[geos-commits] [SCM] GEOS branch main updated. a8d2ed0aba46f88f9b8987526e68eea6565d16ae
Thu Feb 8 12:09:42 PST 2024
the project "GEOS".
The branch, main has been updated
       via  a8d2ed0aba46f88f9b8987526e68eea6565d16ae (commit)
      from  611b69a7a4eaf72a892c8379fd1e264f2aaa6124 (commit)
revisions in full, below.
commit a8d2ed0aba46f88f9b8987526e68eea6565d16ae
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Thu Feb 8 21:09:24 2024 +0100
    CI: add CodeQL static analyzer (#1045)
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
new file mode 100644
index 000000000..1ea5cdc18
--- /dev/null
+++ b/.github/workflows/codeql.yml
@@ -0,0 +1,68 @@
+name: "CodeQL"
+on:
+  push:
+  pull_request:
+concurrency:
+  group: ${{ github.workflow }}-${{ github.head_ref || github.ref }}
+  cancel-in-progress: true
+permissions:
+  contents: read
+jobs:
+  analyze:
+    name: Analyze
+    # Runner size impacts CodeQL analysis time. To learn more, please see:
+    #   - https://gh.io/recommended-hardware-resources-for-running-codeql
+    #   - https://gh.io/supported-runners-and-hardware-resources
+    #   - https://gh.io/using-larger-runners
+    # Consider using larger runners for possible analysis time improvements.
+    runs-on: ${{ (matrix.language == 'swift' && 'macos-latest') || 'ubuntu-latest' }}
+    timeout-minutes: ${{ (matrix.language == 'swift' && 120) || 360 }}
+    permissions:
+      actions: read
+      contents: read
+      security-events: write
+    strategy:
+      fail-fast: false
+      matrix:
+        language: [ 'c-cpp' ]
+        # CodeQL supports [ 'c-cpp', 'csharp', 'go', 'java-kotlin', 'javascript-typescript', 'python', 'ruby', 'swift' ]
+        # Use only 'java-kotlin' to analyze code written in Java, Kotlin or both
+        # Use only 'javascript-typescript' to analyze code written in JavaScript, TypeScript or both
+        # Learn more about CodeQL language support at https://aka.ms/codeql-docs/language-support
+    steps:
+    - name: Checkout repository
+      uses: actions/checkout at v4
+    # Initializes the CodeQL tools for scanning.
+    - name: Initialize CodeQL
+      uses: github/codeql-action/init at v3
+      with:
+        languages: ${{ matrix.language }}
+        # If you wish to specify custom queries, you can do so here or in a config file.
+        # By default, queries listed here will override any specified in a config file.
+        # Prefix the list here with "+" to use these queries and those in the config file.
+        # For more details on CodeQL's query packs, refer to: https://docs.github.com/en/code-security/code-scanning/automatically-scanning-your-code-for-vulnerabilities-and-errors/configuring-code-scanning#using-queries-in-ql-packs
+        # queries: security-extended,security-and-quality
+    - name: Install dependencies
+      run: |
+          sudo apt-get install -y cmake g++
+    - name: Build
+      run: |
+          mkdir build
+          cd build
+          cmake .. -DCMAKE_BUILD_TYPE=RelWithDebInfo
+          make -j$(nproc)
+    - name: Perform CodeQL Analysis
+      uses: github/codeql-action/analyze at v3
+      with:
+        category: "/language:${{matrix.language}}"
Summary of changes:
 .github/workflows/codeql.yml | 68 ++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 68 insertions(+)
 create mode 100644 .github/workflows/codeql.yml
hooks/post-receive
More information about the geos-commits mailing list
