[geos-commits] [SCM] GEOS branch main updated. f9cfee82c868ac8bdf69be2701694e7d75d7144d
Tue Sep 5 12:24:47 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  f9cfee82c868ac8bdf69be2701694e7d75d7144d (commit)
      from  15185e65b3e7bc671cf693c97cf103125fb4a171 (commit)
revisions in full, below.
commit f9cfee82c868ac8bdf69be2701694e7d75d7144d
Author: Mike Taves <mwtoews at gmail.com>
Date:   Wed Sep 6 07:24:14 2023 +1200
    Fix WKTWriter to emit EMPTY elements in multi-geometries (#952)
diff --git a/NEWS.md b/NEWS.md
index effecd7b6..53eebb24d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -11,6 +11,7 @@
   - ConvexHull: Performance improvement for larger geometries (JTS-985, Martin Davis)
   - Intersection: change to using DoubleDouble computation to improve robustness (GH-937, Martin Davis)
   - Fix LargestEmptyCircle to respect polygonal obstacles (GH-939, Martin Davis)
+  - Fix WKTWriter to emit EMPTY elements in multi-geometries (GH-952, Mike Taves)
 ## Changes in 3.12.0
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index def315a44..1471d669d 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -477,12 +477,13 @@ void
 WKTWriter::appendMultiPointText(const MultiPoint& multiPoint, OrdinateSet outputOrdinates,
                                 int /*level*/, Writer& writer) const
-    if(multiPoint.isEmpty()) {
+    const std::size_t n = multiPoint.getNumGeometries();
+    if(n == 0) {
         writer.write("EMPTY");
     else {
         writer.write("(");
-        for(std::size_t i = 0, n = multiPoint.getNumGeometries(); i < n; ++i) {
+        for(std::size_t i = 0; i < n; ++i) {
             if(i > 0) {
                 writer.write(", ");
@@ -506,15 +507,15 @@ void
 WKTWriter::appendMultiLineStringText(const MultiLineString& multiLineString, OrdinateSet outputOrdinates, int p_level, bool indentFirst,
-    if(multiLineString.isEmpty()) {
+    const std::size_t n = multiLineString.getNumGeometries();
+    if(n == 0) {
     else {
         int level2 = p_level;
         bool doIndent = indentFirst;
         writer.write("(");
-        for(std::size_t i = 0, n = multiLineString.getNumGeometries();
-                i < n; ++i) {
             if(i > 0) {
                 writer.write(", ");
                 level2 = p_level + 1;
@@ -530,15 +531,15 @@ WKTWriter::appendMultiLineStringText(const MultiLineString& multiLineString, Ord
 void
 WKTWriter::appendMultiPolygonText(const MultiPolygon& multiPolygon, OrdinateSet outputOrdinates, int p_level, Writer& writer) const
-    if(multiPolygon.isEmpty()) {
+    const std::size_t n = multiPolygon.getNumGeometries();
+    if(n == 0) {
     else {
         bool doIndent = false;
         writer.write("(");
-        for(std::size_t i = 0, n = multiPolygon.getNumGeometries();
-                i < n; ++i) {
             if(i > 0) {
                 writer.write(", ");
@@ -558,11 +559,14 @@ WKTWriter::appendGeometryCollectionText(
     int p_level,
-    if(geometryCollection.getNumGeometries() > 0) {
+    const std::size_t n = geometryCollection.getNumGeometries();
+    if(n == 0) {
+        writer.write("EMPTY");
+    else {
         writer.write("(");
-        for(std::size_t i = 0, n = geometryCollection.getNumGeometries();
-                i < n; ++i) {
             if(i > 0) {
                 writer.write(", ");
@@ -571,9 +575,6 @@ WKTWriter::appendGeometryCollectionText(
         writer.write(")");
-    else {
-        writer.write("EMPTY");
 void
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index 3f36218d4..e1adcf8ca 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -434,7 +434,7 @@ void object::test<28>
     std::string geojson { "{\"type\":\"MultiLineString\",\"coordinates\":[[],[],[]]}" };
     GeomPtr geom(geojsonreader.read(geojson));
-    ensure_equals(geom->toText(), "MULTILINESTRING EMPTY");
+    ensure_equals(geom->toText(), "MULTILINESTRING (EMPTY, EMPTY, EMPTY)");
     ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 2u);
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 2292275ec..19809825f 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -405,4 +405,63 @@ void object::test<14>
     ensure_equals(wktwriter.write(*g), "LINESTRING M (1 2 3, 4 5 NaN)");
+// Test multi-part geometries with zero or more empty parts
+// https://github.com/libgeos/geos/issues/951
+template<>
+template<>
+void object::test<15>
+    // zero empties -- but don't check dim types
+    // https://github.com/libgeos/geos/issues/888
+    std::vector<std::string> variants0{
+        "MULTIPOINT EMPTY", "MULTILINESTRING EMPTY",
+        "MULTIPOLYGON EMPTY", "GEOMETRYCOLLECTION EMPTY"
+    for (const auto& wkt : variants0) {
+        const auto g = wktreader.read(wkt);
+        ensure_equals(wktwriter.write(*g), wkt);
+        ensure_equals(g->getNumGeometries(), 0u);
+    // single empty
+    std::vector<std::string> variants1{
+        "MULTIPOINT (EMPTY)", "MULTIPOINT Z (EMPTY)",
+        "MULTIPOINT M (EMPTY)", "MULTIPOINT ZM (EMPTY)",
+        "MULTILINESTRING (EMPTY)", "MULTILINESTRING Z (EMPTY)",
+        "MULTILINESTRING M (EMPTY)", "MULTILINESTRING ZM (EMPTY)",
+        "MULTIPOLYGON (EMPTY)", "MULTIPOLYGON Z (EMPTY)",
+        "MULTIPOLYGON M (EMPTY)", "MULTIPOLYGON ZM (EMPTY)",
+        "GEOMETRYCOLLECTION (MULTIPOINT EMPTY)",
+        "GEOMETRYCOLLECTION Z (POINT Z EMPTY)",
+        "GEOMETRYCOLLECTION M (LINESTRING M EMPTY)",
+        "GEOMETRYCOLLECTION ZM (POLYGON ZM EMPTY)"
+    for (const auto& wkt : variants1) {
+        ensure_equals(g->getNumGeometries(), 1u);
+    // two empties
+    std::vector<std::string> variants2{
+        "MULTIPOINT (EMPTY, EMPTY)", "MULTIPOINT Z (EMPTY, EMPTY)",
+        "MULTIPOINT M (EMPTY, EMPTY)", "MULTIPOINT ZM (EMPTY, EMPTY)",
+        "MULTILINESTRING (EMPTY, EMPTY)", "MULTILINESTRING Z (EMPTY, EMPTY)",
+        "MULTILINESTRING M (EMPTY, EMPTY)", "MULTILINESTRING ZM (EMPTY, EMPTY)",
+        "MULTIPOLYGON (EMPTY, EMPTY)", "MULTIPOLYGON Z (EMPTY, EMPTY)",
+        "MULTIPOLYGON M (EMPTY, EMPTY)", "MULTIPOLYGON ZM (EMPTY, EMPTY)",
+        "GEOMETRYCOLLECTION (POLYGON EMPTY, LINESTRING EMPTY)",
+        "GEOMETRYCOLLECTION Z (LINESTRING Z EMPTY, POINT Z EMPTY)",
+        "GEOMETRYCOLLECTION M (POINT M EMPTY, LINESTRING M EMPTY)",
+        "GEOMETRYCOLLECTION ZM (POINT ZM EMPTY, LINESTRING ZM EMPTY)"
+    for (const auto& wkt : variants2) {
+        ensure_equals(g->getNumGeometries(), 2u);
 } // namespace tut
Summary of changes:
 NEWS.md                             |  1 +
 src/io/WKTWriter.cpp                | 29 +++++++++---------
 tests/unit/io/GeoJSONReaderTest.cpp |  2 +-
 tests/unit/io/WKTWriterTest.cpp     | 59 +++++++++++++++++++++++++++++++++++++
 4 files changed, 76 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
