[geos-commits] [SCM] GEOS branch main updated. b3d6d20a94fdbe6a8401d176668a6d7d76465673
    git at osgeo.org
    git at osgeo.org
    Thu Nov 30 08:35:50 PST 2023
the project "GEOS".
The branch, main has been updated
       via  b3d6d20a94fdbe6a8401d176668a6d7d76465673 (commit)
      from  ddba88a37bd8edb0acc08c9753a1a0e28de3baee (commit)
revisions in full, below.
commit b3d6d20a94fdbe6a8401d176668a6d7d76465673
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Nov 30 08:35:16 2023 -0800
    Fix and test for LargestEmptyCircle crash on malformed input (#1004)
    * Fix and tests for GH-1003
    * Call to init() was missing? Does not explain why the bug in the original issue seemed tied to particular coordinates, as the fix will apply across all inputs. So be warned, there may still be something hiding in there.
diff --git a/src/algorithm/construct/IndexedDistanceToPoint.cpp b/src/algorithm/construct/IndexedDistanceToPoint.cpp
index 92c703ef8..e1fd58571 100644
--- a/src/algorithm/construct/IndexedDistanceToPoint.cpp
+++ b/src/algorithm/construct/IndexedDistanceToPoint.cpp
@@ -36,7 +36,7 @@ IndexedDistanceToPoint::IndexedDistanceToPoint(const Geometry& geom)
 void IndexedDistanceToPoint::init()
     if (facetDistance != nullptr)
-      return;
+        return;
     ptLocator.reset(new IndexedPointInPolygonsLocator(targetGeometry));
     facetDistance.reset(new IndexedFacetDistance(&targetGeometry));
@@ -62,7 +62,8 @@ bool IndexedDistanceToPoint::isInArea(const Point& pt)
 std::unique_ptr<geom::CoordinateSequence>
 IndexedDistanceToPoint::nearestPoints(const Point& pt)
+    init();
     return facetDistance->nearestPoints(&pt);
\ No newline at end of file
diff --git a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
index b0110fa0f..5a09e2ef8 100644
--- a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
+++ b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
@@ -316,4 +316,30 @@ void object::test<19>()
         0.01, 5.5, 4.5, 2.12 );
+// https://trac.osgeo.org/postgis/ticket/5626
+template<>
+template<>
+void object::test<20>()
+    checkCircle(
+        "POINT(-11 40)", // input
+        "POLYGON((-71.1 42.3,-71.1 42.4,-71.2 42.3,-71.1 42.3))", // boundary
+        0.1, // test tolerance
+        -71.15, 42.34, 60.19588 ); // expected x, y, radius
+template<>
+template<>
+void object::test<21>()
+    checkCircle(
+        "POINT(-11.1111111 40)", // input
+        "POLYGON((-71.0821 42.3036,-71.0821 42.3936,-71.0901 42.3036,-71.0821 42.3036))", // boundary
+        1, // test tolerance
 } // namespace tut
Summary of changes:
 src/algorithm/construct/IndexedDistanceToPoint.cpp |  5 +++--
 .../algorithm/construct/LargestEmptyCircleTest.cpp | 26 ++++++++++++++++++++++
 2 files changed, 29 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
