[geos-commits] [SCM] GEOS branch main updated. d51982c6da5b7adb63ca0933ae7b53828cc8d72e
Thu Sep 21 21:25:04 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  d51982c6da5b7adb63ca0933ae7b53828cc8d72e (commit)
      from  e0e68f636e3b0d32dd7ae09928044699f990a447 (commit)
revisions in full, below.
commit d51982c6da5b7adb63ca0933ae7b53828cc8d72e
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Sep 21 19:40:08 2023 -0700
    Add PrecisionReducer test (#962)
diff --git a/tests/unit/operation/overlayng/PrecisionReducerTest.cpp b/tests/unit/operation/overlayng/PrecisionReducerTest.cpp
index 3b3f4f7eb..7d9dc6ea0 100644
--- a/tests/unit/operation/overlayng/PrecisionReducerTest.cpp
+++ b/tests/unit/operation/overlayng/PrecisionReducerTest.cpp
@@ -27,11 +27,11 @@ struct test_precisionreducer_data {
     WKTWriter w;
     void
-    checkReduce(const std::string& wkt, double gridSize, const std::string& wkt_expected)
+    checkReduce(const std::string& wkt, double scale, const std::string& wkt_expected)
         std::unique_ptr<Geometry> geom = r.read(wkt);
         std::unique_ptr<Geometry> expected = r.read(wkt_expected);
-        PrecisionModel pm(1.0/gridSize);
+        PrecisionModel pm(scale);
         std::unique_ptr<Geometry> result = PrecisionReducer::reducePrecision(geom.get(), &pm);
         ensure_equals_geometry(result.get(), expected.get());
@@ -142,7 +142,7 @@ template<>
 void object::test<11> ()
     checkReduce("LINESTRING(-3 6, 9 1)",
-        2, "LINESTRING (-2 6, 10 2)");
+        0.5, "LINESTRING (-2 6, 10 2)");
 // testCollapsedLine
@@ -170,9 +170,18 @@ void object::test<14> ()
     checkReduce("POLYGON ((2 1, 3 1, 3 2, 2 1))",
     // checkReduce("POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 1 2, 2 1, 1 1), (1 2, 1 3, 2 3, 1 2), (2 3, 3 3, 3 2, 2 3))",
-        1.0/10, "POLYGON ((2 1, 3 1, 3 2, 2 1))");
+        10, "POLYGON ((2 1, 3 1, 3 2, 2 1))");
+// see https://github.com/libgeos/geos/issues/811
+template<>
+template<>
+void object::test<15> ()
+    checkReduce("POLYGON ((127.117461568 34.562519572, 127.117483252 34.5624884690001, 127.117603304 34.562319127, 127.117607152 34.562312309, 127.117607012 34.562312359, 127.117254733 34.5621607510001, 127.117746661 34.5620659730001, 127.117603496 34.5623196400001, 127.117484065 34.562488982, 127.117462315 34.562520066, 127.117245225 34.562385186, 127.117461568 34.562519572))",
+        100000,
+        "POLYGON ((127.11775 34.56207, 127.11725 34.56216, 127.11761 34.56231, 127.11775 34.56207))");
 } // namespace tut
Summary of changes:
 tests/unit/operation/overlayng/PrecisionReducerTest.cpp | 17 +++++++++++++----
 1 file changed, 13 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
