[geos-commits] [SCM] GEOS branch 3.12 updated. 5b60b76fc0dbab04ed2488f78c4239a8b82657b8
Thu Nov 30 08:54:50 PST 2023
the project "GEOS".
The branch, 3.12 has been updated
       via  5b60b76fc0dbab04ed2488f78c4239a8b82657b8 (commit)
      from  564e22f389f2a4cfb38ae7e7ea661146c3fc536c (commit)
revisions in full, below.
commit 5b60b76fc0dbab04ed2488f78c4239a8b82657b8
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Nov 30 08:54:32 2023 -0800
    Add geosop operation largestEmptyCircleBdy
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index 59c01b644..ccff0bc3f 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -372,13 +372,22 @@ std::vector<GeometryOpCreator> opRegistry {
 {"largestEmptyCircle", [](std::string name) { return GeometryOp::create(name,
     catConst,
-    "compute radius line of largest empty circle of geometry up to a distance tolerance",
+    "compute radius line of largest empty circle between obstacles up to a distance tolerance",
     [](const std::unique_ptr<Geometry>& geom, double d) {
         geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), d );
         std::unique_ptr<Geometry> res = lec.getRadiusLine();
         return new Result( std::move(res) );
+{"largestEmptyCircleBdy", [](std::string name) { return GeometryOp::create(name,
+    catConst,
+    "compute radius line of largest empty circle between obstacles with center in a boundary, up to a distance tolerance",
+    [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geom2, double d) {
+        geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), geom2.get(), d );
+        std::unique_ptr<Geometry> res = lec.getRadiusLine();
+        return new Result( std::move(res) );
 {"maxInscribedCircle", [](std::string name) { return GeometryOp::create(name,
     catConst,
     "compute maximum inscribed circle radius of Polygon up to a distance tolerance",
Summary of changes:
 util/geosop/GeometryOp.cpp | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
