[geos-commits] [SCM] GEOS branch main updated. 4286a70ea3321b41930633b1de364f40dfbeefcb
    git at osgeo.org
    git at osgeo.org
    Wed Nov 22 07:45:09 PST 2023
the project "GEOS".
The branch, main has been updated
       via  4286a70ea3321b41930633b1de364f40dfbeefcb (commit)
      from  301bc462db3b8fd3d28137ccbfb8d0ee85d0c479 (commit)
revisions in full, below.
commit 4286a70ea3321b41930633b1de364f40dfbeefcb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Nov 22 07:44:32 2023 -0800
    Fix DiscreteHausdorffDistance for LinearRing (#1000)
diff --git a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
index 5dc1dd0a6..be136edee 100644
--- a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
+++ b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
@@ -36,19 +36,11 @@
 #endif
 namespace geos {
-namespace algorithm {
-//class RayCrossingCounter;
 namespace geom {
 class Geometry;
 class Coordinate;
 //class CoordinateSequence;
-namespace index {
-namespace intervalrtree {
-//class SortedPackedIntervalRTree;
 namespace geos {
diff --git a/src/algorithm/distance/DistanceToPoint.cpp b/src/algorithm/distance/DistanceToPoint.cpp
index 1891b63f8..b98343229 100644
--- a/src/algorithm/distance/DistanceToPoint.cpp
+++ b/src/algorithm/distance/DistanceToPoint.cpp
@@ -45,7 +45,7 @@ DistanceToPoint::computeDistance(const geom::Geometry& geom,
         return;
-    if(geom.getGeometryTypeId() == GEOS_LINESTRING) {
+    if(geom.getGeometryTypeId() == GEOS_LINESTRING || geom.getGeometryTypeId() == GEOS_LINEARRING) {
         const LineString* ls = static_cast<const LineString*>(&geom);
         computeDistance(*ls, pt, ptDist);
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index 5f21fe420..735344cd5 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -216,5 +216,16 @@ void object::test<7>
                   DiscreteHausdorffDistance::distance(*g2, *g3));
+// see https://github.com/libgeos/geos/issues/987
+template<>
+template<>
+void object::test<8>
+    runTest("LINEARRING (0 0, 0 10, 10 10, 10 0, 0 0)",
+            "LINEARRING (1 1, 1 9, 8 8, 9 1, 1 1)",
+            2.8284271247461903);
 } // namespace tut
Summary of changes:
 include/geos/algorithm/distance/DiscreteHausdorffDistance.h   |  8 --------
 src/algorithm/distance/DistanceToPoint.cpp                    |  2 +-
 .../unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp | 11 +++++++++++
 3 files changed, 12 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
