[geos-commits] [SCM] GEOS branch 3.11 updated. 6229457c945ed5c3fa8e51f58c859b3d014cb7d1
git at osgeo.org
git at osgeo.org
Wed Nov 22 07:50:10 PST 2023
the project "GEOS".
The branch, 3.11 has been updated
via 6229457c945ed5c3fa8e51f58c859b3d014cb7d1 (commit)
from 6145340de03e26e6a1bbd0f1f2e676b56ad1b7c9 (commit)
revisions in full, below.
commit 6229457c945ed5c3fa8e51f58c859b3d014cb7d1
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Nov 22 07:44:32 2023 -0800
Fix DiscreteHausdorffDistance for LinearRing (#1000)
diff --git a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
index b8da5eeaa..651d86a94 100644
--- a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
+++ b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
@@ -36,19 +36,11 @@
#endif
namespace geos {
-namespace algorithm {
-//class RayCrossingCounter;
namespace geom {
class Geometry;
class Coordinate;
//class CoordinateSequence;
-namespace index {
-namespace intervalrtree {
-//class SortedPackedIntervalRTree;
namespace geos {
diff --git a/src/algorithm/distance/DistanceToPoint.cpp b/src/algorithm/distance/DistanceToPoint.cpp
index 36a1c059d..a96fe5cae 100644
--- a/src/algorithm/distance/DistanceToPoint.cpp
+++ b/src/algorithm/distance/DistanceToPoint.cpp
@@ -45,7 +45,7 @@ DistanceToPoint::computeDistance(const geom::Geometry& geom,
return;
- if(geom.getGeometryTypeId() == GEOS_LINESTRING) {
+ if(geom.getGeometryTypeId() == GEOS_LINESTRING || geom.getGeometryTypeId() == GEOS_LINEARRING) {
const LineString* ls = static_cast<const LineString*>(&geom);
computeDistance(*ls, pt, ptDist);
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index 46f4cb2da..3f7f72d36 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -198,5 +198,16 @@ void object::test<7>
DiscreteHausdorffDistance::distance(*g2, *g3));
+// see https://github.com/libgeos/geos/issues/987
+template<>
+template<>
+void object::test<8>
+ runTest("LINEARRING (0 0, 0 10, 10 10, 10 0, 0 0)",
+ "LINEARRING (1 1, 1 9, 8 8, 9 1, 1 1)",
+ 2.8284271247461903);
} // namespace tut
Summary of changes:
include/geos/algorithm/distance/DiscreteHausdorffDistance.h | 8 --------
src/algorithm/distance/DistanceToPoint.cpp | 2 +-
.../unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp | 11 +++++++++++
3 files changed, 12 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
