[geos-commits] [SCM] GEOS branch main updated. 078a37eaa6fd0017fefdf3347fa8a5d27f819f51
Mon Jan 8 14:23:08 PST 2024
the project "GEOS".
The branch, main has been updated
       via  078a37eaa6fd0017fefdf3347fa8a5d27f819f51 (commit)
      from  5e806d6918e296c722312c732ff6a0f6df61f416 (commit)
revisions in full, below.
commit 078a37eaa6fd0017fefdf3347fa8a5d27f819f51
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Jan 8 14:22:47 2024 -0800
    Fix incorrect commented code, add RelatePA tests
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index c00205b81..1c8e57a9a 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -209,10 +209,9 @@ GeometryGraph::addCollection(const GeometryCollection* gc)
     for(std::size_t i = 0, n = gc->getNumGeometries(); i < n; ++i) {
         const Geometry* g = gc->getGeometryN(i);
-        //if (! g->isEmpty()) {
+        if (! g->isEmpty()) {
             add(g);
diff --git a/tests/xmltester/tests/general/TestRelatePA.xml b/tests/xmltester/tests/general/TestRelatePA.xml
index 07ceb7e93..4c2345a7d 100644
--- a/tests/xmltester/tests/general/TestRelatePA.xml
+++ b/tests/xmltester/tests/general/TestRelatePA.xml
@@ -157,7 +157,7 @@
 </case>
 <case>
-  <desc>mPA - empty MultiPoint element</desc>
+  <desc>mPA - empty MultiPoint element for A</desc>
   <a>
     MULTIPOINT(EMPTY,(0 0))
   </a>
@@ -181,6 +181,81 @@
 <test><op name="within"     arg1="A" arg2="B"> true  </op></test>
 </case>
+<case>
+  <desc>mPA - empty MultiPoint element for A, on boundary of B</desc>
+  <a>
+    MULTIPOINT(EMPTY,(1 0))
+  </a>
+  <b>
+    POLYGON ((1 0,0 1,-1 0,0 -1, 1 0))
+  </b>
+<test>
+  <op name="relate" arg3="F0FFFF212" arg1="A" arg2="B">
+    true
+  </op>
+</test>
+<test><op name="contains"   arg1="A" arg2="B"> false </op></test>
+<test><op name="coveredBy"  arg1="A" arg2="B"> true  </op></test>
+<test><op name="covers"     arg1="A" arg2="B"> false </op></test>
+<test><op name="crosses"    arg1="A" arg2="B"> false </op></test>
+<test><op name="disjoint"   arg1="A" arg2="B"> false </op></test>
+<test><op name="equalsTopo" arg1="A" arg2="B"> false </op></test>
+<test><op name="intersects" arg1="A" arg2="B"> true  </op></test>
+<test><op name="overlaps"   arg1="A" arg2="B"> false </op></test>
+<test><op name="touches"    arg1="A" arg2="B"> true </op></test>
+<test><op name="within"     arg1="A" arg2="B"> false  </op></test>
+</case>
+<case>
+  <desc>mPA - empty MultiPoint element for B</desc>
+  <a>
+  </a>
+  <b>
+    MULTIPOINT(EMPTY,(0 0))
+  </b>
+<test>
+  <op name="relate" arg3="0F2FF1FF2" arg1="A" arg2="B">
+    true
+  </op>
+</test>
+<test><op name="contains"   arg1="A" arg2="B"> true </op></test>
+<test><op name="coveredBy"  arg1="A" arg2="B"> false  </op></test>
+<test><op name="covers"     arg1="A" arg2="B"> true </op></test>
+<test><op name="touches"    arg1="A" arg2="B"> false </op></test>
+</case>
+<case>
+  <desc>mPA - empty MultiPoint element for B, on boundary of A</desc>
+  <a>
+  </a>
+  <b>
+  </b>
+<test>
+  <op name="relate" arg3="FF20F1FF2" arg1="A" arg2="B">
+    true
+  </op>
+</test>
+</case>
 <case>
   <desc>PmA - empty MultiPolygon element</desc>
   <a>
Summary of changes:
 src/geomgraph/GeometryGraph.cpp                |  5 +-
 tests/xmltester/tests/general/TestRelatePA.xml | 77 +++++++++++++++++++++++++-
 2 files changed, 78 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
