[geos-commits] [SCM] GEOS branch main updated. f84966acecc6decd2aee2e7b26af83f50c6ccac3
Mon Sep 18 19:10:43 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  f84966acecc6decd2aee2e7b26af83f50c6ccac3 (commit)
      from  a9071dd7341ccac164e3754474f23aedae3582b4 (commit)
revisions in full, below.
commit f84966acecc6decd2aee2e7b26af83f50c6ccac3
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Sep 18 19:09:22 2023 -0700
    Remove debug prints
diff --git a/src/operation/distance/IndexedFacetDistance.cpp b/src/operation/distance/IndexedFacetDistance.cpp
index 8866b0d1e..d49012088 100644
--- a/src/operation/distance/IndexedFacetDistance.cpp
+++ b/src/operation/distance/IndexedFacetDistance.cpp
@@ -66,19 +66,17 @@ IndexedFacetDistance::isWithinDistance(const Geometry* g, double maxDistance) co
     if (envDist > maxDistance) {
         return false;
     //-- heuristic: for atomic indexed geom, test distance to envelope of test geom
     if (baseGeometry.getNumGeometries() == 1
         && ! g->getEnvelopeInternal()->contains(baseGeometry.getEnvelopeInternal()))
         auto env2 = g->getEnvelope();
-std::cout << "env dist = " << distance(env2.get()) << std::endl;
         if (distance(env2.get()) > maxDistance) {
-std::cout << "env dist > maxdistance of " << maxDistance << std::endl;
             return false;
     auto tree2 = FacetSequenceTreeBuilder::build(g);
     return cachedTree->isWithinDistance<FacetDistance>(*tree2, maxDistance);
diff --git a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
index a08eb9887..5b6f0cb73 100644
--- a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
+++ b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
@@ -88,7 +88,6 @@ struct test_facetdistanceop_data {
         IndexedFacetDistance ifd(g1.get());
         bool result = ifd.isWithinDistance(g2.get(), distance);
-std::cout << "result = " << result << "  expected = " << expected << std::endl;
         ensure_equals(result, expected);
Summary of changes:
 src/operation/distance/IndexedFacetDistance.cpp            | 6 ++----
 tests/unit/operation/distance/IndexedFacetDistanceTest.cpp | 1 -
 2 files changed, 2 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
