[geos-commits] [SCM] GEOS branch main updated. b3415ca77a8f177493bd36e7d47dc04f5a266096
Wed Nov 22 08:36:59 PST 2023
the project "GEOS".
The branch, main has been updated
       via  b3415ca77a8f177493bd36e7d47dc04f5a266096 (commit)
      from  dcd3919e185a6623f653e44fff3e6a68fe18137b (commit)
revisions in full, below.
commit b3415ca77a8f177493bd36e7d47dc04f5a266096
Author: Kunlin Yu <yukunlin at syriusrobotics.com>
Date:   Thu Nov 23 00:36:40 2023 +0800
    Support id for GeoJSONFeature (#994)
    * Support id for GeoJSONFeature
    1. Add id and getter for GeoJSONFeature
    2. Modify the copy constructor of GeoJSONFeature
    3. Check "id" in GeoJSONReader
    4. Check "id" in GeoJSONWriter
    5. Modify unit test for id
    * Support floating-point id
    Signed-off-by: Kunlin Yu <yukunlin at syriusrobotics.com>
diff --git a/include/geos/io/GeoJSON.h b/include/geos/io/GeoJSON.h
index 0fd045bdb..8281786bb 100644
--- a/include/geos/io/GeoJSON.h
+++ b/include/geos/io/GeoJSON.h
@@ -98,6 +98,13 @@ public:
     GeoJSONFeature(std::unique_ptr<geom::Geometry> g,
                    std::map<std::string, GeoJSONValue>&& p);
+    GeoJSONFeature(std::unique_ptr<geom::Geometry> g,
+                   const std::map<std::string, GeoJSONValue>& p,
+                   const std::string& id);
+                   std::map<std::string, GeoJSONValue>&& p, std::string id);
     GeoJSONFeature(GeoJSONFeature const& other);
     GeoJSONFeature(GeoJSONFeature&& other);
@@ -110,12 +117,16 @@ public:
     const std::map<std::string, GeoJSONValue>& getProperties() const;
+    const std::string& getId() const;
 private:
     std::unique_ptr<geom::Geometry> geometry;
     std::map<std::string, GeoJSONValue> properties;
+    std::string id;
 class GEOS_DLL GeoJSONFeatureCollection {
diff --git a/src/io/GeoJSON.cpp b/src/io/GeoJSON.cpp
index cfb28ea13..32e0f6c33 100644
--- a/src/io/GeoJSON.cpp
+++ b/src/io/GeoJSON.cpp
@@ -224,16 +224,26 @@ bool GeoJSONValue::isArray() const
 // GeoJSONFeature
 GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g,
-                               const std::map<std::string, GeoJSONValue>& p) : geometry(std::move(g)), properties(p) {}
+                               const std::map<std::string, GeoJSONValue>& p) : geometry(std::move(g)), properties(p), id("") {}
-                               std::map<std::string, GeoJSONValue>&& p) : geometry(std::move(g)), properties(std::move(p)) {}
+                               std::map<std::string, GeoJSONValue>&& p) : geometry(std::move(g)), properties(std::move(p)), id("") {}
+GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g,
+                               const std::string& i)
+    : geometry(std::move(g)), properties(p), id(i) {}
+                               std::string i)
+    : geometry(std::move(g)), properties(std::move(p)), id(std::move(i)) {}
 GeoJSONFeature::GeoJSONFeature(GeoJSONFeature const& other) : geometry(other.geometry->clone()),
-    properties(other.properties) {}
+    properties(other.properties), id(other.id) {}
 GeoJSONFeature::GeoJSONFeature(GeoJSONFeature&& other) : geometry(std::move(other.geometry)),
-    properties(std::move(other.properties)) {}
+    properties(std::move(other.properties)), id(std::move(other.id)) {}
 GeoJSONFeature& GeoJSONFeature::operator=(const GeoJSONFeature& other)
@@ -262,6 +272,8 @@ const std::map<std::string, GeoJSONValue>& GeoJSONFeature::getProperties() const
     return properties;
+const std::string& GeoJSONFeature::getId() const { return id; }
 // GeoJSONFeatureCollection
 GeoJSONFeatureCollection::GeoJSONFeatureCollection(const std::vector<GeoJSONFeature>& f) : features(f) {}
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 444905b0c..9daa5ac15 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -98,7 +98,14 @@ GeoJSONFeature GeoJSONReader::readFeature(const geos_nlohmann::json& j) const
     const auto& geometryJson = j.at("geometry");
     const auto& properties = j.at("properties");
-    return GeoJSONFeature{readGeometry(geometryJson), readProperties(properties)};
+    std::string id = "";
+    if (j.contains("id") && !j.at("id").is_null()) {
+        if (j.at("id").is_string()) id = j.at("id").get<std::string>();
+        if (j.at("id").is_number()) id = j.at("id").dump();
+    return GeoJSONFeature{readGeometry(geometryJson), readProperties(properties), id};
 std::map<std::string, GeoJSONValue> GeoJSONReader::readProperties(
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index 6e7b196b8..154b8266d 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -125,9 +125,13 @@ std::string GeoJSONWriter::write(const GeoJSONFeatureCollection& features)
 void GeoJSONWriter::encodeFeature(const GeoJSONFeature& feature, geos_nlohmann::ordered_json& j)
     j["type"] = "Feature";
+    if (feature.getId().size() > 0) j["id"] = feature.getId();
     json geometryJson;
     encodeGeometry(feature.getGeometry(), geometryJson);
     j["geometry"] = geometryJson;
     json propertiesJson = json::object();
     for (auto const& property : feature.getProperties()) {
         std::string key = property.first;
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index e1adcf8ca..bcbb9fead 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -270,13 +270,14 @@ template<>
 void object::test<19>
-    std::string geojson { "{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}, \"properties\": {\"id\": 1, \"name\": \"one\", \"items\": [1,2,3,4], \"nested\": {\"id\":2, \"name\":\"two\"}}}" };
+    std::string geojson { "{\"type\":\"Feature\",\"id\":\"id123\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]}, \"properties\": {\"id\": 1, \"name\": \"one\", \"items\": [1,2,3,4], \"nested\": {\"id\":2, \"name\":\"two\"}}}" };
     geos::io::GeoJSONFeatureCollection features(geojsonreader.readFeatures(geojson));
     ensure_equals(features.getFeatures().size(), static_cast<size_t>(1));
     ensure_equals(static_cast<size_t>(features.getFeatures()[0].getGeometry()->getCoordinateDimension()), 2u);
     ensure_equals(features.getFeatures()[0].getGeometry()->toText(), "POINT (-117 33)");
     ensure_equals(features.getFeatures()[0].getProperties().at("id").getNumber(), 1.0);
     ensure_equals(features.getFeatures()[0].getProperties().at("name").getString(), "one");
+    ensure_equals(features.getFeatures()[0].getId(), "id123");
     std::vector<geos::io::GeoJSONValue> values = features.getFeatures()[0].getProperties().at("items").getArray();
     ensure_equals(values.size(), static_cast<size_t>(4));
     ensure_equals(values[0].getNumber(), 1.0);
@@ -476,5 +477,33 @@ void object::test<30>
     ensure(errorMessage.find("ParseException: Error parsing JSON") != std::string::npos);
+// Read a GeoJSON FeatureCollection with multiple Features with id
+template<>
+template<>
+void object::test<31>
+    std::string geojson { "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\", \"id\":\"123\",    \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": 123,       \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": 123.0,     \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": 123.000,   \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": 123.9,     \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": null,      \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": {},        \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\", \"id\": [\"123\"], \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}},"
+        "{\"type\":\"Feature\",                    \"geometry\":{\"type\":\"Point\",\"coordinates\":[0.0,0.0]}, \"properties\":{}}]}" };
+    geos::io::GeoJSONFeatureCollection features(geojsonreader.readFeatures(geojson));
+    ensure_equals(features.getFeatures().size(), static_cast<size_t>(9));
+    ensure_equals(features.getFeatures()[0].getId(), "123");
+    ensure_equals(features.getFeatures()[1].getId(), "123");
+    ensure_equals(features.getFeatures()[2].getId(), "123.0");
+    ensure_equals(features.getFeatures()[3].getId(), "123.0");
+    ensure_equals(features.getFeatures()[4].getId(), "123.9");
+    ensure_equals(features.getFeatures()[5].getId(), "");
+    ensure_equals(features.getFeatures()[6].getId(), "");
+    ensure_equals(features.getFeatures()[7].getId(), "");
+    ensure_equals(features.getFeatures()[8].getId(), "");
diff --git a/tests/unit/io/GeoJSONWriterTest.cpp b/tests/unit/io/GeoJSONWriterTest.cpp
index 30862b168..26a2d8520 100644
--- a/tests/unit/io/GeoJSONWriterTest.cpp
+++ b/tests/unit/io/GeoJSONWriterTest.cpp
@@ -240,15 +240,15 @@ void object::test<14>
     geos::io::GeoJSONFeatureCollection features {{
         geos::io::GeoJSONFeature { wktreader.read("POINT(-117 33)"), std::map<std::string, geos::io::GeoJSONValue> {
             {"id",   geos::io::GeoJSONValue(1.0)     },
-            {"name", geos::io::GeoJSONValue(std::string{"One"}) },
+            {"name", geos::io::GeoJSONValue(std::string{"One"})}},
+             "id123"},
         geos::io::GeoJSONFeature { wktreader.read("POINT(-127 53)"), std::map<std::string, geos::io::GeoJSONValue> {
             {"id",   geos::io::GeoJSONValue(2.0)     },
             {"name", geos::io::GeoJSONValue(std::string{"Two"}) },
     std::string result = geojsonwriter.write(features);
-    ensure_equals(result, "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]},\"properties\":{\"id\":1.0,\"name\":\"One\"}},{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-127.0,53.0]},\"properties\":{\"id\":2.0,\"name\":\"Two\"}}]}");
+    ensure_equals(result, "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"id\":\"id123\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-117.0,33.0]},\"properties\":{\"id\":1.0,\"name\":\"One\"}},{\"type\":\"Feature\",\"geometry\":{\"type\":\"Point\",\"coordinates\":[-127.0,53.0]},\"properties\":{\"id\":2.0,\"name\":\"Two\"}}]}");
 // Write an empty point
Summary of changes:
 include/geos/io/GeoJSON.h           | 11 +++++++++++
 src/io/GeoJSON.cpp                  | 20 ++++++++++++++++----
 src/io/GeoJSONReader.cpp            |  9 ++++++++-
 src/io/GeoJSONWriter.cpp            |  4 ++++
 tests/unit/io/GeoJSONReaderTest.cpp | 31 ++++++++++++++++++++++++++++++-
 tests/unit/io/GeoJSONWriterTest.cpp |  6 +++---
 6 files changed, 72 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
