3));
+    seq1.add(Coordinate(4, 5, 6));
+    seq2.add(CoordinateXYM(7, 8, 9));
+    seq2.add(CoordinateXYM(10, 11, 12));
+    seq1.add(seq2);
+    ensure(seq1.hasZ());
+    ensure(!seq1.hasM());
+    ensure_equals_xyz(seq1.getAt(0), Coordinate{1, 2, 3});
+    ensure_equals_xyz(seq1.getAt(1), Coordinate{4, 5, 6});
+    ensure_equals_xyz(seq1.getAt(2), Coordinate{7, 8, DoubleNotANumber});
+    ensure_equals_xyz(seq1.getAt(3), Coordinate{10, 11, DoubleNotANumber});
 } // namespace tut
Summary of changes:
 src/geom/CoordinateSequence.cpp            |  2 +-
 tests/unit/geom/CoordinateSequenceTest.cpp | 28 +++++++++++++++++++++++++++-
 2 files changed, 28 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
