[geos-commits] [SCM] GEOS branch 3.9 updated. d1d221f0d412db83f606125f4625faaafcd6979e
Mon Feb 26 02:09:30 PST 2024
the project "GEOS".
The branch, 3.9 has been updated
       via  d1d221f0d412db83f606125f4625faaafcd6979e (commit)
       via  c7769ea3b1fb383eab631f21ef872ffffbe1eec8 (commit)
      from  db33be2390305c405a50c4220a9c769e08fef273 (commit)
revisions in full, below.
commit d1d221f0d412db83f606125f4625faaafcd6979e
Author: Mike Taves <mwtoews at gmail.com>
Date:   Mon Feb 26 22:06:00 2024 +1300
    Regression test for mitre buffer that previously made an invalid geometry
diff --git a/tests/unit/operation/buffer/BufferParametersTest.cpp b/tests/unit/operation/buffer/BufferParametersTest.cpp
index 16e8a2f2f..034cba0a6 100644
--- a/tests/unit/operation/buffer/BufferParametersTest.cpp
+++ b/tests/unit/operation/buffer/BufferParametersTest.cpp
@@ -5,6 +5,9 @@
 #include <tut/tut.hpp>
 // geos
 #include <geos/operation/buffer/BufferParameters.h>
+#include <geos/operation/buffer/BufferOp.h>
+#include <geos/geom/Geometry.h>
+#include <geos/io/WKTReader.h>
 #include <geos/constants.h>
 // std
 #include <memory>
@@ -14,10 +17,16 @@ namespace tut {
 // Test Group
+using geos::operation::buffer::BufferParameters;
+using geos::operation::buffer::BufferOp;
+using geos::geom::Geometry;
 // Common data used by tests
 struct test_bufferparameters_data {
     typedef geos::operation::buffer::BufferParameters BufferParameters;
+    geos::io::WKTReader _reader;
     test_bufferparameters_data() { }
 private:
@@ -207,5 +216,22 @@ void object::test<10>
     ensure_equals(bp.getMitreLimit(), 5.0);
+// Buffer produces invalid output
+// https://github.com/libgeos/geos/issues/856
+template<>
+template<>
+void object::test<23>()
+    auto geom = _reader.read("POLYGON ((-23.989123360549296 73.1287474328027, -22.537997105552297 94.06368412079055,-18.796973600895146 93.80437130274495,-17.80121237894408 108.16990157009043,-21.542235883601226 108.42921438813606,-20.967403753721864 116.7221345967023,-4.728530705460814 116.7221568196225,-7.82790182044367 72.00851605865441,-23.989123360549296 73.1287474328027))");
+    BufferParameters bp;
+    bp.setJoinStyle(BufferParameters::JOIN_MITRE);
+    BufferOp op(geom.get(), bp);
+    auto result = op.getResultGeometry(10);
+    ensure(result->isValid());
 } // namespace tut
commit c7769ea3b1fb383eab631f21ef872ffffbe1eec8
Date:   Mon Feb 26 22:38:33 2024 +1300
    Make line intersection computation more robust (#937)
diff --git a/NEWS b/NEWS
index ac74b3aac..35958db05 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,7 @@
 xxxx-xx-xx
 - Bug fixes / improvements:
+  - Intersection: change to using DoubleDouble computation to improve robustness (GH-937, Martin Davis)
 ## Changes in 3.9.5
diff --git a/src/algorithm/Intersection.cpp b/src/algorithm/Intersection.cpp
index 455bd6048..f62025f16 100644
--- a/src/algorithm/Intersection.cpp
+++ b/src/algorithm/Intersection.cpp
@@ -15,6 +15,7 @@
 #include <cmath>
 #include <vector>
+#include <geos/algorithm/CGAlgorithmsDD.h>
 #include <geos/algorithm/Intersection.h>
 namespace geos {
@@ -26,59 +27,7 @@ geom::Coordinate
 Intersection::intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
                            const geom::Coordinate& q1, const geom::Coordinate& q2)
-    double minX0 = p1.x < p2.x ? p1.x : p2.x;
-    double minY0 = p1.y < p2.y ? p1.y : p2.y;
-    double maxX0 = p1.x > p2.x ? p1.x : p2.x;
-    double maxY0 = p1.y > p2.y ? p1.y : p2.y;
-    double minX1 = q1.x < q2.x ? q1.x : q2.x;
-    double minY1 = q1.y < q2.y ? q1.y : q2.y;
-    double maxX1 = q1.x > q2.x ? q1.x : q2.x;
-    double maxY1 = q1.y > q2.y ? q1.y : q2.y;
-    double intMinX = minX0 > minX1 ? minX0 : minX1;
-    double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
-    double intMinY = minY0 > minY1 ? minY0 : minY1;
-    double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
-    double midx = (intMinX + intMaxX) / 2.0;
-    double midy = (intMinY + intMaxY) / 2.0;
-    // condition ordinate values by subtracting midpoint
-    double p1x = p1.x - midx;
-    double p1y = p1.y - midy;
-    double p2x = p2.x - midx;
-    double p2y = p2.y - midy;
-    double q1x = q1.x - midx;
-    double q1y = q1.y - midy;
-    double q2x = q2.x - midx;
-    double q2y = q2.y - midy;
-    // unrolled computation using homogeneous coordinates eqn
-    double px = p1y - p2y;
-    double py = p2x - p1x;
-    double pw = p1x * p2y - p2x * p1y;
-    double qx = q1y - q2y;
-    double qy = q2x - q1x;
-    double qw = q1x * q2y - q2x * q1y;
-    double x = py * qw - qy * pw;
-    double y = qx * pw - px * qw;
-    double w = px * qy - qx * py;
-    double xInt = x/w;
-    double yInt = y/w;
-    geom::Coordinate rv;
-    // check for parallel lines
-    if (!std::isfinite(xInt) || !std::isfinite(yInt)) {
-        rv.setNull();
-        return rv;
-    // de-condition intersection point
-    rv.x = xInt + midx;
-    rv.y = yInt + midy;
-    return rv;
+    return CGAlgorithmsDD::intersection(p1, p2, q1, q2);
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index d63713994..53a6f8c26 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -305,25 +305,21 @@ void object::test<2>
 // but apparently works now.
 // Possibly normalization has fixed this?
-#if 0 // fails: finds 1 intersection rather then two
 template<>
 template<>
 void object::test<3>
     std::vector<Coordinate> intPt;
-    intPt.push_back(Coordinate(2089426.5233462777, 1180182.3877339689));
-    intPt.push_back(Coordinate(2085646.6891757075, 1195618.7333999649));
+    intPt.push_back(Coordinate(2087600.4716727887, 1187639.7426241424));
     checkIntersection(
         "LINESTRING ( 2089426.5233462777 1180182.3877339689, 2085646.6891757075 1195618.7333999649 )",
         "LINESTRING ( 1889281.8148903656 1997547.0560044837, 2259977.3672235999 483675.17050843034 )",
-        2,
+        1,
         intPt, 0);
-#endif // fails
-#if 0 // fails: the intersection point doesn't match
 // 4 - Outside envelope using HCoordinate method (testCmp5CaseWKT)
 template<>
 template<>
@@ -331,7 +327,7 @@ void object::test<4>
-    intPt.push_back(Coordinate(4348437.0557510145, 5552597.375203926));
+    intPt.push_back(Coordinate(4348440.8493873989, 5552599.2720221197));
     checkIntersection(
         "LINESTRING (4348433.262114629 5552595.478385733, 4348440.849387404 5552599.272022122 )",
@@ -339,9 +335,7 @@ void object::test<4>
         1,
         intPt, 0);
-#endif // fails
 // 5 - Result of this test should be the same as the WKT one!
 //     (testCmp5CaseRaw)
 template<>
@@ -356,11 +350,10 @@ void object::test<5>
     pt.push_back(Coordinate(4348440.8493874,   5552599.27202212));
     checkIntersection(pt, 1, intPt, 0);
-#endif // fails
  * Test involving two non-almost-parallel lines.
@@ -456,7 +449,7 @@ void object::test<10>
         "LINESTRING (-215.22279674875 -158.65425425385, -218.1208801283 -160.68343590235)",
         1,
         "POINT ( -215.22279674875 -158.65425425385 )",
-        0);
+        1.0e-10);
diff --git a/tests/unit/operation/relate/RelateOpTest.cpp b/tests/unit/operation/relate/RelateOpTest.cpp
index 711aa6850..787a41ad7 100644
--- a/tests/unit/operation/relate/RelateOpTest.cpp
+++ b/tests/unit/operation/relate/RelateOpTest.cpp
@@ -84,4 +84,28 @@ void object::test<2> ()
     "FF10F0102"    );
+// see https://github.com/locationtech/jts/issues/396
+// testContainsNoding
+template<>
+template<>
+void object::test<4> ()
+    checkRelate(
+        "LINESTRING (1 0, 0 2, 0 0, 2 2)",
+        "LINESTRING (0 0, 2 2)",
+        "101F00FF2"    );
+// see https://github.com/libgeos/geos/issues/933
+template<>
+template<>
+void object::test<5> ()
+    checkRelate(
+        "MULTILINESTRING ((0 0, 1 1), (0.5 0.5, 1 0.1, -1 0.1))",
+        "LINESTRING (0 0, 1 1)",
+        "1F1000FF2"    );
 } // namespace tut
diff --git a/tests/xmltester/tests/general/TestRelateLL.xml b/tests/xmltester/tests/general/TestRelateLL.xml
index 4c05b6664..4a4fb4289 100644
--- a/tests/xmltester/tests/general/TestRelateLL.xml
+++ b/tests/xmltester/tests/general/TestRelateLL.xml
@@ -1,5 +1,4 @@
 <run>
-  <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
 <case>
   <desc>LL - disjoint, non-overlapping envelopes</desc>
@@ -308,7 +307,7 @@
 </case>
 <case>
-<desc>LA - closed multiline / empty line</desc>
+<desc>LL - closed multiline / empty line</desc>
   <a>
     MULTILINESTRING ((0 0, 0 1), (0 1, 1 1, 1 0, 0 0))
   </a>
@@ -320,4 +319,50 @@
   </test>
 </case>
+<case>
+<desc>LL - test intersection node computation (see https://github.com/locationtech/jts/issues/396)</desc>
+  <a>
+    LINESTRING (1 0, 0 2, 0 0, 2 2)
+  </a>
+  <b>
+    LINESTRING (0 0, 2 2)
+  </b>
+  <test>
+    <op name="relate" arg1="A" arg2="B" arg3="101F00FF2">true</op>
+  </test>
+  <test><op name="contains"   arg1="A" arg2="B"> true  </op></test>
+  <test><op name="coveredBy"  arg1="A" arg2="B"> false </op></test>
+  <test><op name="covers"     arg1="A" arg2="B"> true  </op></test>
+  <test><op name="crosses"    arg1="A" arg2="B"> false </op></test>
+  <test><op name="disjoint"   arg1="A" arg2="B"> false </op></test>
+  <test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+  <test><op name="intersects" arg1="A" arg2="B"> true  </op></test>
+  <test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
+  <test><op name="touches"    arg1="A" arg2="B"> false </op></test>
+  <test><op name="within"     arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+<desc>LL - test intersection node computation (see https://github.com/libgeos/geos/issues/933)</desc>
+  <a>
+    MULTILINESTRING ((0 0, 1 1), (0.5 0.5, 1 0.1, -1 0.1))
+  </a>
+  <b>
+    LINESTRING (0 0, 1 1)
+  </b>
+  <test>
+    <op name="relate" arg1="A" arg2="B" arg3="1F1000FF2">true</op>
+  </test>
+</case>
 </run>
diff --git a/tests/xmltester/tests/issue/issue-geos-398.xml b/tests/xmltester/tests/issue/issue-geos-398.xml
index 3143f09e0..edb3984ef 100644
--- a/tests/xmltester/tests/issue/issue-geos-398.xml
+++ b/tests/xmltester/tests/issue/issue-geos-398.xml
@@ -32,9 +32,8 @@ POLYGON ((50.0044466166182886 0.0,
   </b>
 <test>
  <op name="union" arg1="A" arg2="B">
-MULTIPOLYGON (((0 25.950779066386122, 0 26.860827855779647, 0 29.83879230192533, 0 35.73921397193218, 60 13.183894681853793, 60 10.39852836763784, 60 7.802134559422377, 60 6.657099879646016, 60 6.510515132098641, 60 0, 55.31611974965083 0, 50.00444661661829 0, 43.31611974965083 0, 0 0, 0 14.034613342373582, 0 17.92266612923108, 0 21.587486526024364, 0 25.950779066386122),
-  (0 21.587486526024364, 34.025852439655786 6.898140262297274, 34.02585243965579 6.898140262297273, 0 21.587486526024364)),
-  ((13.44557253233479 36, 60 36, 60 16.794451829809802, 60 16.36440115550932, 60 14.043996030454757, 2.9187843276549756 36, 11.8945390820011 36, 13.44557253233479 36)))
+MULTIPOLYGON (((0 26.860827855779647, 0 29.83879230192533, 0 35.73921397193218, 60 13.183894681853793, 60 10.39852836763784, 60 7.802134559422377, 60 6.657099879646016, 60 6.510515132098641, 60 0, 55.31611974965083 0, 50.00444661661829 0, 43.31611974965083 0, 0 0, 0 14.034613342373582, 0 17.92266612923108, 0 21.587486526024364, 0 25.950779066386122, 0 26.860827855779647)),
+  ((60 36, 60 16.794451829809802, 60 16.36440115550932, 60 14.043996030454757, 2.9187843276549756 36, 11.8945390820011 36, 13.44557253233479 36, 60 36)))
  </op>
 </test>
 </case>
diff --git a/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml b/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml
index 66f488591..f5f9e69ee 100644
--- a/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml
+++ b/tests/xmltester/tests/robust/overlay/TestOverlay-pg-list.xml
@@ -47,7 +47,7 @@ MULTIPOLYGON (((742591.4178018438 5087769.04526206, 742591.417801844 5087769.045
 <test>
 <op name="intersection" arg1="A" arg2="B">
-MULTIPOLYGON (((434608.9999999999 2012571.9999999907, 434608.99999999977 2012571.9999999907, 434505.9999999997 2013031.9999999907, 434889.4374999999 2013081.8073453507, 434506 2013031.99999999, 434608.9999999999 2012571.9999999907)), ((434990.9999999999 2013094.99999999, 435264.9999999997 2013496.9999999898, 435311.2499999999 2013535.9783236892, 435265 2013496.99999999, 434991 2013094.99999999, 434990.9999999999 2013094.99999999)), ((436813.9999999997 2014014.99999999, 436802.9999999997 2014278.9999999893, 436803 2014278.9999999893, 436814 2014014.99999999, 436813.9999999997 2014014.99999999)), ((437427.6587183307 2014442.90461996, 437488.99999999977 2014458.99999999, 437372.9999999997 2016223.9999999898, 437686.7499999999 2016676.926282041, 437373 2016223.99999999, 437489 2014458.99999999, 437427.6587183307 2014442.90461996)))
+MULTIPOLYGON (((437372.9999999997 2016223.9999999898, 437686.7499999997 2016676.9262820408, 437373 2016223.99999999, 437489 2014458.99999999, 437427.6587183306 2014442.90461996, 437488.99999999977 2014458.99999999, 437372.9999999997 2016223.9999999898)), ((434990.9999999999 2013094.99999999, 435264.9999999997 2013496.9999999898, 435311.2499999997 2013535.9783236892, 435265 2013496.99999999, 434991 2013094.99999999, 434990.9999999999 2013094.99999999)), ((434505.9999999997 2013031.9999999907, 434889.4374999997 2013081.8073453507, 434506 2013031.99999999, 434608.9999999999 2012571.9999999907, 434608.99999999977 2012571.9999999907, 434505.9999999997 2013031.9999999907)), ((436802.9999999997 2014278.9999999893, 436803 2014278.9999999893, 436814 2014014.99999999, 436813.9999999997 2014014.99999999, 436802.9999999997 2014278.9999999893)))
 </op>
 </test>
Summary of changes:
 NEWS                                               |  1 +
 src/algorithm/Intersection.cpp                     | 55 +---------------------
 .../unit/algorithm/RobustLineIntersectionTest.cpp  | 17 ++-----
 .../unit/operation/buffer/BufferParametersTest.cpp | 26 ++++++++++
 tests/unit/operation/relate/RelateOpTest.cpp       | 24 ++++++++++
 tests/xmltester/tests/general/TestRelateLL.xml     | 49 ++++++++++++++++++-
 tests/xmltester/tests/issue/issue-geos-398.xml     |  5 +-
 .../tests/robust/overlay/TestOverlay-pg-list.xml   |  2 +-
 8 files changed, 108 insertions(+), 71 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
