[geos-commits] [SCM] GEOS branch 3.12 updated. 3cfdccafc8d9102e7c9bcbc193c163d8f084882b
Mon Feb 5 11:16:46 PST 2024
the project "GEOS".
The branch, 3.12 has been updated
       via  3cfdccafc8d9102e7c9bcbc193c163d8f084882b (commit)
       via  c6bba89fed959008cc9dd74bf707f4c956ef75c2 (commit)
      from  14926fef3da92787793669f083499354c51ae603 (commit)
revisions in full, below.
commit 3cfdccafc8d9102e7c9bcbc193c163d8f084882b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Feb 5 11:16:09 2024 -0800
    News for GH-1039
diff --git a/NEWS.md b/NEWS.md
index c8e4d73a8..6c5e29f5c 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -11,6 +11,7 @@ xxxx-xx-xx
   - Fix PreparedPolygonContains for GC with MultiPoint (GH-1008, Martin Davis)
   - Fix TopologyPreservingSimplifier to prevent jumping components (GH-1012, Martin Davis)
   - Fix reading WKT with EMPTY token with white space (GH-1025, Mike Taves)
+  - Segfault in CoverageSimplify for non-polygonal inputs (GH-1039, Paul Ramsey)
 ## Changes in 3.12.1
 2023-11-11
commit c6bba89fed959008cc9dd74bf707f4c956ef75c2
Date:   Mon Feb 5 11:14:27 2024 -0800
    Fix segfault when coverage simplify called with nonpolygons, references GH-1031 (#1039)
diff --git a/src/coverage/CoverageSimplifier.cpp b/src/coverage/CoverageSimplifier.cpp
index 73b5a5e44..335b10759 100644
--- a/src/coverage/CoverageSimplifier.cpp
+++ b/src/coverage/CoverageSimplifier.cpp
@@ -20,6 +20,7 @@
 #include <geos/geom/Geometry.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/MultiLineString.h>
+#include <geos/util/IllegalArgumentException.h>
 using geos::geom::Geometry;
@@ -83,7 +84,12 @@ CoverageSimplifier::simplifyInner(
 CoverageSimplifier::CoverageSimplifier(std::vector<const Geometry*>& coverage)
     : m_input(coverage)
     , m_geomFactory(coverage.empty() ? nullptr : coverage[0]->getFactory())
+        for (const Geometry* g: m_input) {
+            if (!g->isPolygonal())
+                throw util::IllegalArgumentException("Argument is not a non-polygonal");
 /* public */
 std::vector<std::unique_ptr<Geometry>>
diff --git a/tests/unit/coverage/CoverageSimplifierTest.cpp b/tests/unit/coverage/CoverageSimplifierTest.cpp
index 61e79f54e..94534544a 100644
--- a/tests/unit/coverage/CoverageSimplifierTest.cpp
+++ b/tests/unit/coverage/CoverageSimplifierTest.cpp
@@ -431,7 +431,7 @@ void object::test<24> ()
             "POLYGON EMPTY",
             "POLYGON EMPTY" })
 // testOneEmpty
 template<>
@@ -446,7 +446,7 @@ void object::test<25> ()
             "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
             "POLYGON EMPTY" })
 // testEmptyHole()
 template<>
@@ -461,6 +461,26 @@ void object::test<26> ()
             "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9), EMPTY)",
             "POLYGON EMPTY" })
+// Test non-polygon inputs (GH-1031)
+template<>
+template<>
+void object::test<30> ()
+    auto input = readArray({
+        "MULTILINESTRING ((200 100, 100 100, 200 200), (200 200, 200 100), (200 200, 300 100, 200 100))"
+    try {
+        std::vector<std::unique_ptr<Geometry>> result =
+        CoverageSimplifier::simplify(input, 10);
+    catch (geos::util::IllegalArgumentException& iae) {
+        ensure("caught IllegalArgumentException", true);
+        return;
+    ensure("did not throw IllegalArgumentException", false);
 } // namespace tut
Summary of changes:
 NEWS.md                                        |  1 +
 src/coverage/CoverageSimplifier.cpp            |  8 +++++++-
 tests/unit/coverage/CoverageSimplifierTest.cpp | 26 +++++++++++++++++++++++---
 3 files changed, 31 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
