[geos-commits] [SCM] GEOS branch main updated. e0e68f636e3b0d32dd7ae09928044699f990a447
Thu Sep 21 18:21:34 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  e0e68f636e3b0d32dd7ae09928044699f990a447 (commit)
      from  bd633c61869573b0d4066792d6d27f8e1241cd90 (commit)
revisions in full, below.
commit e0e68f636e3b0d32dd7ae09928044699f990a447
Author: Dan Baston <dbaston at gmail.com>
Date:   Thu Sep 21 21:21:05 2023 -0400
    CoordinateSequence: Fix logic error when adding another CoordSeq (#963)
diff --git a/NEWS.md b/NEWS.md
index b1be865e0..a1502586a 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -13,8 +13,9 @@
   - Fix LargestEmptyCircle to respect polygonal obstacles (GH-939, Martin Davis)
   - Fix WKTWriter to emit EMPTY elements in multi-geometries (GH-952, Mike Taves)
   - Fix IncrementalDelaunayTriangulator to ensure triangulation boundary is convex (GH-953, Martin Davis)
-  - Fix PreparedLineStringDistance for lines within envelope and polygons (GH-959, Martin Davis)
+  - Fix PreparedLineStringDistance for lines within envelope and polygons (GH-959, Martin Davis)
   - Improve scale handling for PrecisionModel (GH-956, Martin Davis)
+  - Fix error in CoordinateSequence::add when disallowing repeated points (GH-963, Dan Baston)
 ## Changes in 3.12.0
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index a0ff67944..fc36b4bb3 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -191,8 +191,13 @@ CoordinateSequence::add(const CoordinateSequence& cs, std::size_t from, std::siz
+    if (first > to) {
+        // No unique points to add.
+        return;
     std::size_t last = first + 1;
-    const CoordinateXY* last_unique = &cs.front<CoordinateXY>();
+    const CoordinateXY* last_unique = &cs.getAt<CoordinateXY>(first);
     while(last <= to) {
         const CoordinateXY* curr = &cs.getAt<CoordinateXY>(last);
         if (curr->equals2D(*last_unique)) {
diff --git a/tests/unit/geom/CoordinateSequenceTest.cpp b/tests/unit/geom/CoordinateSequenceTest.cpp
index 7ec843bad..1d9c08782 100644
--- a/tests/unit/geom/CoordinateSequenceTest.cpp
+++ b/tests/unit/geom/CoordinateSequenceTest.cpp
@@ -1493,4 +1493,21 @@ void object::test<54>
     ensure(xyz3_2.equalsIdentical(xyz3));
+// test add(CoordinateSequence&, false) when last point of receiving sequence is found after the beginning of donor sequence
+template<>
+template<>
+void object::test<55>
+    CoordinateSequence seq1{CoordinateXY(1,2), CoordinateXY(3, 4)};
+    CoordinateSequence seq2{CoordinateXY(3, 4), CoordinateXY(3, 4), CoordinateXY(5, 6), CoordinateXY(3, 4), CoordinateXY(7, 8), CoordinateXY(7, 8), CoordinateXY(9, 10)};
+    CoordinateSequence expected{CoordinateXY(1, 2), CoordinateXY(3, 4), CoordinateXY(5, 6), CoordinateXY(3, 4), CoordinateXY(7, 8), CoordinateXY(9, 10)};
+    seq1.add(seq2, false);
+    ensure_equals(seq1, expected);
 } // namespace tut
Summary of changes:
 NEWS.md                                    |  3 ++-
 src/geom/CoordinateSequence.cpp            |  7 ++++++-
 tests/unit/geom/CoordinateSequenceTest.cpp | 17 +++++++++++++++++
 3 files changed, 25 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
